HI!
I'm trying to encode some footage into divx but keep on having problems with audio syncing.
I capture them in avi ( Huffyuv codec), locking the video to audio. When I convert them to mpg1, they're perfect but when I tried encoding them to divx ( v4.12 or xvid ), they'll gradually lose sync problems over time. What gives?
My footage is about 2 hours + and my system specs is as follows
P4 1.6ghz oc to 2.1
Asus P4S333
512mb DDR
20gb IBM Hdd
60g WD Hdd
Aopen 40x cd-rom
Creative SB Audigy
Pinnacle Studio Vcd
Any help rendered woukld be appreciated.
And yes, the overclocking is not affecting anything. No temperature changes using the default HSF.
I have a similar problem. I encoded an MPG from a DVD, and when I use mediaplayer, the sound gets out of sync with the video. The video seems to play faster than the sound.
But when I used my creative DXR3 or PowerDVD, the sound and video match perfectly
Audio/video out of sync after converting (avi to mp4)
By Foxy Gogo in forum Video ConversionReplies: 1Last Post: 10th May 2010, 12:13 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 12:56 -
MPEG to Divx audio sync problem
By starless in forum ffmpegX general discussionReplies: 8Last Post: 11th Oct 2007, 04:38 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
