Looking forward to buy 24จจ+ LCD (WHUXGA or HXGA) full specs HD monitor. Any suggestions?
Results 1 to 14 of 14
Planar UltraRes Series has 4k (= HXGA) but is not 24" but 84"
Sony XBR Series has 4k for 55", 65" and 84"
there might be smaller once which are labeled as medical equipment,...
Btw. do you have a graphic card which offers WHUXGA or HXGA output? -
my brother in law bought a 27" from Monoprice.com for less than $360 .27" IPS-ZERO-G Slim Monitor WQHD 2560x1440 - Dual Link DVI, VGA NO HDMI.30" goes for over $700. not sure if this what u are looking for.
http://www.monoprice.com/products/product.asp?c_id=114&cp_id=11401&cs_id=1130704&p_id=...seq=1&format=2
one more from ebay
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=121117252582
amazon reviews
http://www.amazon.com/QNIX-QX2710-LED-Evolution-2560x1440/dp/B00BUI44US -
@MJA: WQHD is 2560ื1440 he was looking for WHUXGA (7680ื4800) or HXGA (4096ื3072)
very smart guy.aedipuss
depends on what it's used for. video editing, photoshop, games, word processing...you caught me. Even though my monitor 4096x2160 max and graphic card 3840x2160 max, I am still running short on bottom-low hardware resources for true full specs 4k and 8k resolution.Selur
OOOOooooooooooooooops!MJA
woow .I got owned.lol
Wake me up, if you guys come across any time in near future.
Till then ... -
@MJA: Nope.
3,840 x 2,160 is the max that his current graphic card supports, but it's still not 4096x216
32" is a nice size, but he was looking for a 24" monitor. -
Making an 32-inch LCD display with pixels that are small enough for 3840 x 2160 is difficult enough. No 24-inch 4096x2160 monitors have been released yet or are likely to be in the near future.
The two 3840 x 2160 (Dell and Asus) monitors I saw that will be released this year are 31.5-inch screens. These 32-inch monitors are made using a different material than a normal LCD monitor would use to allow pixels to be made smaller. They use Indium Gallium Zinc Oxide (IGZO) instead of the usual amorphous silicon for the active layer of the monitor. Asus is accepting pre-orders now, with a pre-order price of $3500.
The only 4096x2160 monitor Google found for me was EIZO's DuraVision FDH3601-BK LED monitor, but it has a 36.4" screen. It costs a mere $21,600.00.
[Edit] When I looked at the catalog for the company selling the other EIZO monitor, it actually lists a second 4096x2160 36.4" color monitor, the EIZO RadiForce RX840-MG - LED monitor, which is only $29,000.00.Last edited by usually_quiet; 24th Jul 2013 at 12:59.
My video work-bench needs at least three of them and even running short for 8k resolution. I would prefer to get another brand new benz for my better-bitter-half.The only is 4096x2160 monitor Google found for me was EIZO's DuraVision FDH3601-BK LED monitor, but it has a 36.4" screen. It costs a mere $21,600.00.
Wouldn't it be easier and cheaper to simply go for a multi-monitor setup?
HD Monitor or HD Tv ?
By DB83 in forum ComputerReplies: 55Last Post: 6th Apr 2013, 14:23 -
premiere 6 upgrade, section of project missing after upgrade
By krohm in forum EditingReplies: 0Last Post: 9th Jan 2013, 23:12 -
Using monitor instead of TV
By Ketman in forum DVD & Blu-ray PlayersReplies: 9Last Post: 18th Mar 2010, 07:10 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
PC monitor as a TV?
By Lee82 in forum ComputerReplies: 5Last Post: 20th Feb 2009, 10:28
