I'm using Sony Vegas 12 64bit. I have a video of a dance concert that I've edited. The footage in the timeline looks fine but every time I try to render it as an mpg, the lighting in the video flickers, suddenly becoming brighter, darker, flashing, etc.
I've tried various mpg settings to no avail. I tried rendering as an AVI, and that seemed to work better, but once I put it into Encore (CS4) and compressed it, I had the same problem.
I've been doing this kind of project for years and I've never seen this before. I am at a total loss. Any ideas?
Thanks for your reply. I have already disabled GPU acceleration, and that fixed the problem of frames blacking out and text disappearing, but this little anomaly remains.
I seem to have reduced the issue by switching the render from interlaced to progressive, but the light flickers are still there every once in a while. Anyone have any other suggestions for mpg settings?
I'll try to get a clip of what I'm talking about uploaded, but I'm on my way out the door right now.
Thanks again -
Ok, you're gonna call me crazy, but once I posted it to youtube, the flashes didn't show up.
Am I losing my mind? Is it just a playback problem on my PC?
You may be able to see a subtle little one in this clip, but the major ones which are readily apparent on my PC do not show up here.
It should be noted that any other timeline I render under these settings does NOT produce this effect. I suspect it has something to do with the compression's attempt to deal with the generally low lighting in the piece. But I don't really know. I'm starting to think it's ghosts.
http://www.youtube.com/watch?v=TksCTmkIxas -
Youtube reencodes everything so we can't tell what your video really looks like from that. You should upload a sample directly to this forum. The forum accepts up to 100 MB files. Look at the Quick Reply box below this post. Use the Upload Files / Manage Attachments button below the edit box when you post a message.
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
Quality problem "caused" during "deinterlacing" ?
By Hombre_86 in forum DVD RippingReplies: 26Last Post: 25th May 2010, 21:28 -
VHS tape capture "flickering" - Intensity Pro Capture Card
By mofaster in forum Capturing and VCRReplies: 2Last Post: 31st May 2009, 12:56 -
Filter anti "flickering flame" effect?
By park84 in forum RestorationReplies: 1Last Post: 6th Jan 2009, 10:02 -
VHS capture - "flickering" red
By pfredd in forum RestorationReplies: 12Last Post: 19th Nov 2008, 21:24
