I have a DVD authored on TMPGEnc Authoring Works 4 (not by me), and, at least on VLC Player, the menus only show for a split screen before going to a green background with only the highlights of the links visible, or if you navigate the menus, the background shows whatever menu or image was previous in the navigation. That is, if you open the DVD you'll see the main menu for a moment before it goes to green, and if you follow the highlight of, say, the bonus features menu, the background of the bonus features menu shows what should be the main menu background. What's the workaround for this? Thanks in advance.
Results 1 to 1 of 1
Menu background sound in multi avchd
By DODGEYONE in forum Newbie / General discussionsReplies: 1Last Post: 20th Nov 2011, 14:13 -
TMPGENc Authoring Works 4: Menu crashes after I add background music
By silentmachine in forum Authoring (DVD)Replies: 2Last Post: 11th Aug 2011, 16:32 -
Does Tmpgenc Authoring works 4 support motion background menus?
By perfection in forum Authoring (DVD)Replies: 1Last Post: 10th Mar 2011, 03:35 -
Picture as Menu Background in Adobe Photoshop
By boofer in forum Authoring (DVD)Replies: 3Last Post: 16th Oct 2008, 02:41 -
green/blue background effect
By kj1983 in forum EditingReplies: 2Last Post: 30th Sep 2008, 04:35
