Page 42 of 75
FirstFirst ... 32 40 41 42 43 44 52 ... LastLast
Results 1,231 to 1,260 of 2222
  1. Banned
    Nov 2005
    Originally Posted by x265 View Post
    Pro tip: If you want to create a new website/business/organization, pick a name that isn't already taken. The solution is simple... create bobsbuildbot.com, and you're all set to go.
    Pro Tip: the above statement takes a brass set of balls, seriously! you guys picked a name meant purposely to elicit the belief from the general public that this hevc encoder was the product of the guys behind x264.
    if one wanted to follow your example then if he named his site x266 you wouldn't have a problem with it?
    your idiotic statement is akin to me starting a website called doom10.us and Jason complaining that i was infringing on "his" IP.
    my God, you don't know how badly i hope you guys fail and big.
  2. Banned
    Nov 2005
    Just to make sure: Is there a problem with me supporting x265 in Hybrid?
    they should consider themselves lucky i'm not the lead developer of your software or any other similar app, i would flat out refuse to support their encoder with an explicit explanation of why in the about section.
  3. Member x265's Avatar
    Aug 2013
    Sunnyvale, CA
    Selur,
    Anyone can create products with x265 as long as they comply with the terms of the GPL 2.0.
    Tom
  4. Okay, just wanted to check.
  5. Only comparative purposes, keep doing tests with H265-HEVC (10 Bit) version 0.6+335-3568c1b19947:
    [ ok ] MKV support most audio codec!
    [ ok ] Last configuration has been load.
    [info] Last source dir:
    [info] Last dest dir:
    [info] Last temp dir:
    [info] New temporary folder: E:\
    [ ok ] MP4 support AAC only and ablity to mux with MKV by adding subtitle/etc.
    [ ok ] Loaded libcore.dll
    [info] Command: -i "C:\Users\Marchand\Videos\Videos\00200.m2ts" -vn -ar 44100 -y
    "E:\\temp1.wav"
    ffmpeg version N-59532-gadc09a3 Copyright (c) 2000-2014 the FFmpeg developers
    built on Jan 3 2014 22:07:20 with gcc 4.8.2 (GCC)
    configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
    isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
    le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
    e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena
    ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l
    ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp
    eex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aa
    cenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavp
    ack --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
    libavutil 52. 59.100 / 52. 59.100
    libavcodec 55. 47.100 / 55. 47.100
    libavformat 55. 22.102 / 55. 22.102
    libavdevice 55. 5.102 / 55. 5.102
    libavfilter 4. 0.103 / 4. 0.103
    libswscale 2. 5.101 / 2. 5.101
    libswresample 0. 17.104 / 0. 17.104
    libpostproc 52. 3.100 / 52. 3.100
    Input #0, mpegts, from 'C:\Users\Marchand\Videos\Videos\00200.m2ts':
    Duration: 00:00:07.46, start: 11.650667, bitrate: 41412 kb/s
    Program 1
    Stream #0:0[0x1011]: Video: h264 (High) (HDMV / 0x564D4448), yuv420p, 1920x1
    080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
    Stream #0:1[0x1100]: Audio: dts (DTS-HD MA) ([134][0][0][0] / 0x0086), 48000
    Hz, 5.1(side), fltp, 1536 kb/s
    Output #0, wav, to 'E:\\temp1.wav':
    Metadata:
    ISFT : Lavf55.22.102
    Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 44100 Hz, 5.1(side),
    s16, 4233 kb/s
    Stream mapping:
    Stream #0:1 -> #0:0 (dca -> pcm_s16le)
    Press [q] to stop, [?] for help
    size= 3859kB time=00:00:07.46 bitrate=4233.7kbits/s
    video:0kB audio:3859kB subtitle:0 global headers:0kB muxing overhead 0.002581%
    [ ok ] Loaded libfaac.dll
    [info] Command: -b 128 -o "E:\\temp1.aac" "E:\\temp1.wav"
    Freeware Advanced Audio Coder
    FAAC 1.28
    Remapping input channels: Center=3, LFE=4
    Average bitrate: 180 kbps
    Quantization quality: 100
    Bandwidth: 5000 Hz
    Object type: Low Complexity(MPEG-2) + M/S
    Container format: Transport Stream (ADTS)
    Encoding E:\\temp1.wav to E:\\temp1.aac
    frame | bitrate | elapsed/estim | play/CPU | ETA
    323/323 (100%)| 168.4 | 0.7/0.7 | 11.18x | 0.0
    [ ok ] E:\\temp1.wav has been deleted!
    [info] Command: -i "C:\Users\Marchand\Videos\Videos\00200.m2ts" -pix_fmt yuv420p
    10le -y "E:\\temp0.yuv"
    Program 1
    Output #0, rawvideo, to 'E:\\temp0.yuv':
    Metadata:
    encoder : Lavf55.22.102
    Stream #0:0: Video: rawvideo (Y3[11][10] / 0xA0B3359), yuv420p10le, 1920x108
    0 [SAR 1:1 DAR 16:9], q=2-31, 200 kb/s, 90k tbn, 23.98 tbc
    Stream mapping:
    Stream #0:0 -> #0:0 (h264 -> rawvideo)
    frame= 21 fps=0.0 q=0.0 size= 127575kB time=00:00:00.87 bitrate=1193196.3kbit
    frame= 44 fps= 43 q=0.0 size= 267300kB time=00:00:01.83 bitrate=1193200.2kbit
    frame= 67 fps= 44 q=0.0 size= 407025kB time=00:00:02.79 bitrate=1193201.4kbit
    frame= 90 fps= 44 q=0.0 size= 546750kB time=00:00:03.75 bitrate=1193198.5kbit
    frame= 108 fps= 42 q=0.0 size= 656100kB time=00:00:04.50 bitrate=1193200.4kbit
    frame= 128 fps= 41 q=0.0 size= 777600kB time=00:00:05.33 bitrate=1193200.3kbit
    frame= 146 fps= 41 q=0.0 size= 886950kB time=00:00:06.08 bitrate=1193199.4kbit
    frame= 165 fps= 40 q=0.0 size= 1002375kB time=00:00:06.88 bitrate=1193199.9kbit
    frame= 179 fps= 39 q=0.0 Lsize= 1087425kB time=00:00:07.46 bitrate=1193200.8kbi
    ts/s
    video:1087425kB audio:0kB subtitle:0 global headers:0kB muxing overhead 0.000000
    [ ok ] Loaded libx265hi.dll
    [info] Command: -p placebo --crf 17 --input "E:\\temp0.yuv" --input-res 1920x108
    0 --input-depth 10 --fps 23976 -o "E:\\temp0.hvc"
    yuv [info]: 1920x1080 23976Hz C420, frames 0 - 178 of 179
    x265 [info]: using cpu capabilities: MMX2 SSE SSE2Fast SSSE3 SSE4.1 Cache64
    x265 [info]: HEVC encoder version 0.6+335-3568c1b19947
    x265 [info]: build info [Windows][GCC 4.8.1][64 bit] 16bpp
    x265 [info]: Main10 profile, Level-6.2 (Main tier)
    x265 [info]: WPP streams / pool / frames : 17 / 4 / 2
    x265 [info]: Input bit depth : 10
    x265 [info]: CU size : 64
    x265 [info]: Max RQT depth inter / intra : 4 / 4
    x265 [info]: ME / range / subpel / merge : star / 92 / 5 / 5
    x265 [info]: Keyframe min / max : 250 / 250
    x265 [info]: Rate Control / AQ-Strength / CUTree : CRF-17.0 / 1.0 / 1
    x265 [info]: Lookahead / bframes / badapt : 60 / 8 / 2
    x265 [info]: b-pyramid / weightp / refs : 1 / 1 / 5
    x265 [info]: tools: rect amp rd=6 lft sao-lcu sign-hide tskip
    [7.3%] 13/179 frames, 0.04 fps, 1156277.62 kb/s, eta 1:01:54
    Aug 2013
    Central Germany
    @ Marchand:
    kvazaar 0.21 requires MSVCR100D.dll; is that the debug symbol containing version of MSVCR100.dll? I thought I have all MSVC runtime libraries installed... Please either re-publish compiled in release mode, or include this DLL (if MSVS license permits ... probably not, may not be redistributable).
    Jan 2014
    Kazakhstan
    write in the topic kvazaar https://forum.videohelp.com/threads/362131-Around-the-Kvazaar-H-265-encoder?p=2299390
    Aug 2013
    Central Germany
    Ah, OK, will do.
  9. DECEASED
    Jun 2009
    Heaven
    commit fa9f7b5 (version 0.7+95)
  10. DECEASED
    Jun 2009
    Heaven
    ^ nevermind, because
    clicky =>x265.ru is back in business
    Aug 2013
    Central Germany
    A few questions about the MinGW build environment:
    a) Is it possible to call the MSYS shell with a specific user name, so that it doesn't use the name of the Windows user account?
    b) What do I have to change to build a Win64 EXE instead?
  12. DECEASED
    Jun 2009
    Heaven
    a) yes, create a shortcut to cmd.exe and run it with a different logon,
    then call msys.bat
    b) I'm still trying to find the solution , BTW I've sent you a PM @ doom9
    Aug 2013
    Central Germany
    a) would mean to create a user with the desired name. I hoped one could use a parameter for the shell call inside the MSYS.bat ... maybe I can hide it in the login users list by making it unable to login interactively.
    b) You seem to be on the right track.
  14. DECEASED
    Jun 2009
    Heaven
    Please test the build below,
    IF it happens to work o.k.,
    THEN I will post the fugly "recipe", of course.
  15. for x64 build with msys/mingw you can try with the method I posted some time ago.
    https://forum.videohelp.com/threads/357754-%5BHEVC%5D-x265-EXE-mingw-builds?p=2283564&v...=1#post2283564
    but with this :
    SET(CMAKE_C_COMPILER x86_64-w64-mingw32-gcc -O3)
    SET(CMAKE_CXX_COMPILER x86_64-w64-mingw32-g++ -O3)
    SET(CMAKE_RC_COMPILER x86_64-w64-mingw32-windres)
    SET(CMAKE_ASM_YASM_COMPILER yasm)
  16. DECEASED
    Jun 2009
    Heaven
    How to build a 64-bit x265 binary with MinGW under a 32-bit environment
    1) In the CMakeGUI, set the following "values":
    CMAKE_CXX_COMPILER = Path-To/mingw/bin/x86_64-w64-mingw32-g++.exe
    CMAKE_C_COMPILER = Path-To/mingw/bin/x86_64-w64-mingw32-gcc.exe
    CMAKE_RC_COMPILER = Path-To/mingw/bin/x86_64-w64-mingw32-windres.exe
    2) Click "configure", "generate", then close the GUI.
    3) In the files named below, replace "ranlib.exe" with "x86_64-w64-mingw32-ranlib.exe"
    x265\build\msys\CMakeFiles\x265-static.dir\link.txt
    x265\build\msys\CMakeFiles\2.8.11.2\CMakeCXXCompiler.cmake
    x265\build\msys\CMakeFiles\2.8.11.2\CMakeCCompiler.cmake
    x265\build\msys\CMakeFiles\2.8.11.2\CMakeASM_YASMCompiler.cmake
    x265\build\msys\CMakeCache.txt
    4) make
    P.S.: @easyfab --- your method is very-cheap, unfair and anti-sportive
    Just kidding of course =^.^=
  17. And for those who like -march and -mtune, an example :
    SET(CMAKE_C_COMPILER x86_64-w64-mingw32-gcc -O3 -march=corei7-avx -mtune=corei7-avx)
    SET(CMAKE_CXX_COMPILER x86_64-w64-mingw32-g++ -O3 -march=corei7-avx -mtune=corei7-avx)
  18. DECEASED
    Jun 2009
    Heaven
    New buildbots
    http://chromashift.org/x265_builds/ (by Daemon404)
    http://builds.x265.eu/ (by snowfag )
  19. Last edited by Marchand; 10th Feb 2014 at 19:46.
    Jan 2014
    Kazakhstan
    Originally Posted by Marchand View Post
    PS: I'm still doing tests on variants H265/Hevc-Divx-10bits
    You have DivX / HEVC 10bit version?
    Aug 2013
    Central Germany
    Originally Posted by El Heggunte View Post
    New buildbots
    Meh ... so why do I even try?!
    Ah, well, despite my lack of experience, I was able to put together a few puzzle pieces from El Heggunte and easyfab. The result was a simple build environment for x86-64 8bpp.
    I added the following files to x265\build\msys:
    based on easyfab's reports, and with CMAKE_RANLIB added to include the automation El~ applied manually
    toolchain64.cmake
    SET(CMAKE_SYSTEM_NAME Windows)
    SET(CMAKE_RANLIB x86_64-w64-mingw32-ranlib)
    Remember to save with Unix linebreaks (LF only)!
    completed a copy of make-Makefiles.sh with portions of easyfab's call, but it needs to make "MSYS Makefiles", not "Unix Makefiles"
    make-Makefiles64.sh
    #!/bin/sh
    # Run this from within an MSYS bash shell
    cmake -G "MSYS Makefiles" -DCMAKE_TOOLCHAIN_FILE=toolchain64.cmake ../../source && cmake-gui ../../source
    Instead of typing this line as in El Heggunte's guide, one can also call
    ./make-Makefiles.sh
    in the MSYS shell when building for Win32, and now for building Win64 respectively:
    ./make-Makefiles64.sh
    But if you switch, first delete cmake_install.cmake, CMakeCache.txt, and Makefile.
    Building for Win32, you may enable WinXP compatibility in CMake-gui; building for Win64, you should certainly not.
  22. Member
    Nov 2002
    x265_ 0.4.1+546-ccac3a7d3622.7z --- ( featuring the stdin support 0_o )
    Is this the only version that supports both Windows XP and stdin? I'm having problems getting anything else to work. All the newer versions either give me "blah blah blah is not a win32 program" or %1 is not a Win32 program. Also, none of the presets worked in Virtualdub but replacing them with the command arguments for those presets worked (thanks Selur). At first, I was getting black files instead of the video but I remembered that the only way that I could get those mkv files created with Rovi's Muxer was to give them a divx extension and play with the divx player.
    Doesn't seem like Multicoreware wants this encoder to succeed and I doubt that either mkvtoolnix or MPC-HC's creators think it will or they would've updated their programs by now to support x265.
  23. Member
    Aug 2013
    Central Germany
    My Win32 builds of v0.7+ have XP compatibility enabled.
    But when it comes to UHD resolutions one day, don't even try 32-bit applications anymore.
    mkvtoolnix doesn't want to support HEVC as long as the specifications for HEVC multiplexed in MKV are not final. And MPC-HC already supports decoding HEVC in MP4.
    And x265 will succeed when it is "done". Now it is still "just even started".
  24. Originally posted by Ligh.de
    kvazaar 0.21 requires MSVCR100D.dl....
    it seems like it is compiled MSVS2010 or MSVS2012 VC++ compiler. setting proper compiler switch might work to compile independent binary. Otherwise testers/users need to install MSVCXXXX runtime, the trick of placing MSVCR100D.dll and MSVC(???)100D.dll in same directory might work.
  25. Member
    Aug 2013
    Central Germany
    Wrong thread; you should have replied here instead.
    The problem is not installing the runtime, but having a debug build; the runtime does not contain the debugging versions of the Visual C++ DLLs because they are not redistributable, only available in the SDK.
  26. DECEASED
    Jun 2009
    Heaven
    Surely it isn't.
    Depends on where you've downloaded them from, I guess. Most people who use MSVC certainly don't care about making XP-compatible builds of x265, unfortunately. Also, I have zero experience with the external encoders of VirtualDub.
  27. DECEASED
    Jun 2009
    Heaven
    Ditto.
    Really? For the notes, here goes what Mosu said on November 26 and 27 of 2013:
    Q: as for the much-expected HEVC support,
    will it get out of the oven before next Christmas?
    A: It's not impossible, but unlikely given my current workload I would've been happier if it were different.
    Q: What about using the patch from DivX?
    A: That is what I will do, but from what I've seen from their patch I'm not willing to take it as it is. I will have to spend some time on it in order to whip it into the shape I'd want it to be.
    I'm definitely not going to reinvent the wheel. I loath h.264 and how much complexity it causes even on the container level (determining frame types, and more importantly, correct frame DTS and PTS); therefore I'm very grateful for the work they've done already.
  28. Member
    Nov 2002
    Well, I just tried every x265 encoder on my PC and the only three (2 really because one is the same as 265.cc's latest) I could get working are x265_ 0.4.1+546-ccac3a7d3622.7z listed above and the one in Selurs Hybrid program which I believe is an older build. I assume that Selur is using an older build for the same reason. Nobody, except for x265.cc seems to know how to create a build that supports stdin "-"
  29. The build in Hybrid is the svn version which was up-to-date at the time I released the latest Hybrid version.
    Also there is nothing one has to do to compile x265 with stdin support,...
    Attached 0.7+113 versions of x265 which I just compiled. (static mingw builds)
  30. Member
    Aug 2013
    Central Germany
    If you fail to use x265 with stdin piping, you may have to explain as detailed as possible what you are trying to do, and which reactions you have to report. Quote the command line exactly. Quote error messages exactly.
    Maybe it fails because you are using an obsolete command line option, then it's not the fault of the stdin support.
