Results 1 to 30 of 44
  1. I'm trying to decide which is the best way for me to deinterlace the file below. I've seen three avisnth plugins which were recommended. They were yadif, QTGMC, and TempGaussMC. In regard to QTGMC and TempGaussMC, is TempGaussMC worth the quality for the time it will take?
    General
    Complete name : D:\video.mpg
    Format : MPEG-PS
    File size : 460 MiB
    Duration : 21mn 29s
    Overall bit rate : 2 994 Kbps
    Writing library : (c) 1998-2010 Womble Multimedia, Inc. / MPEG Video Wizard DVD 5.0.0.114 (01/2010) / Jan 5 2011
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : Variable
    Duration : 21mn 29s
    Bit rate mode : Variable
    Bit rate : 2 742 Kbps
    Maximum bit rate : 2 904 Kbps
    Width : 704 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.271
    Time code of first frame : 00:00:00;00
    Time code source : Group of pictures header
    Stream size : 422 MiB (92%)
    Audio
    ID : 189 (0xBD)-128 (0x80)
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Muxing mode : DVD-Video
    Duration : 21mn 29s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 29.5 MiB (6%)
    Text
    ID : 224 (0xE0)-CC1
    Format : EIA-608
    Muxing mode : A/53 / DTVCC Transport
    Muxing mode, more info : Muxed in Video #1
    Stream size : 0.00 Byte (0%)
    Menu
  2. Usually it's worth the time for most sources IMO
    If speed is a concern, you can use faster settings for QTGMC e.g. preset="faster" , and get 95-98% of the quality, but it will be several times faster than the default setting of "slower"
    For some sources and situations you might want to adjust the settings or use different deinterlacer , because it applies some other processing like smoothing, denoising
  3. BTW, mediainfo is useless for this type of thing
    For example, are you sure it needs to be deinterlaced? or might it be telecined / 3:2 hard pulldown ? If you apply the wrong processing it makes the quality much worse
  4. Time isn't really a concern. They are from a game show, so there's not a lot of fast movement/action. These are tv rips so I'm fairly certain that they are interlaced, is there a way to be sure?
  5. Originally Posted by ROBO731 View Post
    Time isn't really a concern. These are tv rips so I'm fairly certain that they are interlaced, is there a way to be sure?
    "tv rips" as in an episodic series, like dramas ? Shot on film or digital film equivalents ? Then 99.99999999999999% chance it's not interlaced content, unless it's a daytime soap opera (in that case I'm gonna laugh )
    The only way to be 100% sure is to use your eyes, examining the fields and/or looking at the cadence patterns. Deinterlacing progressive content is a NO-NO . It's avoidable quality loss . If it's telecined, you reverse it (inverse telecine)
    If you're not sure, you can upload a small sample with steady movement
  6. It's not a drama XD. When i opened them with vlc, and turned on deinterlacing, they looked much better than when it was off.
  7. You must have made a ninja edit before my reply, The quote above is missing the "game show" part.
    Not sure about that show. IIRC, There is an older series with Drew Carey and I think a newer version of series (2013?). Maybe someone else knows offhand. Or upload a sample
  8. Originally Posted by ROBO731 View Post
    It's Whose Line, not a drama XD. When i opened them with vlc, and turned on deinterlacing, they looked much better than when it was off.
    Since you don't know what you're doing, it might be better for you to post a sample. Open a VOB in DGIndex, use the [ and ] buttons to isolate a small 10-second piece, one with steady movement so we can tell, and then File->Save Project and Demux Video. It probably is interlaced, but that's not really the way to definitively tell.
    QTGMC is pretty much a newer and much improved version of TempGaussMC. Cross TempGaussMC off your list. Yadif is decent and fast. QTGMC is much better and can be much slower (depending on the settings you use).
  9. Banned
    New York, US
    The MediaInfo text posted does reveal that it's very low bitrate (3000 or less), probably 3-hour or 4-hour mode. For a fast-action" video encoded along those lines, don't expect miracles. By "TV rip" I take it that these are taken from a commercial DVD of a TV series, which will have higher quality at low bitrates than a home-made recording.
  10. Ok, here's a sample. Also, thanks for the input, I'll use QTGMC or yadif if it's taking too long.
  11. Will these deinterlacers work? They don't say that they support YUV.
  12. Originally Posted by manono View Post
    ...isolate a small 10-second piece, one with steady movement ...
    A guy flapping his jaws doesn't qualify as steady movement. Anyway, it is interlaced and both deinterlacers will work. YV12 (which all DVDs are) is a subset of YUV.
  13. So, I'm currently testing out yadif, but I'm getting an error. I'm not sure what I'm doing incorrectly though.
    Avisynth Script:
    Load_Stdcall_plugin("D:\Desktop\yadif17\yadif.dll")
    DirectShowSource("D:\Desktop\test\video.mpg", audio=false)
    mode=1
    Batch file:
    "D:\Desktop\x264\x264 32 8bit.exe" --crf 18 --preset veryslow --level 3.1 -o "8-bit out mode 1.h264" "D:\Desktop\test\De-interclace.avs"
    @pause
    x264 Error:
    D:\Desktop\test>"D:\Desktop\x264\x264 32
    avs [error]: `D:\Desktop\test\De-interclace.avs' didn't return a vi
    deo clip
    x264 [error]: could not open input file `D:\Desktop\test\De-intercl
    ace.avs'
    Press any key to continue . . .
    When changing the avs so that it uses just the demuxed video track with no audio:
    deo clip
    ace.avs'
  14. How about this:
    Load_Stdcall_plugin("D:\Desktop\yadif17\yadif.dll" )
    Yadif(mode=1)
    Also, in my opinion, you'd be better off making a D2V project file using DGindex and loading the DGDecode.dll so you can use MPEG2Source instead of DirectShowSource. Before encoding, test your scripts in VDub so you'll get a more precise error message if something's wrong with them.
  15. I agree DirectShowSource normally is the last choice. DGDecode, FFmpegSource, LWLibavVideoSource, AviSource, DSS2 should all come before using DirectShowSource. Why? Simply because DirectShow-Filters are ment for playback so the are allowed to drop frames lower quality&co and d non accurate jumps to meat a certain speed.
    -> Using DirectShowSource can be problematic on complex scripts and filters which use multi-threading and/or non-linear frame access.
    Cu Selur
    Ps.: TDeint also is a nice Deinterlacer, which I often prefer over Yadif.
  16. Thanks for the suggestions, I'm using mpegsource with the d2v file and it's encoding now. I'm just testing out different deinterlacers right now. I'll give TDeint a try after this. Then I'm going to test QTGMC.
  17. Video Restorer lordsmurf's Avatar
    QTGMC isn't really that slow in the age of quad-cores and dual-cores.
    And it really is the best.
  18. Originally Posted by lordsmurf View Post
    If you're not running a multithreaded build of AviSynth QTGMC will be running single threaded -- no matter how many cores you have.
  19. Yeah, I'll run it multithreaded. I'm about to try it out now
  20. Video Restorer lordsmurf's Avatar
    Well, yeah, that's obviously required.
    Even without it, the single-core implementation works well on modern hardware.
    I remember when DVD Shrink took hours. Now it's done in minutes. (Example.)
  21. I'm encoding now, using the below parameters and files, but x264 is crashing, leaving me with an incomplete file/encode. At the beginning, it very briefly said that I was missing a dll file, but began the encode anyway. The message went away to quickly for me to have read. I'm going to run it again and quickly screenshot so I can see what plugin it says I'm missing. I'll get the plugin and then run it again, but is there anything anyone can see that might be the source of the problem?
    AVS:
    LoadPlugin("D:\Desktop\dgmpgdec158\DGDecode.dll")
    #SetMemoryMax(M)  # Optional line. Leave it out at first. See below for value M
    SetMTMode(5, 3)  # See below for value X
    MPEG2Source("D:\Desktop\test\video.d2v")  # DGDecode_mpeg2source, FFVideoSource, AviSource, whatever your source requires
    SetMTMode(2)
    QTGMC( Preset="Very Slow", EdiThreads=2 ) # Choose preset based on overall speed/quality you want. See below for value Y
    Distributor()    # This line may or may not be necessary, try removing it and see if you get more speed
    bat:
    "D:\Desktop\x264\x264 32 8bit.exe" --crf 18 --preset veryslow  --level 3.1 -o "QTGMC-Deinterlace.h264"  "D:\Desktop\test\QTGMC-Deinterlace.avs"
    @pause
    Error:
    avs [info]: 704x480p 0:0 @ 60000/1001 fps (cfr)
    x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
    x264 [info]: profile High, level 3.1
    Press any key to continue . . . 7 fps, 1831.48 kb/s, eta 0:09:52
  22. 1) Can you preview the script in vdub? Scrub to the middle and end, any error messages ?
    2) Sometimes MT can cause crashes ; the only stable version is SET's avisynth 2.6 MT - is that the version you are using ?
    3) If you still can't figure it out, try single thread , non MT
    Not related to the crash, but you should probably include --sar 10:11 if you want the AR correct
  23. Not related to the crash, but your sample is TFF
    If you don't specify a field order, avisynth assumes BFF by default. If you assume the wrong field order, you will get jerky fwd/back results
    So for QTGMC you need to add AssumeTFF() to the script before the QTGMC call
    For yadif you can use (mode=1, order=1) if you are bobbing [order =0 would be bff]
    If you're going to ask: "how do I determine field order?", start with this mini guide
    http://neuron2.net/faq.html#analysis
  24. Multithreaded AviSynth does occasionally have problems. Try 1 or 2 threads.
    Or use the Info=3 argument in Mpeg2Source().
  25. Ok, thanks. I'll give these suggestions a try and let you know how it goes.
  26. Edit:
    Woops, ignore this post, I figured out what I was asking in it.
  27. So the dll which it reports to be missing is msvcr71.dll, I fixed this error. Also, this time it didn't run the encode despite this error. It reported a new error message, I don't know why it's has a problem with SetMTMode even though it ran it fine before:
    avs:
    LoadPlugin("D:Desktop\dgmpgdec158\DGDecode.dll")
    AssumeTFF()
    SetMTMode(2)
    QTGMC(Preset="Very Slow", EdiThreads=2, FPSDivisor=2) # Choose preset based on overall speed/quality you want. See below for value Y
    bat:
    "D:\Desktop\x264\x264 32 8bit.exe" --crf 18 --preset veryslow --level 3.1 --sar 10:11 -o "QTGMC-Deinterlace2.h264" "D:\Desktop\test\QTGMC-Deinterlace.avs"
    @pause
    x264:
    D:\Desktop\test>"D:\Users\Robert\Desktop\x264\x264 32
    avs [error]: Script error: there is no function named "SetMTMode"
    (D:\Desktop\test\QTGMC-Deinterlace.avs, line 3)
    x264 [error]: could not open input file `D:\Desktop\test\QTGMC-Dein
    terlace.avs'
  28. Take out all the SetMtMode() lines. What happens?
  29. Same thing, it says the problem is with line 3 anyway, which is the first one, but I was wondering about that.
