Is there a way to rotate (clockwise) a *.MOV Quicktime video by 90 deg?
If it is possible then rotation should be performed lossless.
If lossless is not possible then the necessary re-encoding should be done with AVC/H.264 video codec and MP3 audio codec
Thank you
The command you want is -vf "transpose=1" and you'll have to reencode.
If you're not hell-bent on using ffmpeg, Quicktime Pro does it flawlessly, quickly and without conversion. So does Picasa.Last edited by smrpix; 1st Aug 2013 at 11:30.
Best program to rotate videos?
By Amuse in forum EditingReplies: 10Last Post: 19th Feb 2014, 11:29 -
How to get streamable quicktime / mov file with FFMPEG ?
By rajivrp in forum ffmpegX general discussionReplies: 2Last Post: 27th Jul 2012, 08:08 -
How to ROTATE a video (quicktime or anything)
By nerys in forum EditingReplies: 2Last Post: 21st May 2011, 07:45 -
How to rotate a MOV file? I just gave up.
By Pixelrage in forum EditingReplies: 10Last Post: 28th Oct 2009, 23:30 -
Lossless rotate of MJPEG file?
By kmlee in forum Video ConversionReplies: 18Last Post: 10th Oct 2008, 19:54
