Results 1 to 11 of 11
    Sep 2011
    Serbia
    is any way to remove macrovision on dvd recorder WEG 5050 (with hdd 160gb) ?
    tnx advance
  2. Member DB83's Avatar
    Jul 2007
    Whatever a WEG 5050 is, I assume you are attempting to dub from a copy protected dvd to the hdd of the recorder.
    Forget it. The disk may not even be macrovision protected. Use standard PC based ripping methods.
    Sep 2011
    Serbia
    I think on recording programs from analog Тv, some programs have protection
    sorry for my very bad english
  4. Banned
    Freedonia
    It sounds like a "Do not copy" flag and not Macrovision, but analog TV is not supposed to have this.
  5. Member DB83's Avatar
    Jul 2007
    Back in the days when your satellite tv (Sky) was analog, they had premium services - Sky Box Office Movies - and they did broadcast some sort of signal to prevent recording. They are now digital and still have the same premium services but I have no idea whether recording is prevented but I would expect it is.
    Sep 2011
    Serbia
    message appears "protect", same things on LCD TV (with used analog tuner) and on old Crt tv
    is any way to fix it without payment ?
    sorry for my english again
  7. Banned
    New York, US
    I don't think anything that comes over the O.P.'s provider is analog. Most cable companies have switched to digital, and even my old digital SD box has copy-once imbedded on many channels (TBS, History, USA, Science, NatGeo, TNT, Disney, etc.) -- I'm using analog s-video out on that box.
    Sep 2011
    Serbia
    on this weg5050 protect is some world tv stations: eurosport 2,
    history,Natgeo Wild (I understand that), some national, even 3 local channels from my city,
    total 20-21 from all 60 channels on my cable TV.
    Connectors only scart and composite av (no s-video).
    On my old (now broken), LG dvd recorder everything was fine, (at least on crt tv),
    all channels were available for recording.
    This is Weg5050:
    http://www.takolako.rs/user/divx-dvd-uredjaji/weg-dvd-rekorder-dvr-5050-hdd/44_2122_35...1_0_0/item.jsp
  9. Banned
    New York, US
    Older DVDR's might have worked in the past, but copy-once is constantly being added to more channels since that time. A little over 2 years ago I used an expensive HD tuner that picked up channels directly off the cable line and could record 4:3 SD with a 16:9 display aspect ratio on HD broadcasts. Those days are in the past. Today that tuner is useless for cable pickup. There are PVR's available today that can record HD and SD out of the cable box and most of them ignore copy protection (Macrovision, I believe, is no longer used. Newer methods have been developed to control what you do). But the new PVR's work with computers, not with DVD recorders.
    Nov 2000
    Canada
    Newer recorders will have protection enabled for many premium and other channels. A Grex might be able to remove the protection but it's an extra piece of equipment you would have to purchase. Your best bet is to see if you can find the same model as you had before or ask in a forum inside your country if anyone else had this problem and how to solve it. Many of us have had to move along to other means like using computers and specialized recording equipment in order to do what you are requesting. It's not as simple as it was years ago.
    Good luck...
    Sep 2011
    Serbia
    ps- my mistake - I have not read answers
    thanks, i find a solution
