Hi all,
Still new and learning, can i ask, at what point in a dvd rip do the "black bars" at bottom and top of the file appear? Does is depend on the original DVD? I use DVDfab to rip and then Handbrake to encode, is this something i can adjust? If i already have an encoded file with it can i change this?
Sorry for all the questions, im finding a step learning curve!
Thanks for any advice.
It depends on the video source, see http://en.m.wikipedia.org/wiki/Aspect_ratio_(image)
If the video is wider than your display you will get black bars. You can crop/zoom the video so it fits but you will of course lose some video then. -
DVDs made from video tape sources often have a few black (or noisy) lines at the bottom of the frame. It's in the nature of video tape.
Sometimes those bars show the PRESENCE of filler, sometimes they are just the ABSENCE of video.
Insert "beep" audio to black out words in a mp4 file
By IngvarEkstrom in forum Newbie / General discussionsReplies: 18Last Post: 30th Dec 2020, 14:24 -
"Greenish" Black & White To "True(r)" Black & White?
By DeathStalker77 in forum RestorationReplies: 8Last Post: 30th Jul 2011, 09:39 -
An analysis of "static bars" error needed
By moxiecat in forum RestorationReplies: 10Last Post: 20th Feb 2011, 16:48 -
Best "Black Box" for overriding VHS Macrovision and CopyGuard?
By will7370 in forum Video ConversionReplies: 4Last Post: 20th May 2010, 02:03 -
Easiest way to "black out" a small section of video in an AVI file?
By johnny905 in forum EditingReplies: 7Last Post: 24th Mar 2010, 07:14
