ok guys, here is the original and some test encodes, as i said this is from one of my go to test files as i find it one of the more difficult to get good results with. i used avidemux to open the vc-1/wmv source and cut a 16 second clip that is within this forums rules and used an avi container.
a few notes, the source has an average bit rate of 12mb/s but the portion i cut is listed as 7mb/s and if you calculate the file size it is in fact 7mb/s so all my tests were done with the test encoders being set at average bit rate of 7mb/s. some of the encoders undershot and the source files seems to be primarily composed of b frames.
as for the results to my eyes all the test encodes suck, i tested with xvid and vp8 within Hybrid, ffmpeg mpeg-4 and qs within handbrake and i used xvid4psp to do 8 bit and 10 bit x264 test encodes with all the quality settings maxed out.
i would have tested with vp9 but i can't get it to work on my system, so if Selur or someone else wants to do a test encode with vp9 with all the quality setting maxed out i would be interested in seeing how it turns out.
as it stands now, the test encode i did with Strongene's h265 encoder just beats everything else hands down.
i will also be uploading a few main concept test encodes so you guys can see what a quality encoder can do.
Results 61 to 72 of 72
This may sound and may be "off-topic", but I think it's absolutely necessary.
Avidemux for dealing with ASF files? VERY-BAD idea. "rws_asa.avi" was muxed and indexed incorrectly. All frames are marked as keyframes, and it's impossible to extract from it a well-formed .VC1 file (elementary stream). Besides, the AVI container is not suitable for Windows Media Audio. You really should have used AsfBin instead.
[ end of just-my-2-shillings ]Last edited by El Heggunte; 23rd Aug 2013 at 08:44. Reason: grammar
I'm a bit confused why you would choose (compared to the source) such a high bit rate for the reencodes?
I mean non of these codecs are normally ment as intermediate format.
Wouldn't something along 1500 or lower been a better choice if we look for compression efficiency?
Or are you aiming to look for transparency at similar bit rate?
btw. strange choice of parameters for x264, looks like:
with a target bit rate of 7000.Code:x264 --profile high --level 5.2 --ref 5 --no-mixed-refs --min-keyint 25 --bframes 5 --b-adapt 2 --qpmax 21 --no-fast-pskip --no-dct-decimate --me umh --subme 11 --trellis 2 --aq-mode 2 --cqm jvt --threads 12
Especially deactivating mixed refs, seems strange to me, but I'm sure you chose what you deem to be best/maxed out.
It would be nice to see an example of the output of the mysterious H.264 encoder which is better than x264.
btw. personally I would have chosen something more a long the lines of:
http://vimeo.com/66124969
Cu Selur
Ps.: encoding VP9 at FullHD is just too slow for my taste to test at all atm. -
My chantingel from The City of Angels has provided me few samples which I would like to cite here for purely educational purposes. If I do not post here, probably you will never get them anywhere else. Probably you will never know what Quality means. To some these may help to learn artifacts,to some these may help to understand how they are being sucked, and to some these may help to improve up on. Your inputs and feedbacks are always welcomed.
I could have decided to remain silent, as I already have the things I need.
But, you will never know the difference.
SAMPLE-1
Sample-Frame-433.mp4
If you l@@k @ frame#433 in above sample, it is something like the pic posted as under:
Where as, the encoder chopped off the fingers of forearm with bent wrist. Or, someone's else organ attached to her near elbow. Plus, whole sample contains tons of variety of artifacts. I have already given-up restoration on sample with tons of artifacts and lots of missing details. Still you can try. and waste your energy and time in restoring and re-encoding.
I would be highly interested to know about mathematical model that chops off lots of details or attach someone's else organ to someone else. Do not expect me to tell you the answer of 1+1 coz I do not know either. I luv to do my assignments only.
Following two samples definitely look better than (???) to me for sure.
SAMPLE-2
SAMPLE.GooD.mp4
Good enough. Fair Quality. Preservation of lots of details. No grains!!!
Nice mix of Compression and Quality.
SAMPLE-3
Sample.HiQ.mp4
Simply HiQ.
We everyone would like to have tool like Hanzo's Samurai.
You can download all these samples, and see the difference.
You can also carry on post-mortem, It will lead you in the right direction, I hope.
If so, it will definitely help lots of people who need tools like Hanzo's Samurai.
Otherwise, please do not waste time! please! bcoz...
Most of the time broken and handicapped tools are distributed on very specific and definite purpose.
i HATE broken and handicapped tools.
Your feedback/inputs are always welcomed.
PS: I would like to request my chantingel to provide me both source and full-length encoded files.Last edited by enim; 10th Sep 2013 at 02:25.
As one of the foundation stone for HEVC says
I would LuV HEVC on the day on which HEVC can encode above my samples at half bitrate. Otherwise it's wasting cpu power, energy, time and other resources. Till then...HEVC is said to double the data compression ratio compared to H.264/MPEG-4 AVC at the same level of video quality. It can alternatively be used to provide substantially improved video quality at the same bit rate. -
I would LuV HEVC on the day on which HEVC can encode above my last two samples at half bitrate. Otherwise it's wasting cpu power, energy, time and other resources. Till then...HEVC is said to double the data compression ratio compared to H.264/MPEG-4 AVC at the same level of video quality. It can alternatively be used to provide substantially improved video quality at the same bit rate. -
Only x265 will be worth when we will see realtime encoding 4k ultrahd on quad or eight core machines. Thenafter all the comparison of such kind is worth mentioning. x264 is more than realtime on my quad core pc with 1080p encoding. At present x265 is too slow for any comparison.
been doing some test with the latest naughty build of handbrake and a 1080p full hd sample clip and in my test i can get the bitrate down to around 1800VBR and it looks the same as the original blu-ray 1080p clip but using x264 the bitrate needed to be 3100vbr
i am loving h265Last edited by jamespoo; 5th Sep 2014 at 04:22.
Zones
Is there any switch or method in x265 to specify zones like --zones in x264 ?
tom?
users currently on my ignore list: deadrats, Stears555, marcorocchini -
x265
--zones <start frame>,<end frame>,<option>/
<option> is either q=<integer> or b=<float>(bitrate multiplier)Last edited by movmasty; 10th Jan 2016 at 03:05.
MulticoreWare Annouces x265/HEVC Mission Statement
By enim in forum Latest Video NewsReplies: 4Last Post: 9th Aug 2013, 22:09 -
show x264 command line output when using megui as x264 gui
By codemaster in forum Video ConversionReplies: 4Last Post: 12th Mar 2013, 10:35 -
Xvid vs x264 -- Bit Rate: 1900 kbps -- Same quality but smaller x264 file?
By kingaddi in forum DVD RippingReplies: 17Last Post: 2nd Sep 2012, 11:45 -
Bitrate vs Size Calculator for x264 for ripping DVD to x264 + AC3
By Bonie81 in forum DVD RippingReplies: 7Last Post: 5th Jul 2010, 18:24 -
x264: -1920, -ESiR, -SEPTiC, -CiNEFiLE.... What are these x264 extentions?
By NWNewell in forum Newbie / General discussionsReplies: 7Last Post: 18th May 2009, 17:10
