I converted a 6.3GB movie down to 4.3GB to fit on a single DVD-R (using CCE 2.5SP). But now I have this single huge file (4.5GB with audio) that I need to split into 1GB *.VOB files. How do I get the 4.5GB split into 1GB chunks? I tried to convert individual .VOBs and re-mux the audio into each one, but when played with PowerDVD using the "Play Media Files" option, there is a noticeable gap when it changes from one .MPG file to the next that DOESN'T happen when two .VOBs are played like this. Also, the navigation information seems to have been lost... I can no longer use the PowerDVD slider to select where I want to view the file (I have to use "FF" to scan through the movie). Is there something that I can use to split this files and re-create the navigation information (I am guessing that the header needs to be updated).
I don't exactly get that you want to spilit VOB or MPG ?
you can spilit MPG easily with TMPGEnc and even you can spilit VOB with IFOEdit and so many other softwares
S. Mohammad Najafi
SPLIT A LARGE VOB FILE INTO 1GB CHUNKS AND AUTHOR
By jimmalenko in forum User guidesReplies: 39Last Post: 12th Aug 2011, 09:37 -
Vdub script / tool etc - split large file into 10 min segments? (auto)
By Jynks in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2010, 06:19 -
Split 720P MPG File
By ap0091 in forum Video ConversionReplies: 2Last Post: 30th Aug 2008, 12:51 -
large file split for multiple displays and convert ... what tool 2 use?
By rodpacker1 in forum Video ConversionReplies: 3Last Post: 13th Oct 2007, 03:03 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
