Anyone here use Pinnacle Studio Ultimate 16? Need some advice on hardware... Got a new rig :
i7 4770K
Asus z87-K
8 GB GSkill Ripjaws 1600Mhz
Samsung SSD 120 GB (OS and apps)
WD Black 1TB (media and render)
750W Corsair PSU
Pioneer BRW
Im using the intergrated GPU HD4600 from the i7.. and the system runs Pinnacle fine, if not great? Using any format from mp4/mov 1440x1080 or 1920x1080 .. renders fast too. No hiccups on the timeline projects I see or find. My question is should I spend $ on a GPU? Pinnacle says that it does take CUDA cards now.. but I'm not getting a straight answer from their board on if it has any benefits and if it does where would I see it? Adding effects/rendering etc.. What should I do, stick with what I have? I know Pinnacle is not Vegas/Premiere/AE etc.. so a Quadro card is definitely not needed.
GPU encoding is not considered particularly effective with any software. I wouldn't bother with a graphics card for that reason, but there are of course other benefits ...
what you referring to, gaming for i.e? Won't be doing anything but pinnacle and office / surfing on this machine. So anyone else tested pinnacle 16 with a gpu vs intel i7?
Use the 4770K's QuickSync encoder. It's much faster than CUDA, no matter what Nvidia card you use. And equally bad quality.
How do I know if intel quick sync is enabled or better yet used by pinnacle? BIOS setting? pinnacle setting? Is it on automatically in BIOS if you have no discrete GPU? I have the asus z87-k and DVI cable from monitor to mb.
On a side note does using an HDMI cable make any difference on display over DVI? Resolution shows up 1920x1080. -
Wingfan, did you ever get an answer to whether quick sync was enabled?
Brainiac
PLEASE HELP ME!!!! Pinnacle studio 15 HD
By afrika video in forum Authoring (DVD)Replies: 5Last Post: 2nd Mar 2013, 07:57 -
Pinnacle studio tutorials
By lennylion in forum Video Streaming DownloadingReplies: 2Last Post: 7th Feb 2013, 14:40 -
Pinnacle Studio 16 Ultimate
By Darin in forum Newbie / General discussionsReplies: 1Last Post: 16th Nov 2012, 05:41 -
Pinnacle Studio - 2 Menu's.
By Apple 3.14 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jun 2011, 18:34 -
AVI on Pinnacle Studio 14
By jhughes2466 in forum Video ConversionReplies: 4Last Post: 8th Nov 2010, 06:12
