is there anyway to rec dvb-t tv in MPC
the one i am using is
Media Player Classic - Home Cinema
Build information:
Version: 1.6.8.7378 (7d1831b)
MPC-HC compiler: MSVC 2010 SP1
FFmpeg compiler: MinGW-w64 GCC 4.7.3 (MMX)
Build date: May 31 2013 16:03:45
Operating system:
Name: Windows NT 6.1 (build 7600)
Version: 6.1 (64-bit)
any help would be great![]()
As far as I know, MPCHC only supports using analog capture and analog tuners. I have used Pot Player for ATSC digital TV tuners. I do not know if Pot Player works for DVB-T, since DVB-T is not used in the USA. Pot Player can capture the ATSC stream, but I would use use NextPVR or other PVR software instead.
I have used MPCHC for analog tuners and analog capture, and it works for devices that use software for encoding. If I try to use MPCHC with a digital tuner here, all I get is an error message, something like "can't connect to tuner." Real PVR software doesn't have any problems with the same digital tuners. Since I can't help you other than to suggest other programs that are known to work well for recording DTV, I'll wish you luck.
By Soixante in forum Software PlayingReplies: 4Last Post: 16th Sep 2010, 18:11 -
Problem using Media Player Classic home cinema player
By True Colors in forum Newbie / General discussionsReplies: 7Last Post: 18th Apr 2010, 08:30 -
Streaming FLV in WM Player or Media Player Classic
By jlz901 in forum Video Streaming DownloadingReplies: 0Last Post: 21st Mar 2010, 12:09 -
Media Player Classic on CD
By siluet in forum Newbie / General discussionsReplies: 1Last Post: 2nd Oct 2008, 07:30 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49
