Hi,
I just realized the video bit-rate is missing in the latest FFProbe output whereas it used to be there previously.
(0.6.1 version)
C:\Rajiv\"C:\Users\Administrator\desktop\FFMpeg\0.6.1\ffprobe.exe" cc.mpg2
ffprobe version N-35462-g61b1d85, Copyright (c) 2007-2011 the FFmpeg developers
built on Dec 5 2011 14:22:27 with gcc 4.6.2
configuration: --enable-gpl --enable-version3 --disable-w32threads--enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r--enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm--enable-libmp3lame --enable-libopenjpeg --enable-librtmp--enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvo-aacenc--enable-libvo-amrwbenc --enable-libvorbis--enable-libvpx --enable-libx264 --enable-libxavs--enable-libxvid --enable-zlib
libavutil 51. 30. 0 / 51. 30. 0
libavcodec 53. 40. 0 / 53. 40. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 51. 0 / 2. 51. 0
libswscale 2. 1. 0 / 2. 1. 0
libpostproc 51. 2. 0 / 51. 2. 0
Input #0, mpeg, from 'cc.mpg2':
Duration: 00:01:00.00, start: 0.224556, bitrate: 11993 kb/s
Stream #0:0[0x1e0]: Video: mpeg2video (4:2:2), yuv422p, 720x512 [SAR 128:135
DAR 4:3], 11386 kb/s, 29.97 fps, 59.94 tbr, 90k tbn, 59.94 tbc
Stream #0:1[0x1c0]: Audio: mp2, 48000 Hz, stereo, s16, 384 kb/s
(1.2 version)
C:\Rajiv\"C:\Users\Administrator\desktop\FFMpeg\1. 2\ffprobe.exe" cc.mpg2
ffprobe version 1.2 Copyright (c) 2007-2013 the FFmpeg developers
built on Mar 28 2013 00:34:08 with gcc 4.8.0 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads--enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls--enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype
--enable-libgsm --enable-libilbc --enable-libmp3lame --enable-libopencore-amrnb
--enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp--enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora--enable-libtwolame --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis--enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 52. 18.100 / 52. 18.100
libavcodec 54. 92.100 / 54. 92.100
libavformat 54. 63.104 / 54. 63.104
libavdevice 54. 3.103 / 54. 3.103
libavfilter 3. 42.103 / 3. 42.103
libswscale 2. 2.100 / 2. 2.100
libswresample 0. 17.102 / 0. 17.102
libpostproc 52. 2.100 / 52. 2.100
DAR 4:3], 29.97 fps, 59.94 tbr, 90k tbn, 59.94 tbc
Stream #0:1[0x1c0]: Audio: mp2, 48000 Hz, stereo, s16p, 384 kb/s
Sample file - http://files.videohelp.com/u/211860/cc.mpg2
Any idea if this is a deliberate change in the newer FFProbe version ? And how can I get the video bit-rate now ?
Thanks,
Rajiv
Inconsistent bit-depth in ffprobe output
By rajivrp in forum Video ConversionReplies: 8Last Post: 21st May 2013, 04:20 -
Overall Bit Rate, Bit Rate with Respect to Quality and Filesize
By kingaddi in forum DVD RippingReplies: 113Last Post: 17th Sep 2012, 21:56 -
What should slide show bit rate and frame rate be in video editor?
By johnharlin in forum Video ConversionReplies: 0Last Post: 11th Sep 2012, 21:00 -
Help Reducing Bit Rate on video
By Aleahsmom in forum Video ConversionReplies: 2Last Post: 28th Apr 2011, 13:47 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53
