Hi,
I must create a file video:
file extension. ts PMT PID 32 PCR PID 34
video track:
PID 34
codec H.264/AVC
profile High@4.0
mode: interlaced
framerate: 25
bitrate 3.500 Kbps CBR
GOP SIZE 12
GOP STRUCTURE 3 BBP
audio track 1
pid 36
language ISO 639-3
codec AC3
bitrate 224 Kbps
sample rate 48 Khz
mode 5.1
audio levels range -23/-24 dB LKFS
audio track 2
pid 38
language ISO 639-3
codec mpeg 1 layer II
bitrate 192 Kbps
sample rate 48 Khz
mode stereo
audio levels range -23/24 dB LKFS
HELP!!!!!??????
If your video is .ts, you already have a video file, encoded with h264. It might be helpful if you tell us where the file came from and what you're trying to do with it.
The only thing one can gather from the information given is that you have an interlaced PAL MPEG2 video in a .ts container. When you say you want to "create a transport stream" we still don't know what your intended output is supposed to be. Are you trying to create a video for internet display, burn to disc, author to BluRay, DVD, re-encode as AVCHD? There are any number of ways to encode a ts video. Are you cutting and joining clips, denoising, or what?
Probably for cable/ip-tv? Or?
You could convert to h264 with a x264 encoder frontend. BUT I guess it will be hard to get the ts muxing done correctly. -
Just a wild guess, but that looks like a "homework" given by a very-lazy teacher
I know ffmpeg and ffmbc can mux to TS, but I'm not sure how norm-compliant (or playable) the results can be, though.
Code:audio track 2 pid 38 language ISO 639-3 codec mpeg 1 layer II bitrate 192 Kbps sample rate 48 Khz mode stereo audio levels range -23/24 dB LKFS
MP2 @ 192kbps MAY sound OK if encoded with twolame.
I don't know how to achieve "audio levels range -23/24 dB LKFS"
5.1 AC3 @ 224kbps means *garbage*Code:audio track 1 pid 36 language ISO 639-3 codec AC3 bitrate 224 Kbps sample rate 48 Khz mode 5.1 audio levels range -23/-24 dB LKFS
Stream Transport
By Soixante in forum ComputerReplies: 4Last Post: 4th Apr 2014, 05:05 -
TS Transport Stream Stream length vs. filesize
By Allan Ross in forum Video Streaming DownloadingReplies: 8Last Post: 27th Sep 2012, 07:28 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 04:40 -
MPEG-2 Transport Stream
By avsubvert in forum Video ConversionReplies: 2Last Post: 7th Aug 2009, 11:39 -
Re-encoding MPEG2 Transport Stream (.ts) file
By kary.sharma in forum Video ConversionReplies: 2Last Post: 12th Dec 2008, 04:01
