When I exported some videos from Mercalli Stabilizer stand alone version recently, I noticed if I choose ATI Avivo mpeg 2 codec from the list, the export is quite fast, and gives similar results as if I would be using WAV progressive, but the file is much smaller yet has good quality. The problem is the codec only allows setting 20 Mbps as max bitrate. Can you suggest a similar codec that allows more, up to 28 at least? The advantage of this codec is that it is fast, and the opuput file has similar size as the input H.264 mp4 from my camcorder. And the quality is just almost as good as the original, however I guess because of the 20 Mbps, it is a bit lower.
That is not a possible way now. I need codecs that Mercalli can see after I install them. The problem with these Ati Avivo codecs is that you cannot type a value for bitrate manually, only choose from presets. I am not an expert on codecs, I am not sure which one could allow you to type a value for bitrate manually.
You could export as a uncompressed AVI then encode with one of the above codecs.
Please suggest a good (simple) video editor program
By chrisj in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2013, 05:36 -
Which Mpeg2 compression codec?
By yugurya in forum EditingReplies: 6Last Post: 20th Jan 2012, 01:35 -
Please suggest good AviSynth Anti-Aliasing & Rainbow Remover scripts
By VideoFanatic in forum RestorationReplies: 0Last Post: 30th Nov 2011, 07:54 -
whats a good codec pack
By bmzxzx in forum Newbie / General discussionsReplies: 29Last Post: 7th Jun 2009, 19:58 -
Good codec -- Need Advice
By Bacender in forum Newbie / General discussionsReplies: 4Last Post: 14th Jan 2009, 03:36
