I'm currently using DGMPGDec, but is there a better program for the job? The file contains closed captions. After encoding the Audio (I plan on using ffmeg to encode the audio to aac, unless someone suggests something better) and Video I'm planning to mux them into a mkv. Will the closed captions still be attached or do I need to extract them and remux them?
General
Complete name : D:\video.mpg
Format : MPEG-PS
File size : 460 MiB
Duration : 21mn 29s
Overall bit rate : 2 994 Kbps
Writing library : (c) 1998-2010 Womble Multimedia, Inc. / MPEG Video Wizard DVD 5.0.0.114 (01/2010) / Jan 5 2011
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Duration : 21mn 29s
Bit rate mode : Variable
Bit rate : 2 742 Kbps
Maximum bit rate : 2 904 Kbps
Width : 704 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.271
Time code of first frame : 00:00:00;00
Time code source : Group of pictures header
Stream size : 422 MiB (92%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Muxing mode : DVD-Video
Duration : 21mn 29s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 29.5 MiB (6%)
Text
ID : 224 (0xE0)-CC1
Format : EIA-608
Muxing mode : A/53 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
Menu
Main problem is that EIA-608 subtitles are part of the MPEG-2 user data and not a normal separate stream.
You might want to read https://forum.videohelp.com/threads/341312-How-to-extract-Close-Captions-%28EIA-608%29-from-ts
-> you have to extract and convert these EIA-608 subtitles to srt if you want to add them to an mkv file
Demuxing an flv file over 1 GB
By Alex_ander in forum Video ConversionReplies: 3Last Post: 25th Jun 2013, 15:08 -
Need help demuxing a M4V file
By FulciLives in forum Video ConversionReplies: 1Last Post: 8th Aug 2011, 01:18 -
Problem with demuxing .ts file
By iXed in forum DVB / IPTVReplies: 5Last Post: 8th Aug 2010, 09:14 -
Demuxing a TS file
By carlmart in forum Video ConversionReplies: 17Last Post: 29th Jul 2009, 15:04 -
How to cut a TS file with Projectx without demuxing?
By Talayero in forum DVB / IPTVReplies: 2Last Post: 12th Apr 2009, 19:23
