I want got a esaycap, But other easycap not work with my Mac. The easycap dongle can work with Mac OS?
http://www.amazon.com/gp/product/B00E9J452M
You might want to check with the manufacturer concerning Mac OS compatibility. I don't see any reviews for that device and it doesn't appear to be available yet, and there is only one available, besides it's costing much more that similar models.
This is the only REAL - GENUINE EZCap.
http://www.ezcap.tv/
ALL of the others are fake, cheap pieces of garbage. -
I recommend that you do not buy that device. Buying "EasyCap" models like the one shown is a gamble. There are several different devices sold under the "Easycap name. They use different chips inside, and are often poorly made. There is no manufacture support available, which means if the disc supplied with the device doesn't contain appropriate drivers and software, you must find them yourself. That task is often difficult.
If you want something for a Mac that will actually work, here are two choices with good reviews:
elgato makes a good product: http://www.amazon.com/electronics/dp/B0029U2YSA
If elgato's capture dongle is too expensive buy this: http://www.amazon.com/Diamond-Multimedia-Capture-Device-VC500MAC/dp/B007QCIBX8
WiFi dongle compatible with Philips BDP3200
By xodeus in forum DVD & Blu-ray PlayersReplies: 3Last Post: 4th Jan 2012, 23:14 -
3 dongle problem
By Mr anderson in forum ComputerReplies: 2Last Post: 6th Feb 2011, 09:43 -
Wifi to Ethernet dongle?
By rhegedus in forum ComputerReplies: 5Last Post: 24th May 2009, 01:53 -
carbon coder usb dongle error
By sid_dionne in forum Video ConversionReplies: 9Last Post: 9th Apr 2009, 14:27 -
Adding BLUETOOTH to Epson R300 using Dongle ... Which one works?
By Toaster in forum MediaReplies: 4Last Post: 13th Sep 2008, 09:19
