When incorporating avisource() in a QTGMC deinterlace script it causes problems - i.e. processing the file with audio included the resulting file is messed up, if I do it without audio the problems don't show up. Using ffmpegsource() instead I don't have the problems.
Others say they don't have this problem that they can use avisource() just fine. It's been suggested that something is buggy with the VFW DV decoder and decoding pathway.
So, how do I determine what that something is and fix it? Using a standard Windows XP Pro install, don't know why this aspect of things would be messed up. If others don't have this issue I should be able to achieve the same state.
What info should I include to facilitate diagnosis?
Thanks for all input.
Switch DV decoders? What are you using now? Try Cedocida if you aren't using it already.
Also try AviSource("DV.AVI", audio=false). Any difference? Ie, same DV decoder but not using the audio. -
Have MainConcept DV codec installed.
Avisynth: Maximum Avisource limit reached inside Premiere
By Anoel in forum Video ConversionReplies: 3Last Post: 4th Jan 2013, 17:15 -
mencoder + avisynth + AviSource
By Selur in forum Newbie / General discussionsReplies: 0Last Post: 13th Oct 2012, 15:58 -
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 23:53 -
MP3 codec for AviSource?
By AlanHK in forum Software PlayingReplies: 5Last Post: 29th Sep 2009, 23:53 -
FAVC "Use Directshowsource instead of AVIsource"
By dzsoul in forum Authoring (DVD)Replies: 9Last Post: 19th Dec 2008, 19:00
