Results 661 to 690 of 2222
encoder.pw buildbot is NOT affiliated with, endorsed, or sponsored by the
x265 development team, MultiCoreWare Inc, Xiph.Org Foundation nor VideoLAN organization. -
x265.exe normal encode 720p https://forum.videohelp.com/threads/357754-%5BHEVC%5D-x265-EXE-mingw-builds?p=2275810&v...=1#post2275810
You should not compare two really different builds (Newest revision, VC11, 64bit with Older revision, GCC4.8.1, 32bit).
You can try to compare it with this version: https://x265.cc/builds/MSYS-x86/8bpp/x265_0.4.1%2b493-6d96d64c4e9a.zipencoder.pw buildbot is NOT affiliated with, endorsed, or sponsored by the
im sorry....
next one please
https://x265.cc/builds/VC11-x86_64/8bpp/x265_0.4.1%2b493-6d96d64c4e9a.zip
If this version is also working, its an x265 related problem. (Due to an change in the latest versions)
And should be reported to the x265 mailinglist
Tested commit 4ca4da7 on a 25-frame Y4M file,
using both a GCC build and a Visual C build from x265.cc:
no crashes, BUT only 21 frames were encoded
Definitely there is a bug or design flaw in the latest source-code
( what a surprise
Yep, i've now also got an 720p y4m file to test with. The latest version which is working is "x265_0.4.1+518-a349dec61168.zip".
Probably not my fault
Under which circumstances should I prefer or avoid the 8bpp vs. the 16bpp version?
Is it similar to 8 bit vs. 10 bit of x264, a higher internal encoded value precision? May their support depend on the completeness of the decoder? -
Problem is that afaik, there is no HEVC with 16bit (all the profiles I know of only support up to 12bit)
-> see: http://en.wikipedia.org/wiki/High_Efficiency_Video_Coding#Profiles -
Wiki refers to the output of HEVC pixel accuracy
Rather than the internal processing precision -
Okay, that is the confusion, normally output and internal processing precision is the same,...
Erm, looks like x265 is supporting yuv input from stdin since 12 hours..
The x265 project has set up communication channels, and these include the x265 development mailing list - x265-devel@videolan.org. These communication channels have been working great for everyone who wants to participate or contribute to the project (including the sharing of bug reports). Privately emailing our lead developer at his personal email address is bad form. Please don't do this.
Bug reports are welcomed and very helpful, but please remember to include the steps to reproduce the problem (generally, the build of x265 that you were running, the command line syntax, details on your test sequence or input source, details on your PC system configuration).
As we optimize x265 and add new features there are always bugs introduced in the tip of the code repository. If you want a stable build, pull from the stable branch (hg update stable). If you are getting builds from the tip (not sure? run hg summary), you will encounter bugs, just as our development team does. We have a large team running automated tests, and these tests flush out the bugs. Our development team fixes bugs fairly quickly, but it may take a day or so to show up as we have a 24 hour review process for all patches submitted, even our own. -
x265 and team, thank you all for putting up with our rants, among other things and with great patience!
regarding post # 590
Jacobr, i played around and i found where the problem was with the artifacts when using your param string.
using ref 3 or higher causes artifacts when using the setting for that param string configuration. changing to 2 or 1 removed the artifacts completely. hope this info helps you and others with respect to x265.exe's ref parameter.
note: i only tested on 122 frames, 720x480 video source.
good quality using those params.
Code:--frame-skip 0 --frames 122 --q 17 -F2 --keyint 80 --b-adapt 2 -b 3 --bframe-bias 30 --ref 2 --max-merge 5 --me 3 --rect --hash 0 --rd 0 --tu-intra-depth 3 --tu-inter-depth 3 --no-tskip --no-tskip-fast --input "g:\video.y4m" -o "g:\video.[545].hm10"
- feature request, report -
since the encoded video is in raw form, is it possible to have x265.exe continue an encode after it stopped ?
for example, i have a larger video source, but only encode 122 frames worth. if after reviewing the playback quality, and i like it, i would like to continue encoding additional frames from where i left off. thus, frame 122, 123, 124, ... should work, give the encoder the last frame and video source, let it calculate the gop or idr or whatever its called in h265, and rebuild the video from that and continue. you could hold the necessary info in a .log file if the user chooses that and all the info could be extracted to rebuild from the last frame, much similar to how videoredo does it. thank you. -
At last, the stdin support... commit ccac3a7
usage:
Code:avs2yuv input.avs -raw -o -|x265 --fps xxx --input-res wxh --blah-blah-blah -o output.hevc -
By the way:
We already discussed how to support both YUV4MPEG and raw YUV input via pipe; for the early testing time without implementing an auto header detection, but just with parameters: If you have raw YUV input, on one hand, you'll have to specify several video attributes (width, height, framerate, possibly pixeltype) via parameters anyway, so on the other hand, you could simply indicate piping Y4M with one alternative parameter instead.
I repeat: We discussed. This is probably not yet implemented. "Soon™". You'll get notified.
help - how to compile latest "nightly" ffmpeg for win32 (XP) with mingw
By hydra3333 in forum ProgrammingReplies: 32Last Post: 20th May 2017, 00:33 -
x265 vs x264
By deadrats in forum Video ConversionReplies: 71Last Post: 10th Jan 2016, 06:14 -
ffdcaenc (an upgrade to dcaenc)
By El Heggunte in forum AudioReplies: 22Last Post: 9th Dec 2014, 06:09 -
MulticoreWare Annouces x265/HEVC Mission Statement
By enim in forum Latest Video NewsReplies: 4Last Post: 9th Aug 2013, 22:09 -
New PC Build(s)
By thedeificone in forum ComputerReplies: 6Last Post: 25th May 2010, 16:57
