i get this when i try to render a video im use a 3 filters (levels, xsharpen, Brightness and Contrast)
VirtualDub crash report -- build 32842 (release)
Disassembly:
0d3c3680: 00e8 add al, ch
0d3c3682: 2a11 sub dl, [ecx]
0d3c3684: 0000 add [eax], al
0d3c3686: 46 inc esi
0d3c3687: 3bf3 cmp esi, ebx
0d3c3689: 7ee5 jle 0d3c3670
0d3c368b: 5e pop esi
0d3c368c: 83fb3f cmp ebx, 3fh
0d3c368f: 5b pop ebx
0d3c3690: 7d0c jge 0d3c369e
0d3c3692: b808000000 mov eax, 00000008
0d3c3697: 33c9 xor ecx, ecx
0d3c3699: e912110000 jmp 0d3c47b0
0d3c369e: c3 ret
0d3c369f: cc int 3
0d3c36a0: 53 push ebx
0d3c36a1: 55 push ebp
0d3c36a2: 56 push esi
0d3c36a3: 8b742410 mov esi, [esp+10h]
0d3c36a7: 57 push edi
0d3c36a8: b820000000 mov eax, 00000020
0d3c36ad: b9b6010000 mov ecx, 000001b6
0d3c36b2: 8bd6 mov edx, esi
0d3c36b4: e8f7100000 call 0d3c47b0
0d3c36b9: 8b5c241c mov ebx, [esp+1ch]
0d3c36bd: 8b4b14 mov ecx, [ebx+14h]
0d3c36c0: b802000000 mov eax, 00000002
0d3c36c5: e8e6100000 call 0d3c47b0
0d3c36ca: 33ed xor ebp, ebp
0d3c36cc: 33d2 xor edx, edx
0d3c36ce: 396b28 cmp [ebx+28h], ebp
0d3c36d1: 7643 jbe 0d3c3716
0d3c36d3: 8b4e0c mov ecx, [esi+0ch]
0d3c36d6: b800000080 mov eax, 80000000
0d3c36db: d3e8 shr eax, cl
0d3c36dd: 094608 or [esi+08h], eax
0d3c36e0: 8d4101 lea eax, [ecx+01h]
0d3c36e3: 89460c mov [esi+0ch], eax
0d3c36e6: 83f820 cmp eax, 20h
0d3c36e9: 7225 jc 0d3c3710
0d3c36eb: 8b4e08 mov ecx, [esi+08h]
0d3c36ee: 894c2414 mov [esp+14h], ecx
0d3c36f2: 8b442414 mov eax, [esp+14h]
0d3c36f6: 0fc8 bswap eax
0d3c36f8: 89442414 mov [esp+14h], eax
0d3c36fc: 8b4610 mov eax, [esi+10h]
0d3c36ff: 8b4c2414 mov ecx, [esp+14h]
0d3c3703: 8908 mov [eax], ecx <-- FAULT
0d3c3705: 83461004 add dword ptr [esi+10h], 04h
0d3c3709: 83460ce0 add dword ptr [esi+0ch], 0e0h
0d3c370d: 896e08 mov [esi+08h], ebp
0d3c3710: 42 inc edx
0d3c3711: 3b5328 cmp edx, [ebx+28h]
0d3c3714: 72bd jc 0d3c36d3
0d3c3716: ff460c inc dword ptr [esi+0ch]
0d3c3719: 837e0c20 cmp dword ptr [esi+0ch], 20h
0d3c371d: 722f jc 0d3c374e
0d3c371f: 8b5608 mov edx, [esi+08h]
0d3c3722: 89542414 mov [esp+14h], edx
0d3c3726: 8b442414 mov eax, [esp+14h]
0d3c372a: 0fc8 bswap eax
0d3c372c: 89442414 mov [esp+14h], eax
0d3c3730: 8b4610 mov eax, [esi+10h]
0d3c3733: 8b4c2414 mov ecx, [esp+14h]
0d3c3737: 8908 mov [eax], ecx
0d3c3739: bf04000000 mov edi, 00000004
0d3c373e: 017e10 add [esi+10h], edi
0d3c3741: 896e08 mov [esi+08h], ebp
0d3c3744: bde0ffffff mov ebp, ffffffe0
0d3c3749: 016e0c add [esi+0ch], ebp
0d3c374c: eb08 jmp 0d3c3756
0d3c374e: bde0ffffff mov ebp, ffffffe0
0d3c3753: 8d7d24 lea edi, [ebp+24h]
0d3c3756: 8b4e0c mov ecx, [esi+0ch]
0d3c3759: ba00000080 mov edx, 80000000
0d3c375e: d3ea shr edx, cl
0d3c3760: 8d4101 lea eax, [ecx+01h]
0d3c3763: 89460c mov [esi+0ch], eax
0d3c3766: 095608 or [esi+08h], edx
0d3c3769: 83f820 cmp eax, 20h
0d3c376c: 7227 jc 0d3c3795
0d3c376e: 8b4608 mov eax, [esi+08h]
0d3c3771: 89442414 mov [esp+14h], eax
0d3c3775: 8b442414 mov eax, [esp+14h]
0d3c3779: 0fc8 bswap eax
0d3c377b: 89442414 mov [esp+14h], eax
0d3c377f: 8b db 8bh
Built on Aegis on Fri Dec 24 13:18:44 2010 using compiler version 1400
Windows 5.1 (Windows XP x86 build 2600) [Service Pack 3]
EAX = 135a7000
EBX = 035c4880
ECX = ffffffff
EDX = 02a37efd
EBP = 00000000
ESI = 141beca0
EDI = 035c4880
ESP = 141bebe4
EIP = 0d3c3703
EFLAGS = 00010246
FPUCW = ffff027f
FPUTW = ffffaaaa
Crash reason: Access Violation
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'xvidcore'...
...writing address 135A7000...
...while compressing frame 1 from 13b10020 to 13060020 using codec "Xvid MPEG-4 Codec" (w32videocodecpack.cpp:696)...
...while running thread "Processing" (thread.cpp:163).
Pointer dumps:
EBX 035c4880: 00000003 0000ffff 00000000 0000018e 00003454 00000001 00000001 00000000
EDX 02a37ef9: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ESI 141beca0: 7f0001b0 f5000001 ffffffff 00000020 135a7000 13060020 00000000 00000000
EDI 035c4880: 00000003 0000ffff 00000000 0000018e 00003454 00000001 00000001 00000000
ESP 141bebe0: 00245228 035c4880 035c20c0 141beca0 035c4100 0d409fa1 ffffffff 035c20c0
141bec00: 035c4880 00000001 00000001 035c20c0 035c4880 035c4100 035c2180 035c218c
141bec20: 035c21a4 035c21bc 00100000 00000001 141bed04 035c4a00 035c20c0 00000001
141bec40: 00000001 00000000 00000001 00000000 0000002d 00000000 00000000 00000000
Thread call stack:
0d3c3703: xvidcore!00003703
0d409fa1: xvidcore!xvid_plugin_ssim [0d3c0000+42b90+7411]
0d40b1e0: xvidcore!xvid_plugin_ssim [0d3c0000+42b90+8650]
0d40c24b: xvidcore!xvid_encore [0d3c0000+4c220+2b]
03442241: xvidvfw!00002241
034487a7: xvidvfw!DriverProc [03440000+8550+257]
7c920945: ntdll!RtlAcquirePebLock [7c910000+1091d+28]
7c92094e: ntdll!RtlAcquirePebLock [7c910000+1091d+31]
7c92402e: ntdll!RtlDetermineDosPathNameType_U [7c910000+1399f+68f]
7c920970: ntdll!RtlReleasePebLock [7c910000+10961+f]
7c9240ef: ntdll!RtlDetermineDosPathNameType_U [7c910000+1399f+750]
7c9240bb: ntdll!RtlDetermineDosPathNameType_U [7c910000+1399f+71c]
0057005c: VDResamplerSeparableTableRowStage8SSE41::Process()
7c9205c8: ntdll!RtlFreeHeap [7c910000+1043d+18b]
7c920551: ntdll!RtlFreeHeap [7c910000+1043d+114]
7c92056d: ntdll!RtlFreeHeap [7c910000+1043d+130]
7c926cd7: ntdll!RtlMultiAppendUnicodeStringBuffer [7c910000+1671b+5bc]
7c9137bf: ntdll!RtlConvertUlongToLargeInteger [7c910000+3745+7a]
7c91378b: ntdll!RtlConvertUlongToLargeInteger [7c910000+3745+46]
7c947b48: ntdll!RtlUnwind [7c910000+37a40+108]
7c91d625: ntdll!NtContinue [7c910000+d619+c]
7c947b75: ntdll!RtlUnwind [7c910000+37a40+135]
7c80de9c: kernel32!DuplicateHandle [7c800000+ddfe+9e]
7c925db4: ntdll!RtlValidateUnicodeString [7c910000+15c72+142]
7c9253f5: ntdll!RtlFindActivationContextSectionString [7c910000+15319+dc]
7c925af1: ntdll!RtlDosApplyFileIsolationRedirection_Ustr [7c910000+157a3+34e]
7c925041: ntdll!bsearch [7c910000+14ffb+46]
7c925233: ntdll!bsearch [7c910000+14ffb+238]
7c9255c9: ntdll!RtlHashUnicodeString [7c910000+15465+164]
7c920732: ntdll!RtlAllocateHeap [7c910000+105d4+15e]
0051eb90: vdint128:special)()
0043430d: VideoPrefetcher::Finalize()
00437805: FilterInstance::GetSourceFrame()
005b306d: free()
005b308c: free()
0043278c: VDFilterFrameRequestAllocator::AllocateClientReque st()
00432855: VDFilterFrameRequest::CreateClient()
0043289d: VDFilterFrameRequest::CreateClient()
0043237f: VDFilterFrameQueue::Add()
004372ca: FilterInstance::CreateRequest()
004372f9: FilterInstance::CreateRequest()
7c924859: ntdll!RtlGetLongestNtPathLength [7c910000+147df+7a]
7c923212: ntdll!LdrLockLoaderLock [7c910000+13171+a1]
7c91d4ea: ntdll!NtAllocateVirtualMemory [7c910000+d4de+c]
7c9280ff: ntdll!RtlReAllocateHeap [7c910000+179fd+702]
7c9206ab: ntdll!RtlAllocateHeap [7c910000+105d4+d7]
7c9206eb: ntdll!RtlAllocateHeap [7c910000+105d4+117]
7c921596: ntdll!wcsncpy [7c910000+10a8f+b07]
7c921414: ntdll!wcsncpy [7c910000+10a8f+985]
0043689a: FilterInstance::GetPrefetchInfo()
0051cad7: VDMemcpyRect()
0055e2d8: VDPixmapUberBlitterDirectCopy::Blit()
75ba18a8: MSVFW32!ICSendMessage [75ba0000+187d+2b]
75ba4c09: MSVFW32!ICCompress [75ba0000+4ba6+63]
0057e3fb: VDVideoCompressorVCM::PackFrameInternal()
0057ee15: VDVideoCompressorVCM::CompressFrame()
7c8025f0: kernel32!WaitForSingleObjectEx [7c800000+2540+b0]
00431ca6: VDFilterFrameManualSource::GetNextRequest()
7c802532: kernel32!WaitForSingleObject [7c800000+2520+12]
004783d2: VDThreadedVideoCompressor::ProcessFrame()
00478807: VDThreadedVideoCompressor::ExchangeBuffer()
004220e9: VDDubVideoProcessor::WriteFinishedVideoFrame()
00422f89: VDDubVideoProcessor::ProcessVideoFrame()
00423137: VDDubVideoProcessor::WriteVideo()
00425533: VDStreamInterleaver::GetNextAction()
-- End of report
Results 1 to 26 of 26
Probably an Xvid problem. Try a different codec and see what happens.Crash reason: Access Violation
Crash context:
...while compressing frame 1 from 13b10020 to 13060020 using codec "Xvid MPEG-4 Codec" (w32videocodecpack.cpp:696)... -
the codec is working but this is happen only when i use filters and i really need them
and i try to use another codec but the i can't compress the video -
I have no doubt Xvid is working. But there's always the possibility that a particular setup brings out a bug.
I don't know what you mean by "can't compress the video". Do you mean using another codec crashes too? Or you just don't get the compression/quality you want. The point of trying a differnt codec (or no compression) is to try to isolate the problem to Xvid or to the filtering. -
Try eliminating one filter at a time to figure out which one is causing problems. My guess is XSharpen.
i try to delete filter by filter but nothing is there any other xvid codec?
Excuse me, I thought you were referring to the decoding.
I don't think recent versions of FFDshow even have the xvid encoder, do they?
Does it only fail on this one video? If so, it's possible it has some bad frames causing the encoding to fail.
Give this a try. Select file/open video file.
In the bottom left, put a check mark in "ask for extended options". Select the file and when the options come up,
select redrive keyframes.
Set video and audio to "direct stream copy" and save the avi as-is.
Then open this video for filtering. save as normal. (video/full processing) -
the problem is the filters i try divx codec but the program still crashing
the problem is not the filters it's when i check this option but i really need this so the video and audio play at the same time
this is the script that i use
pip=AVISource("1.avi").Spline36Resize(776,549)
background=ImageReader("Pokemon Light Platinum.png", start=0, end=10496)
overlay(background, pip, x=252, y=83)
ConvertToYV12()
vid=last
aud=AVISource("1.avi")
audiodub(vid,aud)
MyBackground=last
Logo=ImageSource("pokemon.png",pixel_type="RGB32", start=0, end=10496)
Overlay(MyBackground, Logo , mask=Logo.ShowAlpha())
WithLogo=last
MyBackground.trim(0,8122) ++ WithLogo.trim(8122,10496) -
Perhaps this is the problem... Spline36Resizee(776,549)
Try using mod4 sizes... -
mod4 means evenly divisible by 4
549 is not, but 548 is
Spline36Resize(776, 548) -
Remember in your other thread, I said there was an "fps" parameter to ImageSource() (or ImageReader() ) ? The default is 24.0 fps .
https://forum.videohelp.com/threads/355159-Avisynth-Question?p=2233340&viewfull=1#post2233340
When you use overlay(), the fps will take the value from the background layer fps, not the overlay layer fps (in this case 24.0 fps, because you never entered the fps value)
So if your 1.avi was 30 fps, it's going to be out of sync .
You might have to adjust the frame numbers and trim numbers for the rest of the script
You can try x264vfw for encoding, but it's likely a filter issue if you can encode fine without filters. Or do the filters in avisynth instead
What does vdub file=>file information say with the avs script loaded , no other filters ?Last edited by poisondeathray; 5th Aug 2013 at 23:04.
x264vfw crash when is use filters
can you please give example how to change the fps?
pip=AVISource("1.avi").Spline36Resize(776, 548)
ConvertToYV12()
vid=last
audiodub(vid,aud)
MyBackground=last
WithLogo=last
or you can add AssumeFPS(30) to the end, but you should get in the habit of specifying fps for ImageSource or keeping track of the fps of various sequences
background=ImageReader("Pokemon Light Platinum.png", start=0, end=10496, fps=30)
ConvertToYV12()
vid=last
audiodub(vid,aud)
MyBackground=last
Logo=ImageSource("pokemon.png",pixel_type="RGB32", start=0, end=10496, fps=30)
WithLogo=last
If you remove all the filters one by one as jagabo suggested, did you find out which one causes the crash ? Or remove them all, then one by one add them back . If you figure that out, you can use another similar filter in vdub or avisynth -
So what about the filters and xvid encoding error/crash ? or does that work ok too now ?
VirtualDub error
By ajc109 in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2012, 11:50 -
VirtualDub Error
By WebMaximus in forum Video ConversionReplies: 5Last Post: 6th Jun 2011, 13:29 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
Virtualdub Error
By Hittz in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 08:27
special)()
