Results 1 to 20 of 20
    Sep 2006
    I've got a fairly modest Lenovo i5 laptop and I'm wondering if it would be suitable to use for capturing HD video via an external USB capture device. One thing I'm not sure of is whether or not the graphics card matters when capturing video, or if it's mainly the CPU and RAM. The laptop has integrated Intel HD 4000 graphics, and I'm not sure if this is good enough for smooth captures. Here are the relevant system specs:
    CPU: Intel Core i5-3210M @ 2.5GHz (Ivy Bridge)
    RAM: 8 GB PC3-12800 DDR3 SDRAM
    Video: Intel HD Graphics 4000
    Storage: 500 GB 7200 RPM SATA HD
    It has USB3 ports, if that would make a difference. Is this good enough for capturing HD video?
  2. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Hauppage GE Plus. Perfect for Laptops. Its a hardware encoder.
    Claudio
    Sep 2006
    Claudio
    Thanks for the suggestion, but it's more than I really wanted to spend.. My max is $100. How about this one:
    http://amzn.com/B005YR0M0W
    Aug 2006
    Claudio
    If you read the reviews, some owners find the quality of captured HD video to be disappointing.
  5. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    Keep in mind that it has no Harddrive so that add cost
    Best read the Newegg user review http://www.newegg.com/Product/Product.aspx?Item=N82E16815100097
    Look around youtube as well
    Sep 2006
    BTW, these new external PVRs are basically standalone with their own realtime hardware encoders, making the power of my CPU/GPU largely irrelevant, right? I mean, you can basically record without the computer at all, it's just used to tweak the recording settings and dump the recorded files to?
    Are there cheaper USB devices that use the computer's CPU/GPU to encode instead of doing the work on the device? It seems like I already have a computer, why pay for more processing power to do the work? Maybe I'm just not clear on how video capture works.
    Sep 2006
    I'll be using an external HD, so that's not an issue. I'll be using it to record HD content from my cable box, so I need one with a component input. The Hauppage GE Plus has HDMI input, but it comes with a component to HDMI cable (for PS3) that I can use, right?
  8. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    There is no Component to HDMI cable
    HDMI Output for Live Preview or Pass-through to any Monitor like PC or TVset so long it support 480i, 480p, 720p, 1080i or 1080p.
    HDMI Input is for Xbox, Xbox 360, Xbox One, PC and any other device that doesn't output HDCP.
    Component Input is for and device that has Component Output and need less to say must use with PS3 because HDMI Output is always on HDCP copy protection with everything.
    S/Video Input is for and device that has Output.
    Composite Input is for and device that has Output.
    Stereo Analog Audio, SPDIF Optical Audio and HDMI Audio Input
    IR blaster
    Two HDMI Cable
    One PS3 Component Cable that Plugs in to back of the PS3 it same cable you can buy at any local store for PS3 because it not included if going to your TV set.
    One Component A/V Input Cable that plugs in to the back of the HD-PVR 2
    One Power Supply
    Software Disc
    Accessories you can add to the Hauppauge HD-PVR 2 Gaming Edition Plus which is not included.
    IR Receive/Blast/Learn cable
    A/V Cable Set for S-Video, Composite Video and Stereo Audio
    Hauppauge Remote Control
    WinTV v7.2 with Extend
    There also the HD-PVR 2 model 1512 which included the above Accessories but what not included is
    PS3 Component Cable
    Aug 2006
    The standalone devices and most external HD capture devices output H.264 transport streams as output, so CPU power does not come into play for encoding. However there are CPU/GPU requirements for the device which must be met in order to play or edit your captured video.
    No. The only inexpensive HD capture devices that do not use hardware encoding are internal PCI-e devices. You need an external capture device that encodes using hardware because you have a laptop.
    The problem is that USB 2.0 doesn't have enough bandwidth to carry the uncompressed high-definition output from an external capture device. USB 3.0 or Thunderbolt do provide the required bandwidth, but the Blackmagic Intensity external HD capture devices that have those interfaces and use software to encode are beyond your budget, plus your laptop probably does not meet their hardware requirements.
    Nov 2000
    Canada
    Might want to check Ebay and see if anyone is selling an HDPVR for $100. It does happen. But I'm now looking to upgrade my old one to a HDPVR 2 with HDMI capture and that still costs as much as $200. I think your budget might be a bit on the low side if you want to play this game...
    The computer should be fine. I can cap 13.5 mbps (max. bit rate) with an Asus i5 with 6 GB RAM without any problems...
    Sep 2006
    The pic of the back of the unit on Amazon only shows an HDMI input, no component. That's why I was wondering if there was some sort of component to HDMI adapter included, but you're saying no?
    Sep 2006
    Thanks for the info, now I understand. So an HD PVR is what I need.
  13. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    See the label A/V in Port that what this for
    Image Attached Images
    Sep 2006
    See the Plugs label A/V in that what this for
    OK, that's what I meant by component to HDMI cable. Thanks.
    Aug 2006
    It is not your only choice. The Elgato Game Capture HD is another good HD capture device that supports using a higher bitrate for capture than the HD-PVR 2 and costs only a little more. However, it only records stereo audio, not 5.1 audio like the HD-PVR 2 and the Elgato Game Capture HD doesn't work with Windows PVR software for capturing TV shows from a set-top box.
  16. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    Keep in mind that Hauppauge is only device that can record Dolby Digital 5.1 Audio (AC3)
    List of Hardware Compression with Component input and or with HDMI
    "USB 2.0 Interface"
    AVerTV USB HD DVR (C874)
    AVerMedia Live Gamer Portable (C875)
    AVerMedia Game Capture HD (C281)
    AVerMedia HD EzRecorder Plus (C283)
    Diamond 1080 Game Console Video Capture (GC1000)
    elgato Game Capture HD (10025010)
    Hauppauge HD-PVR 2 (1512)
    Hauppauge HD-PVR 2 Gaming Edition Plus (1504)
    Hauppauge HD-PVR (1212)
    "PCIe Interface"
    AVerMedia Live Gamer HD (C985)
    AVerMedia Game Broadcaster HD (C127)
    Hauppauge Colossus (1414)
    "Express 34/54 Slot Interface"
    AVerMedia AVerTV Express HD DVR (C927) I can't fig out if this is a Hardware or Software Compression it saying Realtime H.264 Recording.
    Software Compression with Component input and or with HDMI
    "USB 2.0 Interface"
    Diamond HD Game Capture (GC500)
    KWorld Gaming Maker (GM220)
    "USB 3.0 Interface"
    Blackmagic Design Intensity Shuttle (BINTSSHU) USB3
    "Thunderbolt Interface"
    Blackmagic Design Intensity Shuttle (BINTSSHU/THBOLT)
    "PCIe Interface"
    AVerMedia AVerTV HD DVR (C027)
    Blackmagic Design Intensity Pro (BINTSPRO)
    Blackmagic design DeckLink Mini Recorder (BDLKMINREC)
    This id not counting the min other like Matrox, Grass Valley and so on.
  17. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Hi SHS,
    Can you separate by input (USB, PCI and PCI-e)??
    Claudio
  18. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    How that?
  19. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    How that?
    Perfect!!
    Claudio
    Aug 2006
    "USB 2.0 Interface"
    "PCIe Interface"
    "USB 2.0 Interface"
    "USB 3.0 Interface"
    "PCIe Interface"
    It is important to point out that the Diamond HD Game Capture (GC500) and KWorld Gaming Maker (GM220) capture from component video input, but otherwise are not really in the same class as the other capture devices in the list because they capture in standard definition.
