You should abandon x26*vfw, and you should abandon the belief that the AVI container is suitable to contain AVC or HEVC video.
If you insist in using VirtualDub as converter application, use it with its "external encoder" feature, this will support any x265.exe to create raw HEVC video, and a multiplexer like MP4Box, L-SMASH, or mkvmerge.
Results 2,041 to 2,070 of 2222
Ligh,
so if I choose to abandon x26*vfw what road do you recommend me travel down? I am not the smartest person when it comes to encoding, but i am a little familiar with the apps and lingo. I know this is opening padora's box, but I am up to getting up to speed on a newer method as I have encoded over 8TBs of movies -
x265 2.2+22-20217c8af8ac
Scalinglists support for 4:4:4 videos + fixes for ssim-rd and others -
I'm not noticing any quality increases since like 1.8. The speed has gotten slower for what exactly? Picture is the same.
This is not the best matching thread for this kind of question. Try the general one or make a new one. And document your parameters in detail.
x265 2.2+30-fa52b516f5ff
Code:--complex-analysis <0..4.0> Strength of complex analysis, 0 to disable. Default 0.0
A developers' functionality test runs with strength 1.53, FYI.Increases the RD-level at points where the bitrate drops due to vbv. The number of CUs for which the RD is reconfigured is determined based on the strength. Strength 1 gives the best FPS, strength 4 gives the best SSIM. Strength 0 switches this feature off. Default: 0.
Effective for RD levels 4 and below.Last edited by LigH.de; 31st Jan 2017 at 05:45. Reason: v2.2+29 revoked in favor of v2.2+30
x265 2.2+36-9b975fec584a
--complex-analysis is now --dynamic-rd, and you can now manually control HDR SEI packets
Exchanged v2.2+35 with v2.2+36, it's a "merge with stable"Last edited by LigH.de; 10th Feb 2017 at 17:54.
New milestone (stable merge build): x265 v2.3
x265 2.3+2-912dd749bdb5 (mostly identical to v2.2+36) -
x265 2.3+7-c15f8bce9f4b [Windows][GCC 6.3.0][32+64 bit] 8bit+10bit+12bit
Luma/Chroma(fixed) offsets for HDR/WCG content, and some more Unicode support for filenames in Windows builds. New CLI parameters:
Code:--capture-csp <string> Specify color primaries from bt709, p3d65, bt2020 for the capture device. Default bt709 --[no-]hdr-opt Add luma and chroma offsets for HDR/WCG content. Default disabled
x265 2.3+17-6e348252e902
Now even finer!
^typo (analy»s«is) already reported...Code:--refine-level <1..10> Level of analyis refinement indicates amount of info stored/reused in save/load mode, 1:least....10:most. Default 5
Not available anymore:
Why should there be?
Looking at the change log:
- multi-level refinement: fix typo and missing space => only useful to codec developers
- regression: include test for refine levels => only useful to codec developers
- multi-level: increase maximum level from 5 to 10 => only useful to codec developers
=> nothing happened that is useful to a normal user (most of last few changes were mainly for codec developers&co)users currently on my ignore list: deadrats, Stears555, marcorocchini -
OK then, I've just seen there was a new version here: https://www.videohelp.com/software/x265-Encoder
But I prefer all-in-one (8 bits to 12 bits) GCC builds as they are faster, at least on my system. -
I build new versions only when features change. Not just when a typo got fixed or only the documentation got enhanced (that does not change the code at all, only increases the patch number).
AnonymousGuest
x265.exe 2.3+22-db5e22b856f5
(GCC 6.3.0, 64-bit, multilib)Last edited by Marsia Mariner; 14th Mar 2017 at 11:00. Reason: edit
AnonymousGuest
x265.exe 2.3+28-08a05ca9fd16
(GCC 6.3.0, x64, multilib)
Fix artifacts issue in multi-pass-opt-distortion with VBV -
AnonymousGuest
deleted Deleted DELETED
}}Last edited by Marsia Mariner; 8th Apr 2017 at 01:11.
CLI: informs if '--ssim-rd' is used;
Add dynamic rate-control reconfiguration (API only);
Improved sao implementation by limiting sao types:
x265 2.3+32-1ed218717877Code:--[no-]limit-sao Limit Sample Adaptive Offset types. Default disabled
x265 2.3+28-08a05ca9fd16 (belated) -
AnonymousGuest
x265.exe 2.3+40-2c6e6c9c3da7
http://www.mediafire.com/file/iymx3l6rjmyttv4/x265_2.3+40-2c6e6c9c3da7.7zCode:Merge with default, prep for 2.4
I tried to enable Dynamic HDR10 routines for compilation with GCC 6.3.0, but C++11 compatibility is missing in the current CMake scripts. Release postponed...
AnonymousGuest
^ The HDR10+ stuff seems to be very-useless for the time being...
And as LigH pointed out, it was not implemented correctly.
It's disabled by default in the main CMakeLists.txt.
For the "normal" users of x265, the new 10-bit and 12-bit lambda2 table is more relevant than the (non-existent) HDR10+ support.Last edited by Marsia Mariner; 20th Apr 2017 at 11:34. Reason: :-/
The long awaited:
x265 2.4+6-fd01abfc7898 (merge with stable) contains an additional multi-lib EXE with Dynamic HDR10 enabled. -
AnonymousGuest
x265.exe 2.4+14-bc0e9bd7c08f
https://bitbucket.org/multicoreware/x265/commits/all -
AnonymousGuest
x265.exe 2.4+22-c102c809fc4f
x265 2.4+22-c102c809fc4f
adds CTUInfo API (seems to be a debug feature, quite time consuming) and an AVX2 framework of integral functions to speed up SEA motion search.
help - how to compile latest "nightly" ffmpeg for win32 (XP) with mingw
By hydra3333 in forum ProgrammingReplies: 32Last Post: 20th May 2017, 01:33 -
x265 vs x264
By deadrats in forum Video ConversionReplies: 71Last Post: 10th Jan 2016, 07:14 -
ffdcaenc (an upgrade to dcaenc)
By El Heggunte in forum AudioReplies: 22Last Post: 9th Dec 2014, 07:09 -
MulticoreWare Annouces x265/HEVC Mission Statement
By enim in forum Latest Video NewsReplies: 4Last Post: 9th Aug 2013, 23:09 -
New PC Build(s)
By thedeificone in forum ComputerReplies: 6Last Post: 25th May 2010, 17:57
Netscape Navigator?!
