Hi. I've used avidemux 2.5 (portable) for a long time with no problems although I do also have the 2.6 version (also portable) for the odd file that 2.5 doesn't like. Yesterday, I used 2.5 to edit some scenes from a clip then, deciding the volume was too loud, loaded the new file so as to reduce it by a few Db.
It wouldn't load, saying “a problem has caused avidemux to stop working”. And that's now the case for every video I try to open with 2.5. I downloaded a clean copy of 2.5 but it crashes too. Version 2.6 still works, however.
I've ran ccleaner and malwarebytes. Can anyone suggest what the problem (and cure) could be?
My grateful thanks to anyone who can assist.
	Update...
 At the same time as avidemux started crashing, WMP was repeating a video every time I played it and I was saving that problem for later. Turns out I had accidentally hit the 'repeat' button and now that I've unclicked it, avidemux is back to normal.
 I believe both programs use the same 'engine' so I must assume that avidemux doesn't like WMP being on 'repeat'.
  AVIdemux keeps crashingBy gastrof in forum Newbie / General discussionsReplies: 2Last Post: 31st Jan 2012, 14:32
  Avidemux aspect ratio question [from newbie to Avidemux]By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 21:07
  Y/C Separation 2D/3D could this be the only reason?By DB83 in forum Capturing and VCRReplies: 2Last Post: 9th Jul 2010, 14:13
  My Avidemux Is CrashingBy bigman70 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 12:54
  Computer Shuts Down For No ReasonBy bryankendall in forum Newbie / General discussionsReplies: 7Last Post: 23rd Nov 2008, 17:33
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
