Hi, I am searching for software that can perform video screen capture in Windows 7 with HD resolution, fps and quality settings, AND can be programmed to record per a schedule. Any suggestions off the cuff? Does not need to be freeware necessarily.
I did check the software list for Screenshots but none mention scheduling. Thanks.
Results 1 to 9 of 9
video replay will capture in HD , if your cpu has the speed and memory
never checked to see if it has a scheduling function -
http://applian.com/replay-video-capture/support/user_guide6.php#scheduleLast edited by videobruger; 24th Jul 2013 at 22:23.
Wow@@ That looks like a great program. I was chatting with Applian and they pushed me to their sister software, WM Capture, saying that it had the scheduler. Turns out they both do! Trying to determine the differences. Is it that Replay Video Capture appears to be limited to DVD quality? I will be copying an HD security camera video feed so I plan to cut the FPS way back to save space and keep the image quality up. I am no video expert but WD Capture doesn't actually say "HD" anywhere. Not clear as to their differences. That may take a while.
Great suggestions. THANKS!!! I will contact Applian tomorrow and get all my questions answered and will report back. Both are same price- $40.Last edited by lbblock; 24th Jul 2013 at 22:45.
Acc to Applian, they are the exact same program and do record HD. Now to test it out. I am still checking for backup options just in case. THANKS again!
Well, I emailed back and forth with Applian. I am hoping that you can shed a little light on something. Applian was not very helpful.
My goal is to record about 1/2 of the screen in at least very good quality for 12 hours at a time (I do not jest). Obviously I need to greatly reduce file size while keeping quality up-ish. The settings window gives various options for bitrate, fps, and video format. As far as file size goes, I hope to drop the fps to 3 or 4 but am hoping you folks can assist in my saving a lot of grasping-in-the-dark-time regarding good ranges for bitrate and formats (MPEG-2, MPEG-4 (AVI), WMV and DVD. Thanks!! -
a screen capture is what you need, give camstudio a try. i don't know about the scheduling part. but you did say 3 to 4 frame/sec, for 12 hours, so i guess you could just start it and leave.
also, virtualdub (vdub) has screen capture capatilities too. set the (menu\device\screen capture) and open your security camera in video mode, go into vdub, (menu\video\source) and make necessary changes, set vdub capture dimension to 1280/720 or 1920/1080 or whatever size necessary, then choose the compression codec of your choice in vdub, then press F2 and give a folder/filename.avi, then set the (fps) frame rate in vdub, then press F5 to begin capturing, and then point your mouse to the other video windows playing the security camera feed. when finished, go back to vdub (select its window) and press the ESC key to stop the capture. then just open the file.avi in another vdub and review it. use v1.9.11 or above for all this.
if the capture software does not show up in vdub's capture window (may be a black screen due to overlay mode) then, you will need to force it into 'preview' mode, if possible. otherwise, you will have to close down the security camera window completely, then open another player window of your choice and play something in it (and minimize it) while you restart your security camera window, then see if you see a video in vdub's capture window. if you do, then proceed to capture.
Capture software for video capture cards that allow to use external filters
By Milardo in forum Capturing and VCRReplies: 7Last Post: 8th May 2013, 23:35 -
Small University Broadcast Station, need help on scheduling software
By gooberguy in forum Video Streaming DownloadingReplies: 0Last Post: 15th Nov 2011, 22:59 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 07:17 -
Which video capture software??
By DJ12345 in forum Capturing and VCRReplies: 2Last Post: 23rd Feb 2010, 10:42 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26
