I want to re-convert my aac file but i didn't manage it.Are there any lib files for enable them?
your ffmpeg version needs to be build to support this, just having some external library isn't enough
(personally I use https://github.com/rdp/ffmpeg-windows-build-helpers to build ffmpeg for Windows within a Ubuntu Virtual Box image) -
I used this file from GitHub...
https://github.com/nu774/fdkaac_autobuild
https://github.com/nu774/fdkaac_autobuild/archive/master.zip
Just follow the install instructions
FFmpeg Runtime error / FFmpeg git-df82454 32-bit Static (2012-10-03)
By MashedPotatoes in forum Newbie / General discussionsReplies: 5Last Post: 6th Oct 2012, 17:22 -
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 04:11 -
Which ffmpeg options are used behind the scenes by ffmpeg?
By roberto.aloi in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2011, 05:09 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 12:04 -
Difference between ffmpeg -threads and ffmpeg-mt
By Calidore in forum Video ConversionReplies: 2Last Post: 7th Mar 2010, 22:44
