Results 61 to 66 of 66
MSuper is part of MVTools2.
Make sure you have mvtools2.dll in the plugins folder. Or load it manually by using LoadPlugin("PATH\mvtools2.dll")
Read this section on "requirements"
http://avisynth.nl/index.php/QTGMC#Requirements
or there are bundled packages that have everything on this page
http://forum.doom9.org/showthread.php?t=156028
You won't be able to "fix" it.I want to fix stuttering created when I convert 60fps to 30fps, meabe frame dropping too.
You might make it slightly less worse, that's all -
That usually indicates you don't have MVTools2. Try this one and see if it gets rid of the error message:
http://avisynth.org.ru/mvtools/mvtools-v2.5.11.3.zip -
And in the end you'll find that adding motion blur often creates ugly artifacts and only makes a tiny difference in the flicker.
Which is better video: 1080i 60i/30fps or 720p 60fps?
By jbitakis in forum Video ConversionReplies: 7Last Post: 9th Dec 2012, 05:59 -
How do I convert 60fps to 30fps to halve file size?
By DigitalOxygen.ca in forum MacReplies: 33Last Post: 11th Jul 2012, 22:27 -
Encoding 30fps from 60fps source, keep maximum smoothness?
By squall0833 in forum Video ConversionReplies: 22Last Post: 13th Apr 2012, 00:57 -
Shoot 60fps or 30fps for YouTube?
By vid83 in forum Video Streaming DownloadingReplies: 5Last Post: 18th Jun 2011, 13:42 -
Converting 720p/60fps file to 30fps?
By mt123 in forum Newbie / General discussionsReplies: 11Last Post: 17th Nov 2009, 13:34
