Hi
I want to have thumbnails in XnViewMP x64 for mkv-files. Since I've reinstalled Win7 x64 it does not work anymore (I forgot what I did in the last install to get it working) and I don't know what I am doing wrong.
I've only installed Haali Media Splitter and ffdshow x32 and x64 yet. The thumbnails-feature in Haali is activated, but I don't get thumbnails in the Explorer (I don't need them as I use another file manager, but possible that's a hint what's going wrong?).
I found a lot of threads about this topic (generally, not for XnViewMP) but mostly all with the solution to install codec packs, but I don't want to. Hope you can help me...
It probably is a Windows setting that needs to be changed. Go to Control Panel, Folder Options, click on View, and look under Files and Folders to see if "Always show icons, never thumbnails" is check marked. If it is, uncheck mark it and click on Apply.
"Zed's dead, baby."
Icaros, GREAT Explorer Files preview thumbnails presenter
By visible0 in forum Newbie / General discussionsReplies: 2Last Post: 8th Mar 2013, 20:16 -
Windows Explorer Doesn't Display Certain AVI & FLV Thumbnails
By ezehelm in forum ComputerReplies: 1Last Post: 4th Nov 2011, 16:20 -
MKV Thumbnails question
By deadman36g in forum Newbie / General discussionsReplies: 0Last Post: 7th Aug 2010, 05:47 -
thumbnails for mkv files
By runLoganrun in forum Software PlayingReplies: 1Last Post: 8th Dec 2008, 12:51 -
.MKV Thumbnails in Vista?
By evenSong in forum Software PlayingReplies: 3Last Post: 19th Nov 2008, 06:54
