Results 1 to 10 of 10
  1. Hi there
    I have some Blu-Rays that I want to get rid of various extras from the discs, but not to re-encode. BD Rebuilder wants to do that, & I then found a link to Clown BD, but it seems to use other programs that no longer seem to exist?
    What do I do?
    William
  2. Clown BD will do that.
    Or you can use BDtoAVCHD and use the BD remux selection and it won't encode or you can rewrap it with mkv remux selection.
    You will get only the main movie using this program.
  3. I've just started to use Clown BD & there's no option to remove extras?
  4. I am not that familiar with clown bd, bdtoavchd is easier to use.
    Nov 2003
    West Texas
    If you don't want BD Rebuilder to re-encode the video, add this line to your configuration file: FORCE_NOENCODE=1
    You can find the configuration file by clicking File-->View/Edit Config File. With the no encode line added, BD Rebuilder will never re-encode the video, so if you ever want to use the program normally, you have to manually remove this line from the config file.
    Clown BD will give you a main movie only output, with your choice of video, audio and subtitle streams. No encoding with it either.
  6. Thanks for that info, Kerry. I will do what you suggest. Clown BD is running at the moment (It never gave me any options to select), so I'm waiting to see what the outcome is. I suspect BD Rebuilder is better, since I can see the options prior to creating the disc.
  7. Clown BD is crap for converting TV Shows! After running it, only one episode remains!
  8. Member wulf109's Avatar
    Jul 2002
    Change custom target size to 50,000 in BDRB would also prevent video encoding? Then do movie only.
  9. Originally Posted by wulf109 View Post
    I found this reply during some googling on the titled subject.. tried isng BD-RB with 50,000 for a movie that is under 20,000... BUT BD-RB still wants to re-encode
  10. Hi there, not sure if you found a solution but another solution would be to use DVDFab.
