commit 36a8f03e2ac0
Latest changes:
cli: add option to support limit-TU and newer
@ https://bitbucket.org/multicoreware/x265/commits/all
Results 2,011 to 2,040 of 2222
x265 2.1+20-c64393b415ad (GCC 5.3.0)
x265 2.1+20-c64393b415ad (GCC 6.2.0)
CLI changes since v2.1+2:
^ The small syntax typo will surely be corrected soon... ([no-]... instead of [no]-...).Code:+ --limit-tu <integer> Enable early exit from TU recursion for inter coded blocks. Default 0 - --discard-sei Discard SEI packets in bitstream. Default disabled - --discard-vui Discard optional VUI information from the bistream. Default disabled + --[no]-vui-timing-info Discard optional VUI timing information from the bistream. Default enabled + --[no]-vui-hrd-info Discard optional HRD timing information from the bistream. Default enabled
The new option --limit-tu sounds interesting to me; I wonder how much speed gain will be possible without a noticable additional loss of quality.
__
P.S.: Don't try --limit-tu >2.
In a very brief test with a small video, the results were bit-identical, and no certain speed increase. So I guess an advantage requires specific situations.Code:Invalid limit-tu option, limit-TU must be 0, 1 or 2
can someone please explain the GCC compiled versions that are included in these files and why someone would download a given one?
example, I'm on a dell inspiron laptop, intel i3 processor, win 7 home prem 64bit from 2010
last reported capability of this laptop from x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
and, which one should I download for the windows xp home OS, on a desktop pc, Amd dual core cpu from 2010 or earlier? -
Regarding my archives:
You will probably prefer the GCC 6.2.0 builds. I added the GCC 5.3.0 builds only for the case someone wants to check compatibility issues the new compiler generation might have introduced due to more aggressive optimizations (but chances are low already that such bugs are still missed).
My Win32 builds may work on Windows XP, but I don't guarantee, I don't have any more installation. At least I compiled with required flags, I guess... For Windows 7 in a 64-bit version, no matter how expensive, you can use the Win64 builds.
In each case, you will probably just use the x265_ml.exe (multi-library EXE with included 8-bit, 10-bit, and 12-bit precision routines). All other files are only for rare cases when someone rather needs the separate DLLs, and maybe one of the single precision EXE's.
I did not optimize my builds for more complex instruction sets as minimum requirement. The assembler routines in x265 will probably be used from SSE2 on (all 64-bit CPUs should support that, including Athlon64), and the C routines minimum may be MMX, I guess. Win32 builds with 10 or 12 bit precision don't have assembler routines, as known for a long time already, so use only 8 bit precision for Win32 (in this case, Win32\x265_main.exe is enough).Last edited by LigH.de; 11th Oct 2016 at 10:16.
x265 v2.1+22-c97805dad914, compiled by Barough@doom9.forum
http://www117.zippyshare.com/v/5kpmu8gP/file.html -
commit 0e9e52640546
Code:limitTU: fix energy calculation used in limiting TU recursion
New CLI options:
GCC 6.2.0 only is sufficient from now on.Code:--[no-]opt-qp-pps Discard optional HRD timing information from the bistream. Default enabled --[no-]opt-ref-list-length-pps Discard optional HRD timing information from the bistream. Default enabled
x265 2.1+25-0e9e52640546 -
commit bc911034c2a0
µChangeLog
Code:Store commonly-used RPS in SPS in 2 pass mode. Add new param --[no]-multi-pass-opt-rps to control it, default disabled. slicetype: Add bias used in scenecut detection as param option. test: Add multi-pass-opt-rps test to 2-pass rate control tests
commit d216cb9b3b47
changelog: (aaaaargh!) @ https://bitbucket.org/multicoreware/x265/commits/all -
Me too:
x265 2.1+36-d216cb9b3b47 (MSYS/MinGW, GCC 6.2.0, 32 + 64 bit, 8+10+12 bit single EXE + DLL and multi-lib EXE)
More advanced options:
Code:--[no-]opt-qp-pps Discard optional HRD timing information from the bistream. Default enabled --[no-]opt-ref-list-length-pps Discard optional HRD timing information from the bistream. Default enabled --[no-]multi-pass-opt-rps Enable storing commonly RPS in SPS in multi pass mode. Default disabled
AnonymousGuest
commit 67e980e22c43
changelog: https://bitbucket.org/multicoreware/x265/commits/all -
AnonymousGuest
commit a895b6344a82
Code:limitTU : modify condition for limitTU 1 and 2 limitTU : use spatial and temporal CUs' TU depth to limit recursion limitTU : use neighbouring CUs' TU depth to limit 1st subTU's depth tests: update command lines to cover limitTU 3 and 4
x265 2.1+59-a895b6344a82
CLI changes:
Code:(new) --scenecut-bias <0..100.0> Bias for scenecut detection. Default 5.00 (changed descr.) --[no-]vui-timing-info Emit VUI timing information in the bistream. Default enabled --[no-]vui-hrd-info Emit VUI HRD information in the bistream. Default enabled --[no-]opt-qp-pps Dynamically optimize QP in PPS (instead of default 26) based on QPs in previous GOP. Default enabled --[no-]opt-ref-list-length-pps Dynamically set L0 and L1 ref list length in PPS (instead of default 0) based on values in last GOP. Default enabled
AnonymousGuest
commit df25adaa30f6
NOTICE: from this day on, no more 32-bit builds of x265.exe from me, sorry.Code:fix logic timing bug
For CPU-hungry tasks like HEVC compression, 64-bits is the way to go. -
AnonymousGuest
commit 5d95fbd53ca3
Code:doc: Improve rst doc and help doc about param multi-pass-opt-rps Fix source width and height in info
AnonymousGuest
commit 5ae077d7053d
SEA motion search Implementation 0_o
https://bitbucket.org/multicoreware/x265/commits/5ae077d7053d76a036d50fd426996cc2e2d3c565 -
AnonymousGuest
commit b2d360143d96
Code:Warn no support of pme and pmode in SEA motion search regression: add pme option in regression commandlines
AnonymousGuest
commit c97c64ab8b8e
µchangelog
csv: modify csv api
SEA motion search: Copy integral planes for ANALYSIS LOAD
rc: frameSizePlanned is calculated from the predictors for vbv case -
x265 2.1+69-c97c64ab8b8e
As mentioned above: SEA motion search implemented, several fixes and optimizations in addition. -
x265 2.1+70-78e1e1354a25 – "merge with stable" build; prepare for v2.2 "soon™"!
AnonymousGuest
commit e8152da7aa0e
Code:Set up separate threadpool for lookahead The user can allocate specific number of threads for lookahead by specifying --lookahead-threads <val>, creating a separate lookahead pool for these threads. This will improve performance when lookahead becomes a bottle neck. The threads for lookahead must be ideally less than half the total number of available worker threads. Aarthi Thirumalai
And just for the record.., there is a slight fps increase in encoding speed. I was sure I saw at most 3 fps, using --preset fast. I assume speed is effective in certain presets, and fps rate will vary per user encoding criteria. In comparing against 2.1.63, I believe the speed had increase starting with 2.1.70 and on..
Also, as I commented in another thread, the quality (image detail) has improved. -
New "merge with stable milestone" build:
x265 2.2+2-998d4520d1cf -
x265 2.2+15-a18ab7656c30
Speedups in multipass encoding (reusing of more 1st-pass data); SSIM based RDO for mode selection; and some bugfixes. -
Good day,
I have been using x264VFW for years with VD, but now i would like to give x265VFW a shot. I downloaded x265vfw_x64_v120_x265b80_20160129.exe and installed it on win 10, just like my x264VFW file, but when i go to the compression window, I do not see the x265VFW codec. Will your file resolve this issue? How can I get a x265VFW to show up in my "video Compression" window in VD
help - how to compile latest "nightly" ffmpeg for win32 (XP) with mingw
By hydra3333 in forum ProgrammingReplies: 32Last Post: 20th May 2017, 01:33 -
x265 vs x264
By deadrats in forum Video ConversionReplies: 71Last Post: 10th Jan 2016, 07:14 -
ffdcaenc (an upgrade to dcaenc)
By El Heggunte in forum AudioReplies: 22Last Post: 9th Dec 2014, 07:09 -
MulticoreWare Annouces x265/HEVC Mission Statement
By enim in forum Latest Video NewsReplies: 4Last Post: 9th Aug 2013, 23:09 -
New PC Build(s)
By thedeificone in forum ComputerReplies: 6Last Post: 25th May 2010, 17:57
