Page 74 of 75
FirstFirst ... 24 64 72 73 74 75 LastLast
Results 2,191 to 2,220 of 2222
  1. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.2_RC1+1-00d8df1b3bc6
    (x64, multilib, GCC 9.2.0, upx)
    "Programmers are human-shaped machines that transform alcohol into bugs."
  2. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.2+3-fdd69a766881
    Image Attached Thumbnails x265_2019-09-25.pdf
    Aug 2013
    Central Germany
    Nice PDF. Obviously supposed to be an auto-generated x265 documentation. Unfortunately ... the converter is not perfect. It does not support the "option::" tag as span formatting instruction, and there are some lines in bold weight which exceed the page margins.
    Aug 2013
    Central Germany
    x265 3.2+3-fdd69a766881 (MSYS2/MinGW, GCC 9.2.0)
  5. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.2+5-354901970679
    Latest changes:
    --- Fix: AQ mode 4 commit (21db162) introduces slowdown even when AQ mode 4 is not used;
    --- Adaptive Frame duplication
    This patch does the following:
    1. Replaces 2-3 near-identical frames with one frame and sets pic_struct based on frame doubling / tripling;
    2. Add option "--frame-dup" and "--dup-threshold' to enable frame duplication and to set threshold for frame similarity (optional);
    Aug 2013
    Central Germany
    x265 3.2+5-354901970679
  7. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.2+15-04db2bfee5d6
    API: New API to reconfigure zones
    Add encoded frame bits into analysis structure
    add reference list in analysis structure
    zone: tune base QP to achieve zone target
    add total intra percentage per frame in analysis structure
    Enable Boundary Aware Frame Quantizer Selection
    1)Reduce bits for frames inside the scenecut-window and increase the quality of
    scenecut I-frames.
    2)Add options "--scenecut-aware-qp", "--scenecut-window" and "--max-qp-delta" to
    enable boundary aware frame quantization, to set window size (optional) and to
    set offset(optional).
  8. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.2+17-4a29e0c5bfaf
    µchangelog
    Histogram Based Scene Cut Detection.
    This patch does the following.
    1.Finds scene cuts by thresholding normalized SAD of edge and chroma histograms.
    2.Add option "--hist-scenecut" to enable histogram based scene cut detection.
    3.Add option "--hist-threshold" to provide threshold for determining scene cuts.
    4.Optimizes frame duplication by reusing normalized SAD to mark duplicate frames.
    Also:
    limit-tu: Fix bug in loading co-located CU's TU depth.
  9. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.2+18-f0fe46ce379d
    Fix pass 2 encode failure
    https://bitbucket.org/multicoreware/x265/commits/f0fe46ce379dbdf21ee255146796dbf5c4e02ac7
  10. DECEASED
    Jun 2009
    Heaven
    Aug 2013
    Central Germany
    Please note:
    Bitbucket will drop the support for Mercurial. The development repository will prefer Git in the future. This will introduce a different system of counting patch increments after version tags. Builds from the same source release will probably have different increments and hashes, whether you got it via Mercurial or Git.
    My most recent build has the version 3.3+1-g396395b2b via Git (notice the "g" in front of the hexadecimal hash).
    x265 3.3+1-g396395b2b
  12. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.3+4-30eb4de83092
    Edge Aware Quad Tree Establishment.
    1. Terminates recursion for quadtree establishment using edge information.
    2. Adds modes for option "--rskip". Modes 0,1 for current usage and 2,3 for edge
     based recursion skip.
    3. Adds option "rskip-edge-threshold" to decide recursion skip using CU edge density.
    4. Re uses edge information when already available in encoder.
  13. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.3+7-d769bc8e8cde
    (x64, multilib, GCC 8.4.0)
    Add aarch64 support - Part 1
    This patch add some common assembly optimization function for aarch64 platform. These function won't work until the patch Part 2 is merged.
    Add aarch64 support - Part 2
    This patch adds aarch64 build & compile support. This patch must be merged after the Part 1.
    Fix: segmentation fault for hist-scenecut option
    fixes plane size calculation for chroma planes using source resolution and not padded resolution.
  14. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.3+12-00b686782ad0
    Latest changes:
    Fix: clis in regression txt file.
    1. corrects file naming convention.
    2. updates deprecated rskip clis options.
    zone: Enable strict VBV conformance for zone encode as per requirement
    - Fixes mismatch in BufferRate with dynamic zone reconfiguration when bufferrate varies for each zone
    - Logs UnclippedBufferFillFinal into csv when csvloglevel greater than 1
    Add option to get global maxrate.
    This global maxrate can be used for HRD signaling.
    zone: Remove unnessary conditions on zone reconfig
    This commit
    - Removes unnessary conditions on zone reconfig
    - Fixes crash with dynamic zone reconfig
  15. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.3+24-37916f420742
    "This commit enables CBR based QP tuning for rate-control 2 Pass and enables the signalling of CBR flag in HRD for CBR bitstreams."
    Aug 2013
    Central Germany
    x265 3.3+27-g4780a8d99 (multilib, GCC 10.1)
  17. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.4+30-g6722fce
    Changes since commit a82c6c7: https://bitbucket.org/multicoreware/x265_git/commits/all
  18. DECEASED
    Jun 2009
    Heaven
    Time flies indeed
    Yeah, many things have changed since I started this thread in 2013...
    Mr. Vaughan left MultiCoreWare, both Steve Borho and Min Chen left the x265 project, and according to one of the Doom9 moderators,
    currently x265 is considered "good enough" by the x265 devs if the answer to the question "żdoes it compile?" is «YES» :O
    Somewhat off-topic, I know, but I couldn't resist...
    Aug 2013
    Central Germany
    New uploads: x265 3.4+27-g5163c32d7 + x265 3.4+30-g6722fce1f
    CLI changes since x265 3.4+14-gd419c7152:
    • Defaults changed from undef to unknown for:
      --overscan
      --colorprim
      --colormatrix
    • New options:
         --min-vbv-fullness <double>   Minimum VBV fullness percentage to be maintained. Default 50.00
         --max-vbv-fullness <double>   Maximum VBV fullness percentage to be maintained. Default 80.00
         --[no-]vbv-live-multi-pass    Enable realtime VBV in rate control 2 pass.Default disabled
    Nov 2020
    espańa
    Originally Posted by El Heggunte View Post
    HOW TO COMPILE X265
    NEW: scripts for MultiLib builds, by LigH:
    https://forum.videohelp.com/threads/357754-%5BHEVC%5D-x265-EXE-mingw-builds?p=2431971&...=1#post2431971
    OLD:
    https://forum.videohelp.com/threads/357754-%5BHEVC%5D-x265-EXE-mingw-builds?p=2259093&...=1#post2259093
    BINARIES
    https://www.mediafire.com/?6lfp2jlygogwa --- by LigH
    http://x265.ru/en/ --- by Fllear
    http://builds.x265.eu/ --- by snowfag
    COMPLAINTS, COMPILER ERRORS & BUG REPORTS
    => x265-devel@<a class="contentlink" href="https://www.videohelp.com/software/VLC-media-p...deolan</a>.org
    Also: https://www.mail-archive.com/x265-devel@videolan.org/
    — and FWIW...
    Commits: https://bitbucket.org/multicoreware/x265/commits/all
    HI How can I Use "tsMuxerGUI" For Change Tags "video" and Replace By without copyright. you can help me Gracias
  21. --vbv-live-multi-pass, --no-vbv-live-multi-pass
    It enables the Qp tuning at frame level based on real time VBV Buffer fullness in the ratecontrol 2nd pass of multi pass mode to reduce the VBV violations. It could only be enabled with rate control stat-read encodes with VBV and ABR rate control mode.
    Default disabled. Experimental feature
    source: https://x265.readthedocs.io/en/latest/cli.html?highlight=vbv-live-multi-pass#cmdoption...ive-multi-pass
    I don't get it,.. Can someone explain that.
  22. Member
    Aug 2013
    Central Germany
    @Selur: As far as I understand, it requires multipass so that the 2nd pass can read a stats file which was written in a 1st pass, also it requires VBV limits and an ABR mode (not CRF or CQ). No more clues from me, never tried that.
    @Davisuper: I believe you are completely wrong here; this thread is only for announcing new MinGW builds of the x265 encoder (and marginally for discussing new CLI parameters). Discussions about the use of tsMuxer and GUIs don't belong here, they deserve a new separate thread. Furthermore, I see no reason for this superfluous quote.
  23. Thanks
  24. DECEASED
    Jun 2009
    Heaven
    @LigH: thanks for the polite answer, your patience surely is much greater than mine
    as for Davisuper... well, I don't know, I am paranoid and to me he smells like a sock-puppet of a certain Doom9 moderator...😱
    —therefore I just sent him to my IgnoreList 😇
  25. Member
    Aug 2013
    Central Germany
    New uploads: x265 32-g57e0b0382
    CLI changes since x265 3.4+30-g6722fce1f:
       --scenecut-aware-qp <0..3>    Enable increasing QP for frames inside the scenecut window around scenecut. Default disabled
                                     0 - Disabled
                                     1 - Forward masking
                                     2 - Backward masking
                                     3 - Bidirectional masking
       --masking-strength <string>   Comma separated values which specifies the duration and offset for the QP increment for inter-frames
    replaces
       --[no-]scenecut-aware-qp      Enable increasing QP for frames inside the scenecut window after scenecut. Default disabled
       --scenecut-window <0..1000>   QP incremental duration(in milliseconds) when scenecut-aware-qp is enabled. Default 500
       --qp-delta-ref <0..10>        QP offset to increment with base QP for inter-frames. Default 5.000000
       --qp-delta-nonref <0..10>     QP offset to increment with base QP for non-referenced inter-frames. Default 6.500000
  26. Member
    Aug 2013
    Central Germany
    Success! With the great support of Christopher Degawa, main supporter of the media-autobuild suite, I was able to tweak my workflow until I could build an x265 binary with Yuuki-Asuna mod (Asuna branch = based on v3.4-stable). It required some pkgconfig tuning and I found a way to use the "video decoders only" light ffmpeg build as already used by m-ab-s in its x264 binary (option 6); so it should contain support for AVS input, VPY input, LAVF input, MP4 output (L-SMASH), MKV output (Haali, obsolete), and ZIMG scaling.
    Consider this an experiment. No guarantee to be repeated.
    x265 3.4-Asuna+54
    x265 [info]: HEVC encoder version 3.4+-+54
    x265 [info]: build info [Windows][GCC 10.2.0][64 bit] Asuna 8bit+10bit+12bit
    x265 [info]: (lsmash 2.16.1)
    x265 [info]: (libavformat 58.65.101)
    x265 [info]: (libavcodec  58.117.101)
    x265 [info]: (libavutil   56.63.101)
  27. Member
    Aug 2013
    Central Germany
    Update with correct version numbering
    x265 3.4+13-g729a838d3+41 (Asuna)
    x265 [info]: HEVC encoder version 3.4+13-g729a838d3+41
  28. For the unknowing: What does "Yuuki-Asuna mod" do / is intended to do?
  29. Member
    Aug 2013
    Central Germany
    Most of all:
    Also some tuning in the output format of the debug info and statistics, I believe. github repo
  30. Ah okay, thanks.
