    May 2013
    EDM, USA
    I love using DVDStyler for it's custom menus but anyways I keep trying to burn a DVD with softsubs and I keep getting this error.
    ERR: Encoded row takes more than 1440 bits. Please simplify subtitle.
    Failed
    I'm using English, ISO-8859-1, Tahoma 28.
    DVDStyler v2.5 beta 4
    Windows 7 (build 7601, Service Pack 1)
    FFmpeg: libavformat 54.21.2, libavcodec 54.41.1, libavutil 52.7.0
    Prepare
    Cleaning temporary directory
    Search for transcoded files in cache
    Generating menus
    Generating menu 1 of 3
    Create menu MPEG
    Multiplexing subpictures into mpeg
    Menu has 1 group(s) of changeable colours.
    Executing command: spumux -P -s 0 "C:\AppData\Local\Temp\dvd-tmp\menu1-0.mpg_spumux.xml"
    DVDAuthor::spumux, version 0.7.1.
    Build options: gnugetopt iconv freetype fribidi fontconfig
    Send bug reports to <dvdauthor-users@lists.sourceforge.net>
    INFO: no default video format, must explicitly specify NTSC or PAL
    INFO: Converting filenames to cp1252
    INFO: PNG had 1 colors
    INFO: PNG had 4 colors
    INFO: Pickbuttongroups, success with 1 groups, useimg=1
    INFO: 0 bytes of data written
    INFO: 47104 bytes of data written
    INFO: 94208 bytes of data written
    INFO: 139264 bytes of data written
    INFO: 186368 bytes of data written
    INFO: Found EOF in .sub file.
    INFO: Max_sub_size=240
    INFO: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.50
    Executing command: spumux -P -s 1 "C:\AppData\Local\Temp\dvd-tmp\menu1-0.mpg_spumux.xml"
    INFO: 141312 bytes of data written
    INFO: 188416 bytes of data written
    INFO: Max_sub_size=186
    INFO: 237568 bytes of data written
    INFO: found existing substream ID 0x20 (DVD-Video 0)
    INFO: 1 subtitles added, 0 subtitles skipped, stream: 33, offset: 0.50
    Generating menu 2 of 3
    Create menu MPEG
    Executing command: spumux -P -s 0 "C:\AppData\Local\Temp\dvd-tmp\menu1-1.mpg_spumux.xml"
    INFO: 20480 bytes of data written
    INFO: 38912 bytes of data written
    INFO: 59392 bytes of data written
    INFO: 77824 bytes of data written
    INFO: Max_sub_size=5258
    Executing command: spumux -P -s 1 "C:\AppData\Local\Temp\dvd-tmp\menu1-1.mpg_spumux.xml"
    INFO: 22528 bytes of data written
    INFO: 43008 bytes of data written
    INFO: 63488 bytes of data written
    INFO: 83968 bytes of data written
    INFO: Max_sub_size=3962
    INFO: 104448 bytes of data written
    Generating menu 3 of 3
    Create menu MPEG
    Executing command: spumux -P -s 0 "C:\AppData\Local\Temp\dvd-tmp\menu1-2.mpg_spumux.xml"
    INFO: 32768 bytes of data written
    INFO: 65536 bytes of data written
    INFO: 98304 bytes of data written
    INFO: 131072 bytes of data written
    INFO: Max_sub_size=460
    Executing command: spumux -P -s 1 "C:\AppData\Local\Temp\dvd-tmp\menu1-2.mpg_spumux.xml"
    INFO: 34816 bytes of data written
    INFO: 67584 bytes of data written
    INFO: 102400 bytes of data written
    INFO: 135168 bytes of data written
    INFO: Max_sub_size=358
    INFO: 169984 bytes of data written
    Multiplexing subtitles
    Multiplexing subtitles 1 of 1
    Executing command: spumux -P -s 0 "C:\AppData\Local\Temp\dvd-tmp\title0-0-0.vob_spumux.xml"
    INFO: Opened iconv descriptor. *UTF-8* <= *ISO-8859-1*
    INFO: Detected subtitle file format: subviewer
    INFO: Read 1041 subtitles
    INFO: Adjusted 485 subtitle(s).
    INFO: Unicode font: 2888 glyphs.
    Failed
  2. I keep getting the illegal byte sequence error and I'm already in UTF-8. OSX 10.9.4 updated Dvd Styler. Can anyone help?
  3. can you upload sample subtitle file?
