    Jul 2013
    Rizhao, Shandon, China
    I have some videos that have an incorrect rotation property. This means that some viewers will rotate it and some will not.
    I am looking for a utility that can update the rotation property so that the video will not be rotated.
    I believe that FFmpeg can do it, but I really don't want to slog through the doc to determine how to flip a simple bit. I would also prefer some method that can do this in place, but at the moment any solution is better than what I have.
    Thanks, everyone.
    Maybe quicktime pro. Or it might only be for mov files.
    Jul 2013
    Thanks, but I was hoping for something free and I'm not going to lay out funds for "maybe" it works.
    I also should have mentioned that I would prefer Windows XP compatible software.
    I don't need anything fancy. A simple command line utility to set this property to zero would suffice.
  4. Googling "rotate ffmpeg" isn't really a huge slog. Good luck.
  5. Maybe remux with My Mp4Box GUI. Or MP4 Muxer. Or Mp4Box.
