I have been using several programs to convert "any" format to MPG for burning to DVD. TMPEnc does not seem to work the best so I usually revert to Ulead Video Studio. These files then get burned as DVD's without any problems. Occasionally, the ending file size is greater than 4.5GB, which is an obvious problem.
Does anyone know of a way to reduce the size of the file just enough to fit on the DVD?
Results 1 to 1 of 1
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
mpg image wrong 'size'
By HMH in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 16th Sep 2010, 17:49 -
mpg-2 to ??? size and quality
By l4l4u in forum Video ConversionReplies: 4Last Post: 6th Nov 2009, 16:43 -
MPG File Size and/or Timing Help
By GearBeer in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2009, 12:21 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50
