Results 1 to 9 of 9
  1. I've been informed that the dvd's I make have audio issues. When watching them in Windows 8, they sound fine, but as you play them back in older versions, the audio level of the dvd decreases. Playback in 7 isn't as loud as it is in 8, and when playing these dvd's in XP, there's no sound at all. I've never heard of this issue. Is there anything I can do other than check sound card drivers to minimize this problem? Any help is appreciated.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    What media players are being used?
    I recommend using vlc or mpchc as they have internal codecs.
    Also when you say dvds are these regular dvds ie video_ts folders and all that? Or are these dvds with video files like h264 in a mkv file type videos?
    Either way there should be some sound if it plays in one windows version.
  3. The disk I just checked does have both folders.
  4. Mod Neophyte redwudz's Avatar
    USA
    The AUDIO_TS folder is rarely used and you can leave it out most times as it's empty. The audio is in the VOBs in the VIDEO_TS folder.
    In order to be DVD complaint, you have to adhere to the DVD specifications. You can see them to the top left of this page in 'WHAT IS' DVD. Basically, this is what it says about audio:
    Audio:
    48000 Hz 32 - 1536 Kbit/s Up to 8 audio tracks containing DD (Dolby Digital/AC3),
    DTS, PCM(uncompressed audio), MPEG-1 Layer2. One audio track must have DD or PCM Audio.
    What I would check is what format your sound is. Open one of the VOBs on one of your DVDs with Mediainfo, Tree view and post the results here.
    XP didn't come with a MPEG player for DVDs. It would have been added on. Vista and W7 have one built in. W8, for some unknown reason, doesn't have one either, if I recall correctly.
    I would recommend if you want to playback on most PCs is that you just include a copy of VLC Portable player on your discs. It doesn't install on their PCs and it plays most anything: http://portableapps.com/apps/music_video/vlc_portable
    And welcome to our forums.
  5. I don't have one of the dvd's currently available, but I used Mediainfo to analyze the source file I used last week. Here's what it says on the audio portion (if this helps):
    Audio
    Menu ID :
    1 (0x1)
    Format :
    AC-3Format/Info :Audio Coding 3
    Mode extension :
    CM (complete main)
    Format settings, Endianness :
    BigCodec ID :129
    Duration :16mn 22s
    Bit rate mode :
    ConstantBit rate :256 Kbps
    Channel(s) :2 channels
    Channel positions :Front: L R
    Sampling rate :
    48.0 KHz
    Bit depth :
    16 bits
    Compression mode :
    Lossy
    Delay relative to video :-84ms
    Stream size :
    30.0 MiB (2%)
    When I make another one, I will post that one here, too.
    Nov 2003
    West Texas
    ^That's bog standard AC3 stereo audio, which should be acceptable in any dvd player.
    What did you use to make the dvd-video?
  7. I'm currently looking around for a new program that's easy to use. I'm using Power Producer 11 right now, but I've used Nero 7, 9, 12, Pinnacle Studio 11, Visual Studio x6, and several that wouldn't run, were too difficult to use, or would watermark because it was a trial version. I am open to suggestions.
    Mar 2008
    Near the Beach
    Windows XP doesn't have a native ac3 decoder, maybe that's why there's no sound. Use the players, yoda313 in post #2 recommended.
    Loudness depends of how the decoder is set. In Windows Media Player check the settings (loud ambient, theater, noisy ... can't remember all)
    Feb 2004
    Australia
    "but as you play them back in older versions, the audio level of the dvd decreases"
    If this comparison is about different os's not running on the exact same hardware then your comparing tomato with potato.
    Not all systems audio chipset's and there drivers are equal ... and that includes speakers used ... some just perform better than others.
    For xp install ac3filters to solve the no audio issue.
