This is the first time I deal with converting an mp4 file to mkv, with as little or no re encoding as possible, and I failed.
I tried to MKV merge, different versions, and Vidcoder, and couldn't even load the file.
From Mediainfo I get the following specs for the file:
With Vidcoder I can't even load it, and with MKVmerge I get this message:Code:General Complete name : C:\ file.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 6.80 GiB Duration : 56mn 38s Overall bit rate : 17.2 Mbps Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L4.0 Format settings, CABAC : No Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=30 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 56mn 38s Source duration : 56mn 38s Bit rate mode : Variable Bit rate : 16.3 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.262 Stream size : 6.45 GiB (95%) Source stream size : 6.72 GiB (99%) mdhd_Duration : 3398195 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 56mn 38s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 79.4 MiB (1%) mdhd_Duration : 3398229
What should I do?Code:Command line used: "C:\Video\MKVToolNix 6.2.0\mkvmerge.exe" --output-charset UTF-8 --identify-for-mmg "C:\file.mp4" Output: Error: The demultiplexer for the file 'C:\file.mp4' failed to initialize: The file could not be opened for reading, or there was not enough data to parse its headers.
What tool(s) for MP4 to MKV conversion with no reencoding?
By zdvd in forum Video ConversionReplies: 35Last Post: 17th Dec 2016, 08:38 -
MKV to MP4 without conversion
By swiego in forum Video ConversionReplies: 9Last Post: 7th Dec 2014, 12:54 -
Another MKV to MP4 conversion question
By cbjfan2009 in forum Video ConversionReplies: 13Last Post: 15th Sep 2012, 22:45 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
AppleTV - Conversion of MKV to HD MP4
By Austehn in forum Video ConversionReplies: 7Last Post: 22nd Oct 2008, 20:28
