I have been having major problems trying to encode divx > s/vcd using TMGPenc.
I have been using WinXP Pro on a NTFS file system, while the files to be encoded are sitting on a 7200rpm drive.
The project NEVER finishes - usually hangs up at 50-80%
I have also tried on Win98SE - same result
My question is - Wouold i have any better results if I went to Win2K on a NTFS
My System
-P3 667
-192 SDRAM - YUK!!!!
-30 GB 5400 rpm drive
-80 GB 7200 rpm drive
-ATI All-In-Wonder PCI
" I am the one which you do not want to see, becasue I am the one which makes you see yourself" H.R.
i would say Increase your memory atleast to 256 but reocmend 512. i thint it costs around only 50 $
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 17:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 20:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
