Totally missed that, thanks.![]()
Results 1,801 to 1,830 of 2222
Out-of-schedule, here are some additional builds, experimenting with jb_alvarado's media-autobuild_suite.
x265_1.5+420-24fdb661bb57.7z (MSYS, MinGW32, GCC 4.8.2, package from xhmikosr + 4x cross compile script, EXE+DLL)
x265_1.5+420-24fdb661bb57.GCC492.7z (MSYS2, MinGW64, GCC 4.9.2, media-autobuild_suite, EXE only, stripped and UPX'ed) -
Another weekly, stable merge build.
x265 1.5+448-22a312799bb0 (GCC 4.8.2 EXE + DLL)
x265 1.5+448-22a312799bb0 (GCC 4.9.2 UPX-EXE)
It seems that the x265 project will allow easier configuring for native architecture optimized builds. If I would enable this feature, my builds would probably still be generated for SSE2 or SSE3, using AMD K10 architecture (Phenom-II). I did not yet change my workflow. -
Belated Happy Easter:
x265 1.6+85-e0523096bb21 (stable merge)
x265 1.6+117-095ed87526e5 (with "implementation of fine grained adaptive quantization")
Furthermore, some spring-cleaning (removing v1.3 archives).
__
P.S.: trying to add --qgsize 16 to the parameter set, I get only a syntax help page as error result, instead of an encode.
P.P.S.: My fault, insert another hyphen: --qg-sizeLast edited by LigH.de; 7th Apr 2015 at 07:13.
x265 1.6+174-4cccf22b00ee
Supports a switch for the "Annex B" format internally, which may be interesting for builds supporting already multiplexed outputs. Raw HEVC video shall always be formatted according to Annex B, I was told.
Coming builds may require a decision to be either compatible to Vista without — or to Win7+ with support for NUMA thread pools. May my Win32 builds be XP compatible (and without much use for multi-socket encoding anyway), but my Win64 builds will then probably prefer Win7+ compatibility with NUMA support. -
x265 1.6+239-5c3443546ccc
News: Support for SMPTE ST 2086 (HDR / Wide Gamut display metadata) and piping reconstructed video to a Y4M viewer. -
x265 1.6+298-4a7176bab742
New published parameter:
Code:--qpstep <integer> The maximum single adjustment in QP allowed to rate control. Default 4
@LigH: did you do anything specific to make your 32bit builds Windows XP compatible? see: https://github.com/jb-alvarado/media-autobuild_suite/issues/85
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Nothing special. GCC 4.8.2 in MSYS package prepared by XhmikosR.
~/rebuild_x265.sh
Code:#!/bin/sh cd x265/build/msys make clean-generated cmake -G "MSYS Makefiles" -DWINXP_SUPPORT:BOOL=TRUE ../../source make /mingw/bin/strip.exe x265.exe /mingw/bin/strip.exe libx265.dll cd ../msys_hbd make clean-generated cmake -G "MSYS Makefiles" -DWINXP_SUPPORT:BOOL=TRUE -DHIGH_BIT_DEPTH:BOOL=TRUE -DENABLE_ASSEMBLY:BOOL=FALSE ../../source make /mingw/bin/strip.exe x265.exe /mingw/bin/strip.exe libx265.dll cd ../msys64 make clean-generated cmake -G "MSYS Makefiles" -DCMAKE_TOOLCHAIN_FILE=toolchain-x86_64-w64-mingw32.cmake ../../source make /mingw/x86_64-w64-mingw32/bin/strip.exe x265.exe /mingw/x86_64-w64-mingw32/bin/strip.exe libx265.dll cd ../msys64_hbd make clean-generated cmake -G "MSYS Makefiles" -DCMAKE_TOOLCHAIN_FILE=toolchain-x86_64-w64-mingw32.cmake -DHIGH_BIT_DEPTH:BOOL=TRUE ../../source make /mingw/x86_64-w64-mingw32/bin/strip.exe x265.exe /mingw/x86_64-w64-mingw32/bin/strip.exe libx265.dll
A new "merge with stable" to prepare a coming v1.7 era: x265 1.6+412-b642b3d8cc1e
Also support for "content light level" (HDR SEI info). -
btw. has anyone tried the patched builds from VTT ?
- Patch to enable high bit depth for 32-bit target
- Patch that adds missing aligment declaration
see: http://vtt.to/refined%20x265%20buildsusers currently on my ignore list: deadrats, Stears555, marcorocchini -
If these alignment declarations are generally useful, this patch should have been offered to the main repository.
x265 1.6+417-f2081ef64fd2 publishes a switch to select the output (and internal) bit depth at run time:
Default depth depends on the compile options.Code:-D/--output-depth 8|10 Output bit depth (also internal bit depth). Default {8|10}
Now I wonder: If a 64 bit executable should support both 8 and 10 bit depths, shouldn't the building process create "more or less identical" binaries containing both code groups, so that switching between 8 and 10 bit depths at run time is at all possible? But normal and HBD builds still differ (DLLs as well as EXEs). I doubt this works as desired (but not tested yet...).
This package has also DETAILED_CU_STATS enabled.
__
P.S.: The documentation reads like it doesn't have to. If a specific depth is unsupported (because not linked in), it seems to fall back to a supported one. I guess that a dynamic EXE linking both 8 and 10 bit DLLs would be an easier way to make a CLI encoder supporting both at run time?Last edited by LigH.de; 12th May 2015 at 04:58.
The -D switch allows you to build a High Bit Depth DLL, calling it libx265_main10.dll and placing it alongside your 8 bit x265.exe. With this "package" the x265 command line interface can dynamically choose either Main or Main10 profiles (if you add "-D 10" to your command line), and it will use either the 8 bit library (built into x265.exe), or the high bit depth build (in the DLL).
On the occasion of the new milestone:
x265 1.7+2-d7b100e51e82
Please note: Contains different file names, starting with v1.7, to be more easily compliant with the new Multi-library Interface.
__
P.S.: Additional MSYS2-64 GCC 4.9.2 build, each one pair only (8-bit EXE + 10-bit DLL), as built with media-autobuild_suite by jb_alvaradoLast edited by LigH.de; 19th May 2015 at 11:18.
Must have forgotten the last one. So today, two releases.
x265 1.7+37-dc4fcfc574ad
—Last edited by LigH.de; 3rd Jun 2015 at 05:29.
x265 1.7+95 removed in favour of 1.7+96:
x265 1.7+96-093618ce0b26api: fix for crash in x265_api_query caused by function type casting error
In x265_api_query, after retrieving the function pointer of x265_api_query from external DLL, it is then incorrectly type cast into x265_api_get function, the patch is intended for this fix.Last edited by LigH.de; 3rd Jun 2015 at 05:35.
Current builds appear to be really a lot bigger, especially 16bpp binaries (EXE: 3.3 => 4.6 MB; DLL: 2.9 => 4.1 MB; each about +1.2 MB). Furthermore, the "full help" output shrunk to 70% of its previous amount.
x265 1.7+166-32590b25678b
P.S.: Compressed with 7-zip 15.05 beta; please check if you can unpack even with slightly older versions (but min. 9.20 beta).Last edited by LigH.de; 15th Jun 2015 at 04:39.
Weekly (with a just even fixed typo in the XP compatible X265 Name Space refactoring):
x265 1.7+207-83a7d8244424 -
A first release with "multilib" EXE: x265 1.7+234-b1af4c36f48a
"Merge with stable" and working CPU features identification for alternative encoder libraries (i.e. -D 10 -V warns about "noasm" option for Win32 builds in multilib EXE as well as 8-bit EXE with 10-bit DLL):
x265 1.7+266-68d089360477 (GCC 4.8.2)
x265 1.7+266-68d089360477 (GCC 4.9.2) -
WARNING! HIGHLY EXPERIMENTAL!
x265 1.7+282-1867f1703846 (GCC 4.9.2) containing separate EXE and DLL files as well as a multilib EXE (possible by manually patching listfile.rsp) with 8 bit + 10 bit + 12 bit encoder
In addition, some new samples with a downscaled "L4D2 Fireworks" clip (640x360) in 8 / 10 / 12 bit encoding resolution.
LAV Filters can't play the 12 bit sample correctly. I guess it is not yet supported? -
afaik no decoder supports 12bit atm. (same for 16 bit), so to compare these you probably will have to output a y4m file.LAV Filters can't play the 12 bit sample correctly. I guess it is not yet supported?users currently on my ignore list: deadrats, Stears555, marcorocchini
help - how to compile latest "nightly" ffmpeg for win32 (XP) with mingw
By hydra3333 in forum ProgrammingReplies: 32Last Post: 20th May 2017, 01:33 -
x265 vs x264
By deadrats in forum Video ConversionReplies: 71Last Post: 10th Jan 2016, 07:14 -
ffdcaenc (an upgrade to dcaenc)
By El Heggunte in forum AudioReplies: 22Last Post: 9th Dec 2014, 07:09 -
MulticoreWare Annouces x265/HEVC Mission Statement
By enim in forum Latest Video NewsReplies: 4Last Post: 9th Aug 2013, 23:09 -
New PC Build(s)
By thedeificone in forum ComputerReplies: 6Last Post: 25th May 2010, 17:57
