Hello,
How do i force DVD Flick to expand the encoded video into full 4.3 G.B DVD?
Thanks.
On the project settings/video/target bitrate, it should normally be "auto fit"
Of course, your project may still not fill the DVD if the running time is below 65 - 70 minutes.
The bitrate can only be raised so much and still be within the DVD spec. -
Yes, AVStoDVD.
I very much prefer it to DVDFlick. Use a two pass encode with HC for best accuracy in fitting your video into a 4.3gb DVD-5 target.
If you need a guide to get started with AVStoDVD, here are a couple: https://forum.videohelp.com/threads/353284-AVStoDVD-beginners-guide-Any-video-to-DVD-Video
http://club.myce.com/f32/avstodvd-guide-331620/
DVD player locks up when I try to play disk with menu authored by DVD Flick
By aprete in forum Authoring (DVD)Replies: 2Last Post: 19th Jun 2013, 22:19 -
No subtitles in dvd flick on final dvd output. .avi file ??
By fairenough786 in forum SubtitleReplies: 2Last Post: 20th May 2013, 18:52 -
Burnin DVD via Flick, all DVD clips come out pixilated towards end of disc?
By jacknscoob in forum Authoring (DVD)Replies: 27Last Post: 28th Jan 2012, 07:48 -
Converting AVI to DVD using DVD Flick: low quality result
By e2p in forum Video ConversionReplies: 13Last Post: 28th Oct 2010, 11:50 -
Subtitle timing problem, DVD created using DVD Flick
By Vianty in forum Authoring (DVD)Replies: 8Last Post: 28th Apr 2010, 03:33
