I have another camcorder to get from a grant received. I can spend around $3000 or a little more but not much more. What camcorder would you get? No real low light issues but I think when you get to this level most do well in low light anyway. Now, we don't have to spend it all if something for cheaper is better.
	How about that new Canon Hf G30 or better XA20 (less money left for rest of gear though), + solid tripod, some lights, microphones, batteries, stabilizer.
	I wonder if the XA20 would just be the answer. It might give me all I need. I do have a solid tripod. Could use some mics, maybe a battery and some of the other gear. Good idea.
 Are you familiar with the Panasonic AG-AC90. I wonder how these two compare. I am going to do some searches and see although the AC90 is somewhat new.
	Take a look here: http://www.dvinfo.net/forum/canon-xa-vixia-series-avchd-camcorders/ there are people that discuss those comparisons of that sort. There is even more expensive XA25.
	I had narrowed it down to three choices. One was the Panasonic AG-AC90, the other was the Canon XA20, and the final was the Canon XF100. It is really a toss up overall as to which one to get. I don't think that anyone in the class or anyone else around will be able to tell the difference between the AC90 and the other two. I would save a lot of money and I could put that toward something else. As time goes by and we upgrade equipment maybe something better would be in the books but for now maybe the AC90 is the way I go unless someone can justify why something else other than the AC90.
	Here is another link for the Panasonic AG-AC90:
 http://www.dvinfo.net/forum/panasonic-avccam-camcorders/510881-first-look-panasonic-ag...0-dv-expo.html
 Brainiac
	Wow.  It has many functions.  I will have to do a lot of learning to pull this one off, that's for sure. It has many functions.  I will have to do a lot of learning to pull this one off, that's for sure.
  Best Camcorder for my Budget - Football Games (High School)By Stoneface in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 31st Mar 2013, 22:00
  On a budget, any recommendations?By marioval in forum Media Center PC / MediaCentersReplies: 5Last Post: 17th Aug 2012, 13:41
  Is there a decent budget dual-use PAL digicam/camcorder?By wapwap in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 23rd Mar 2010, 03:48
  SD vs. HD (documentary and on a budget)By Aheiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 17th Mar 2010, 01:55
  Camcorder upgrade, pref w/ progressive capability less than $1000 budget ?By vhelp in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 27Last Post: 13th May 2009, 02:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
