I'm a complete newbie about that subject so any information about it will be useful. Thanks in advance.
Results 1 to 15 of 15
A 3-D Blu-Ray disc, 3-D capable Blu-Ray player, a 3-D capable TV set, and the right pair of 3-D glasses.
Is there any device to be used along with a HDTV that can do the job of a 3D TV set? 3D TV sets are quite expensive.
No. It is not possible to change a 2D flatscreen TV into a 3D flatscreen TV by purchasing a kit or a separate device. In addition to the electronics needed for processing and displaying 3D video, for passive 3D, the TV needs to have a special polarizing film, or for active 3D, the TV needs to have an IR or RF emitter to sync active shutter glasses.
Well that explains why I never heard of them. HDFury's products aren't available in the US. 3D Now is fairly new.
[Edit] ...but 3D Now's product is available here. http://www.amazon.com/3DNOW-Theater-Processor-Eyewear-Starter/dp/B009E7WDLO
Some new 3D TVs cost less.Last edited by usually_quiet; 23rd Jul 2013 at 10:06.
I searched Amazon and found some 3D converter boxes priced between $33.99 to $49.99. Do you have any idea if those ones will also do the job?
How come it looks 3-D when I see whole universe with bare naked eyes, except videos?
It looks way more beautiful than 3-D videos. I believe HE is the perfect designer. -
The inexpensive converters are for use with anaglyph glasses, like those used in movie theaters in the 60s with one amber or red lens and one blue or cyan lens. The most expensive boxes like the 3D Now product use active shutter glasses like the more expensive 3D TVs.
The inexpensive boxes can give a 3D effect but not the same quality as what a real 3D TV would provide. I do not think I could recommend any of them. If you read the user reviews, some buyers liked them, but others noted that colors looked wrong or too pale. -
If you play the 3D disc on a computer, with the right video driver / software combination, you can use the above mentioned anaglyph if you have a 2D monitor.
The 3D output (please correct me / add info if there are other ways) splits the image vertically, and therefore halves the resolution 1920 / 2, in order to present the left and right eye. When output, this is then sent out again full screen, and mixed using the anaglyph colours.
Some software / video drivers let you choose the colour and separation for each eye. I am looking to do more testing personally, but have not seen, nor read, very good results from this method. -
That makes sense. A 120Hz TV is needed instead of a 60Hz TV for active shutter glasses to work well. As Wikipedia explained: "Frame rate has to be double that of a non-3D, anaglyph, or polarized 3D systems to get an equivalent result. All equipment in the chain has to be able to process frames at double rate..."
Also effectively halves the brightness (or rather, the amount of light getting to each eye) , but Hey, some people like it
VLC Blu-ray plugin - Watch encrypted Blu-rays directly in VLC 2.0+
By Baldrick in forum Latest Video NewsReplies: 63Last Post: 23rd Feb 2014, 21:34 -
Blu-ray chapter info needed
By ratatouille in forum Blu-ray RippingReplies: 2Last Post: 14th Jun 2012, 09:42 -
Blu Ray slowly gets more out of sync longer you watch it... Using Leawo
By bigt85 in forum Authoring (Blu-ray)Replies: 10Last Post: 24th Jan 2012, 05:05 -
Blu-Ray Subtitles (Only when they are needed, not all the time)
By nexus69 in forum Blu-ray RippingReplies: 2Last Post: 23rd Apr 2010, 11:11 -
Is it possible to watch Blu Ray movies on your HD TV using your...
By pwangdel in forum Software PlayingReplies: 2Last Post: 2nd Nov 2008, 17:46
