Results 1,291 to 1,320 of 2222
finished after 00:02:14.145 (icl14)
finished after 00:06:43.569 (msvc2012)
low-encoding presets looks nicer than at high (reasonable motivation)Last edited by Gravitator; 6th Mar 2014 at 01:26.
@marchand: are these your own builds or are you just uploading the builds of someone else?
@Graviator: thanks for testing -
With this direction > http://chromashift.org/x265_builds/
tried to reproduce your result:
Code:"g:\Hybrid\mencoder.exe" -lavdopts threads=8 -really-quiet -of rawvideo -o - -ovc raw -demuxer lavf -vfm ffmpeg -noskip -vf scale,format=i420 -forcedsubsonly -nosub -nosound -mc 0 "F:\TESTCL~1\test.avi" | x265_msvc2012 --input - --input-res 640x352 --fps 25 --frames 429 --colormatrix bt470bg --output "H:\Temp\test_07_51_12_3910_01.265" yuv [info]: 640x352 fps 25000/1000 i420 unknown frame count x265 [info]: HEVC encoder version 0.8+17-91936aab5ae9 x265 [info]: build info [Windows][MSVC 1700][64 bit] 8bpp x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX AVX2 FMA3 LZCNT BMI2 x265 [info]: Main profile, Level-2.1 (Main tier) x265 [info]: WPP streams / pool / frames : 6 / 8 / 3 x265 [info]: CU size : 64 x265 [info]: Max RQT depth inter / intra : 1 / 1 x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 2 x265 [info]: Keyframe min / max / scenecut : 25 / 250 / 40 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / refs : 1 / 1 / 3 x265 [info]: Rate Control / AQ-Strength / CUTree : CRF-28.0 / 1.0 / 1 x265 [info]: tools: rect amp rd=3 lft sao-lcu sign-hide x265 [info]: frame I: 3 Avg QP:25.89 kb/s: 1111.47 x265 [info]: frame P: 139 Avg QP:28.07 kb/s: 197.14 x265 [info]: frame B: 287 Avg QP:30.44 kb/s: 35.94 x265 [info]: global : 429 Avg QP:29.64 kb/s: 95.70 x265 [info]: 2 of 139 (1.44%) P frames weighted x265 [info]: consecutive B-frames: 2.1% 0.7% 91.5% 4.2% 1.4% encoded 429 frames in 13.95s (30.75 fps), 95.70 kb/s
-> that is a huge difference!Code:"g:\Hybrid\mencoder.exe" -lavdopts threads=8 -really-quiet -of rawvideo -o - -ovc raw -demuxer lavf -vfm ffmpeg -noskip -vf scale,format=i420 -forcedsubsonly -nosub -nosound -mc 0 "F:\TESTCL~1\test.avi" | x265_icl --input - --input-res 640x352 --fps 25 --frames 429 --colormatrix bt470bg --output"H:\Temp\test_07_51_12_3910_01.265" yuv [info]: 640x352 fps 25000/1000 i420 unknown frame count x265 [info]: HEVC encoder version 0.8+17-91936aab5ae9 x265 [info]: build info [Windows][ICC 1400][64 bit] 8bpp x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX AVX2 FMA3 LZCNT BMI2 x265 [info]: Main profile, Level-2.1 (Main tier) x265 [info]: WPP streams / pool / frames : 6 / 8 / 3 x265 [info]: CU size : 64 x265 [info]: Max RQT depth inter / intra : 1 / 1 x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 2 x265 [info]: Keyframe min / max / scenecut : 25 / 250 / 40 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / refs : 1 / 1 / 3 x265 [info]: Rate Control / AQ-Strength / CUTree : CRF-28.0 / 1.0 / 1 x265 [info]: tools: rect amp rd=3 lft sao-lcu sign-hide x265 [info]: frame I: 3 Avg QP:25.89 kb/s: 1111.47 x265 [info]: frame P: 139 Avg QP:28.07 kb/s: 197.16 x265 [info]: frame B: 287 Avg QP:30.44 kb/s: 35.94 x265 [info]: global : 429 Avg QP:29.64 kb/s: 95.70 x265 [info]: 2 of 139 (1.44%) P frames weighted x265 [info]: consecutive B-frames: 2.1% 0.7% 91.5% 4.2% 1.4% encoded 429 frames in 7.69s (55.78 fps), 95.70 kb/s
For better comparision I compiled a MinGW64 build and tried it:
-> seems like only the msvc builds are that slowCode:"g:\Hybrid\mencoder.exe" -lavdopts threads=8 -really-quiet -of rawvideo -o - -ovc raw -demuxer lavf -vfm ffmpeg -noskip -vf scale,format=i420 -forceds ubsonly -nosub -nosound -mc 0 "F:\TESTCL~1\test.avi" | x265 --input - --input-res 640x352 --fps 25 --frames 429 --colormatrix bt470bg --output "H:\Temp\test_07_51_12_3910_01.265" yuv [info]: 640x352 fps 25000/1000 i420 unknown frame count x265 [info]: HEVC encoder version 0.8+40-889edfd2c4c3 x265 [info]: build info [Windows][GCC 4.8.2][64 bit] 8bpp x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX AVX2 FMA3 LZ CNT BMI2 x265 [info]: Main profile, Level-2.1 (Main tier) x265 [info]: WPP streams / pool / frames : 6 / 8 / 3 x265 [info]: CU size : 64 x265 [info]: Max RQT depth inter / intra : 1 / 1 x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 2 x265 [info]: Keyframe min / max / scenecut : 25 / 250 / 40 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / refs : 1 / 1 / 3 x265 [info]: Rate Control / AQ-Strength / CUTree : CRF-28.0 / 1.0 / 1 x265 [info]: tools: rect amp rd=3 lft sao-lcu sign-hide x265 [info]: frame I: 3 Avg QP:25.89 kb/s: 1111.47 x265 [info]: frame P: 139 Avg QP:28.07 kb/s: 197.14 x265 [info]: frame B: 287 Avg QP:30.44 kb/s: 35.94 x265 [info]: global : 429 Avg QP:29.64 kb/s: 95.70 x265 [info]: 2 of 139 (1.44%) P frames weighted x265 [info]: consecutive B-frames: 2.1% 0.7% 91.5% 4.2% 1.4% encoded 429 frames in 7.59s (56.51 fps), 95.70 kb/s
@Marchand: if you compile the builds yourself you might want to look into your MSVC compilation settings, the difference in speed seems to be too much to be just a compiler change. (my guess: the msvc version is compiled in debug and not release mode. -
probably the same, MinGW64&ICL14 should be the same speed and the MSVC builds Marchand uploaded here will be a lot slower.
Anybody have a 32bit version of 0.8+40-889edfd2c4c3 ? I can't find a good download. The Russian guy doesn't have one and the european guy's downloads seem to be corrupt. 6kb files.
Curious to check out speed difference. -
thanks selur, was having issues with the msvc/icl builds jus stopping about 3/4 of the
way thru an encode
so went back 2 the build u posted on the 4th 0.7+388 and was fine.
---[Information] [3/6/2014 1:53:41 AM] yuv [info]: 720x384 fps 24000/1001 i420 unknown frame count
---[Information] [3/6/2014 1:53:41 AM] x265 [info]: HEVC encoder version 0.8+17-91936aab5ae9
---[Information] [3/6/2014 1:53:41 AM] x265 [info]: build info [Windows][ICC 1400][64 bit] 8bpp
---[Information] [3/6/2014 1:53:41 AM] x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
---[Information] [3/6/2014 1:53:41 AM] x265 [info]: Main profile, Level-3 (Main tier)
---[Information] [3/6/2014 1:53:41 AM] x265 [info]: WPP streams / pool / frames : 12 / 8 / 3
---[Information] [3/6/2014 1:53:41 AM] x265 [info]: CU size : 32
---[Information] [3/6/2014 1:53:41 AM] x265 [info]: Max RQT depth inter / intra : 1 / 1
---[Information] [3/6/2014 1:53:41 AM] x265 [info]: ME / range / subpel / merge : hex / 44 / 1 / 2
---[Information] [3/6/2014 1:53:41 AM] x265 [info]: Keyframe min / max / scenecut : 23 / 250 / 40
---[Information] [3/6/2014 1:53:41 AM] x265 [info]: Lookahead / bframes / badapt : 10 / 4 / 0
---[Information] [3/6/2014 1:53:41 AM] x265 [info]: b-pyramid / weightp / refs : 1 / 0 / 1
---[Information] [3/6/2014 1:53:41 AM] x265 [info]: Rate Control / AQ-Strength / CUTree : ABR-1400 kbps / 0.0 / 0
---[Information] [3/6/2014 1:53:41 AM] x265 [info]: tools: cfm esd rd=3 lft sao-lcu sign-hide
---[Information] [3/6/2014 3:54:45 AM] Assertion failed: cu->getSlice()->getNumRefIdx(refListIdx) > 0, file C:\msys\1.0\devel\x\x265\source\Lib\TLibEncoder\TE ncEntropy.cpp, line 486
---[Information] [3/6/2014 3:54:54 AM] avs [info]: Avisynth 2.6+ detected, forcing conversion to YV12
---[Error] [3/6/2014 3:54:54 AM] avs [error]: Error occurred while writing frame 122800
---[Information] [3/6/2014 3:54:54 AM] (Maybe x265.exe closed)
--[Error] [3/6/2014 3:54:55 AM] Process exits with error: 3 -
Speed seems to be almost identical from 0.7+388-3cbde0b893e3 and 0.8+40-889edfd2c4c3
0.7+388-3cbde0b893e3 encoded 675 frames in 58.03s (11.63 fps), 120.07 kb/s
0.8+40-889edfd2c4c3 encoded 675 frames in 57.50s (11.74 fps), 120.07 kb/s -
Built: 2014/Mar/10 - Version: 0.8+61-50d7910ddd61 - Hevc Video Encoder (32 and 64Bit)
Built: 2014/Mar/11 - Version: 0.8+90-2014-03-11 - Hevc Video Encoder (32 and 64Bit)
x265-0.8.90-highbitdepth-icl14.0-64.7z 2014-Mar-11 14:12:36 - 806.5K
x265-0.8.90-highbitdepth-msvc2012-64.7z 2014-Mar-11 14:15:39 - 397.9K
x265-0.8.90-icl14.0-64.7z 2014-Mar-11 14:09:49 - 852.9K
x265-0.8.90-msvc2012-64.7z 2014-Mar-11 14:14:14 - 442.2K
x265-0.8.131-highbitdepth-icl14.0-642014-Mar-14
x265-0.8.131-highbitdepth-msvc2012-642014-Mar-14
x265-0.8.131-icl14.0-642014-Mar-14
x265-0.8.131-msvc2012-642014-Mar-14
x265-0.8.136-highbitdepth-icl14.0-64 2014-Mar-15
x265-0.8.136-highbitdepth-msvc2012-64 2014-Mar-15
x265-0.8.136-icl14.0-64 2014-Mar-15
x265-0.8.136-msvc2012-64 2014-Mar-15
x265-0.8.161-highbitdepth-icl14.0-64 2014-Mar-18
x265-0.8.161-highbitdepth-msvc2012-64 2014-Mar-18
x265-0.8.161-icl14.0-64 2014-Mar-18
x265-0.8.161-msvc2012-64 2014-Mar-18
can someone tell me what I need to get all these builds without XP support to work? I've installed Visual Studio 2013 but still get the message that x265.exe is not a win32 application (and no, I'm not trying to run 64bit builds). Selur and the Russian guy are the only ones that work and the Russian guy seems way behind in his builds.
^ Latest LAV Filters are compiled with VS 2013, and yes, they do work under Windows XP =^.^=
EDIT: if Selur means "VS 2013 does not install on Windows XP", then he is right
The error message "is not a Win32 application" seems to be not a sign of a missing runtime library, but a sign of a different EXE header. So I guess that there are EXE files for Vista+ which use a different kind of memory management or EXE image layout.
Sometimes I build with GCC (probably like Selur), and here it may just be a matter of checking one box in the CMakeGUI. I don't know what it takes to build an XP compatible EXE with VS 2013, but they do exist, and a Windows XP compatible Redistributable installer exists too; I had such an issue with L-SMASH Works for AviSynth, the MSVCR120.DLL included with it did not work under XP, but installing the runtime helped.
__
P.S.: Uploaded v0.8+131-ed48f84e541b (Win32 version should be XP compatible, please try).Last edited by LigH.de; 14th Mar 2014 at 13:54.
Works for me, Thanks! Should probably list your builds on the front page. The Russian Guy's work but he's a week or two behind. The Europe guy's never work even though he posts 32bit builds. Kinda useless posting 32bit builds if they don't work on XP since any newer OS should be 64bit.
My last encode using the build posted above was 12.77 fps. This may be my fastest encode using x265. I've had spikes 13 fps and higher but average fps were 10 or 11 fps. Every fps you can squeeze out of this encoder is helpful. -
The list is not in ascending order (you can skip the build)
the quality gets better (good allocates dark contours in 10bit)
now I preferred to look at x265 instead of x264!
Congratulations
Well, it looks like I ran into my first instance of my hardware not being up to snuff. Not enough memory to encode a video with a higher resolution than 3200x1800 with the x265 encoder. I guess it might be the x265 encoder since I can encode the files with either DivX265 or DivXEngine.
You are correct, there exists a problem in x265. I attempted to encode a 5616x3744 picture,
and x265 said "it couldn't find input file -" or something
OTOH, kvazaar.exe didn't complain about the huge width and height, and the HM11 reference decoder found no errors in the output file.
UPDATE:
this time, tested raw input (i.e., no y4m) with x265, BUT the actual encoding never starts --- and the final result is a zero-byte file
Last edited by El Heggunte; 16th Mar 2014 at 05:01. Reason: update info, add sample file, correct myself : - /
Tried to encode 5334x3000 with DivXEngine and although it encoded with no errors, it re-sized the video to 3840x2160. Took just under 20 minutes to encode a 36 second 863 frame file. The picture looks really good at that resolution though
Wished I had a huge TV to watch them on.
FWIW --- I reported the problem above to the x265 mailing list, a couple of minutes ago
Last edited by El Heggunte; 16th Mar 2014 at 00:17. Reason: my English suxxx : - /
Your picture would look good on a nine foot TV. I hear ya about the money thing. I'd like to build a better computer. My brother might move back here this summer which would allow me to save some money (I'm on disability) or I could just use his computer which we built a couple of years ago.
HEVC is supposed to support 8192x4320.
I have to whittle my input files down to get the encoder to encode them. My animations are just a few frames but I have to save them as 25 fps avi and then open the avi in Virtualdub and cut them back down to 1 frame per picture and then as .245. This gives me 9 or 10 frames that I can feed the encoder which would not accept the 900 or so frame file before or it would encode a video that would just play one frame.
EDIT: I'll try to encode just one frame and see how it goes. I believe that is one of the goals, to use HEVC as a graphics compression. The frame that you uploaded is 2,096 kbs. I opened the file and saved as a .png image that was 34,027 kbs. That is a huge difference in file size.Last edited by DarrellS; 16th Mar 2014 at 00:07.
help - how to compile latest "nightly" ffmpeg for win32 (XP) with mingw
By hydra3333 in forum ProgrammingReplies: 32Last Post: 20th May 2017, 00:33 -
x265 vs x264
By deadrats in forum Video ConversionReplies: 71Last Post: 10th Jan 2016, 06:14 -
ffdcaenc (an upgrade to dcaenc)
By El Heggunte in forum AudioReplies: 22Last Post: 9th Dec 2014, 06:09 -
MulticoreWare Annouces x265/HEVC Mission Statement
By enim in forum Latest Video NewsReplies: 4Last Post: 9th Aug 2013, 22:09 -
New PC Build(s)
By thedeificone in forum ComputerReplies: 6Last Post: 25th May 2010, 16:57
