Hello,
Recently I tried making my own intro to use when I upload videos to YouTube. I wanted to add a couple of small videos in the corners of the intro (to make it look nice) when I realised that the edges of these small videos looked very sharp and didn't blend well at all with the background. I tried looking for a tool on VideoPad Editor to smooth the edges into the background so that they didn't stand out so much, but I had no luck.
All I could find was the smoothness effect in the effects menu and all that did was blur the entire video. I would appreciate it if someone could point out the tool that can smooth the edges of the clips (if it exists) or maybe point me in the direction of a program that can do it for me! (preferably cheap/free)
Thanks in advance for the help,
Max
	And you have to use this VideoPad Video Editor, or you can use something else? Maybe VideoPad doesn't provide such a tool. Ideally you want to smooth both your little video at its edges as well as the larger video around where the smaller one joins it. I think it's called 'feathering'. Does VideoPad have such a thing?
 AviSynth with a mask and overlay can do it fairly easily, but if you've never used it there's a learning curve. I don't know if there are any NLEs with such a feature.
	What I ended up doing was adding a border around the outside of the clip so that it wouldn't look so sharp, it looks great now! Well in my eyes at least :P
 Max
  Problem with VideoPad Editor - screen turns blackBy titothetitan in forum EditingReplies: 3Last Post: 18th May 2013, 04:13
  VideoPad Editor won't capture from Panasonic camcorderBy dbmcinnis in forum Capturing and VCRReplies: 2Last Post: 1st Sep 2012, 13:58
  VideoPad Video Editor narration/media problems *PLEASE HELP*By 19tyler19 in forum EditingReplies: 1Last Post: 25th May 2011, 02:04
  Videopad video ruined by subtitles?By pixisticks in forum Newbie / General discussionsReplies: 7Last Post: 3rd Aug 2010, 20:45
  VEGAS 6: Smoothing out jagged edges on still during slideshowBy pdx10 in forum Newbie / General discussionsReplies: 1Last Post: 17th Apr 2009, 20:08
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
