For a multimedia playback system I need to encode multichannel sound files as AC3.
I managed to run the ffmpegx encoder, but when I convert back to multichannel PCM (using QuickTime Pro 7), it seems that the input channels have been mixed together to the first two (stereo front) channels, while the other four channels are empty.
I am using a 6-channel 48 kHz 16-bit WAV file as input. This is accepted by ffmpegx, saying it is "5.1". I use AC3 as target, encode-audio only. Audio-tab says:
- 448 kbit/s, 48000 Hz, 5:1 channels, CBR, Audio track: 0 (what is this supposed to mean?), Inverted mapping yes (that's the default).
What am I doing wrong? I can adjust the channel mapping of my source file, no problem, but I need the 5 or 6 input channels to correspond exactly with separate channels in the AC3 file.
Perhaps related: I have no clue what the "Audio track" selection menu in the Audio tab is supposed to mean, neither what the "Add audio..." button is for.
Thanks very much!
	Think I solved the issue. First of all, QuickTime Player 7 although supporting multi-channel audio when using PCM files, seems to have broken or incompatible A3 decoding. Second, I am using Audacity now for export. It uses ffmpegx as backend, but is more comfortable than the ffmpegx standalone app, because it has a channel mapping matrix and can go up to 640 kbps.
 Files exported this way with Audacity are played correctly back as 5 / 6 discrete channels with VLC.
  Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 16:57
  Which player S/W and H/W can play 12.3 Mbps 48 KHz 8 channels PCM wave?By Bonie81 in forum AudioReplies: 3Last Post: 8th Jul 2011, 20:30
  7.1 channels - I plan to have it on my Bluray. Premiere Pro? TrueHD? PCM?By Asterra in forum AudioReplies: 3Last Post: 18th May 2011, 08:02
  How to convert WAV/MPA/MP3 to AC3 6 channels?By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 15:12
  MKVs: downmix ac3 6-channels to ac3 2-channels and remuxBy kwanbis in forum AudioReplies: 4Last Post: 10th Mar 2009, 17:07
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
