Tried converting some mkv files for a friend, but it failed, and said something about excessive bitrate. Any help would be welcome. Fairly certain I used all the default settings, except changing the output folder and setting it to burn to DVD.
Log Files:
DVD_0
<20/7/2556 17:58:45>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 3
DVD Size: 3821/4450 MB (86%)
DVD Output Setup: Burn DVD
DVD Label: DVD
DVD Menu: No Menu
Output Folder: D:\Videos
Delete Temp Assets Files: Yes
Delete Temp Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Video Source Filter: A2DSource
AVS Audio Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
Frame Adjust Strategy: 1
PAL SpeedUp: 0
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): JA - Japanese
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 18pt (255,255,255)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: E:\
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Unload ActiveMovie library: 0
Adjust ffdshow at runtime: 1
Save General Settings: 0
TITLE 1 SOURCE FILES
Video: G:\Anime\Durarara\Durarara 04.mkv
Info: AVC - 700 kbps - 1280x720 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 24:29 minutes - 35234 frames
Audio 1: G:\Anime\Durarara\Durarara 04.mkv
Info: Vorbis - 48 kbps - VBR - 1 ch - 48000 Hz - 24:29 minutes (0 ms delay) - JA
Subs 1: G:\Anime\Durarara\Durarara 04.mkv
Info: SubStation Alpha (SSA) - JA
[MediaInfoLib - v0.7.61]
AVISYNTH SCRIPT
Import("D:\AVStoDVD\Lib\A2DSource.avsi")
LoadPlugin("D:\AVStoDVD\Lib\ffms2.dll")
Video = A2DVideoSource("G:\Anime\Durarara\Durarara 04.mkv", CacheFolder="C:\Users\ADMINI~1\AppData\Local\Temp" , FrameRate=23.976, VFR=false)
# Forced 'FFAudioSource' to extract secondary Audio Tracks
Audio = FFAudioSource("G:\Anime\Durarara\Durarara 04.mkv", track=2, cachefile="C:\Users\ADMINI~1\AppData\Local\Temp\A2 DFFA_" + String(Rand()) + ".cache")
Video = Video.ConvertToYV12()
Video = Video.Spline16Resize(720,480)
#Using DGPulldown/HCenc to upsize FPS
Audio = Audio.ConvertToMono
AudioDub(Video, Audio)
<20/7/2556 17:58:46>
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 1-pass
Target Video FileSize: 1226.7 MB
Encoding Parameters: -ini "C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_ 01_Durarara 04.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_0 1_Durarara 04_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Administrator\Videos\DVD_0_Title_01_Durar ara 04.m2v
*LOGFILE C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_0 1_Durarara 04.HCenc.log
*MAXBITRATE 9000
*1PASS
*BITRATE 7000
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 70
*DC_PREC 10
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*DBPATH C:\Users\ADMINI~1\AppData\Local\Temp
*WAIT 2
<20/7/2556 18:18:07>
END VIDEO ENCODING OPERATIONS
Video Source Filter: A2DSource (DirectShowSource)
Created File: C:\Users\Administrator\Videos\DVD_0_Title_01_Durar ara 04.m2v (1044.6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5963 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 24:29 minutes - 35233 frames
START AUDIO ENCODING OPERATIONS (Track 1)
Wavi+Aften Parameters: "C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_ 01_Durarara 04_1.avs" - | "D:\AVStoDVD\Aften\aften.exe" -b 128 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Administrator\Videos\DVD_0_Title_01_Dura rara 04_1.ac3"
<20/7/2556 18:18:25>
END AUDIO ENCODING OPERATIONS (Track 1)
Created File: C:\Users\Administrator\Videos\DVD_0_Title_01_Durar ara 04_1.ac3 (22.4 MB)
OUTPUT AUDIO INFO: AC3 - 128 kbps - CBR - 1 ch - 48000 Hz - 16 bit - 24:30 minutes (0 ms delay)
START SUBS EXTRACTING OPERATIONS (Track 1)
MKVExtract Parameters: tracks "G:\Anime\Durarara\Durarara 04.mkv" 3:"C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Titl e_01_Durarara 04.ssa"
<20/7/2556 18:18:32>
END SUBS EXTRACTING OPERATIONS (Track 1)
Created File: C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_0 1_Durarara 04.ssa (32.2 KB)
START SUBS ENCODING OPERATIONS (Track 1)
SSA/ASS to SRT conversion routine applied (304 subtitles converted)
SRT fixing routine applied (6 lines fixed)
SubtitleCreator Parameters: "C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_ 01_Durarara 04.srt" -p4 -i"D:\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.IF O"
<20/7/2556 18:18:50>
END SUBS ENCODING OPERATIONS (Track 1)
Created File: C:\Users\Administrator\Videos\DVD_0_Title_01_Durar ara 04_1.sup (.71 MB)
TITLE 2 SOURCE FILES
Video: G:\Anime\Durarara\Durarara 05.mkv
Info: AVC - 700 kbps - 1280x720 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 24:29 minutes - 35235 frames
Audio 1: G:\Anime\Durarara\Durarara 05.mkv
Subs 1: G:\Anime\Durarara\Durarara 05.mkv
AVISYNTH SCRIPT
Video = A2DVideoSource("G:\Anime\Durarara\Durarara 05.mkv", CacheFolder="C:\Users\ADMINI~1\AppData\Local\Temp" , FrameRate=23.976, VFR=false)
Audio = FFAudioSource("G:\Anime\Durarara\Durarara 05.mkv", track=2, cachefile="C:\Users\ADMINI~1\AppData\Local\Temp\A2 DFFA_" + String(Rand()) + ".cache")
Encoding Parameters: -ini "C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_ 02_Durarara 05.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_0 2_Durarara 05_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Administrator\Videos\DVD_0_Title_02_Durar ara 05.m2v
*LOGFILE C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_0 2_Durarara 05.HCenc.log
*MAXBITRATE 9000
*1PASS
*BITRATE 7000
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 70
*DC_PREC 10
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<20/7/2556 18:38:55>
Created File: C:\Users\Administrator\Videos\DVD_0_Title_02_Durar ara 05.m2v (979.4 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5590 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 24:29 minutes - 35234 frames
Wavi+Aften Parameters: "C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_ 02_Durarara 05_1.avs" - | "D:\AVStoDVD\Aften\aften.exe" -b 128 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Administrator\Videos\DVD_0_Title_02_Dura rara 05_1.ac3"
<20/7/2556 18:39:34>
Created File: C:\Users\Administrator\Videos\DVD_0_Title_02_Durar ara 05_1.ac3 (22.6 MB)
OUTPUT AUDIO INFO: AC3 - 128 kbps - CBR - 1 ch - 48000 Hz - 16 bit - 24:37 minutes (0 ms delay)
MKVExtract Parameters: tracks "G:\Anime\Durarara\Durarara 05.mkv" 3:"C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Titl e_02_Durarara 05.ssa"
<20/7/2556 18:39:41>
Created File: C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_0 2_Durarara 05.ssa (40.2 KB)
<20/7/2556 18:39:42>
SSA/ASS to SRT conversion routine applied (406 subtitles converted)
SRT fixing routine applied (18 lines fixed)
SubtitleCreator Parameters: "C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_ 02_Durarara 05.srt" -p4 -i"D:\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.IF O"
<20/7/2556 18:39:45>
Created File: C:\Users\Administrator\Videos\DVD_0_Title_02_Durar ara 05_1.sup (.8 MB)
TITLE 3 SOURCE FILES
Video: G:\Anime\Durarara\Durarara 06.mkv
Audio 1: G:\Anime\Durarara\Durarara 06.mkv
Subs 1: G:\Anime\Durarara\Durarara 06.mkv
AVISYNTH SCRIPT
Video = A2DVideoSource("G:\Anime\Durarara\Durarara 06.mkv", CacheFolder="C:\Users\ADMINI~1\AppData\Local\Temp" , FrameRate=23.976, VFR=false)
Audio = FFAudioSource("G:\Anime\Durarara\Durarara 06.mkv", track=2, cachefile="C:\Users\ADMINI~1\AppData\Local\Temp\A2 DFFA_" + String(Rand()) + ".cache")
Encoding Parameters: -ini "C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_ 03_Durarara 06.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_0 3_Durarara 06_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Administrator\Videos\DVD_0_Title_03_Durar ara 06.m2v
*LOGFILE C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_0 3_Durarara 06.HCenc.log
*MAXBITRATE 9000
*1PASS
*BITRATE 7000
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 70
*DC_PREC 10
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<20/7/2556 18:58:09>
Created File: C:\Users\Administrator\Videos\DVD_0_Title_03_Durar ara 06.m2v (1089.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6221 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 24:29 minutes - 35233 frames
Wavi+Aften Parameters: "C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_ 03_Durarara 06_1.avs" - | "D:\AVStoDVD\Aften\aften.exe" -b 128 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Administrator\Videos\DVD_0_Title_03_Dura rara 06_1.ac3"
<20/7/2556 18:58:47>
Created File: C:\Users\Administrator\Videos\DVD_0_Title_03_Durar ara 06_1.ac3 (22.4 MB)
MKVExtract Parameters: tracks "G:\Anime\Durarara\Durarara 06.mkv" 3:"C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Titl e_03_Durarara 06.ssa"
<20/7/2556 18:58:55>
Created File: C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_0 3_Durarara 06.ssa (36.2 KB)
SSA/ASS to SRT conversion routine applied (368 subtitles converted)
SRT fixing routine applied (9 lines fixed)
SubtitleCreator Parameters: "C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Title_ 03_Durarara 06.srt" -p4 -i"D:\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.IF O"
<20/7/2556 18:58:58>
Created File: C:\Users\Administrator\Videos\DVD_0_Title_03_Durar ara 06_1.sup (.72 MB)
<20/7/2556 18:58:59>
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_BatchM ux.ini"
BatchMux ini file:
-d "D:\Videos\DVD_0\VIDEO_TS"
-mxp "C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_MuxMan .mxp"
-l "C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_MuxMan .log"
-muxman "D:\AVStoDVD\MuxMan"
-prio LOW
-palette "C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Palett e.txt"
-v "C:\Users\Administrator\Videos\DVD_0_Title_01_Dura rara 04.m2v"
-vidmode LB
-a1 "C:\Users\Administrator\Videos\DVD_0_Title_01_Dura rara 04_1.ac3"
-a1lang ja
-s1 "C:\Users\Administrator\Videos\DVD_0_Title_01_Dura rara 04_1.sup"
-s1lang en
-s1ext 1
-cellfr "C:\Users\Administrator\Videos\DVD_0_Title_01_Dura rara 04_Chapters.txt"
-progfr "C:\Users\Administrator\Videos\DVD_0_Title_01_Dura rara 04_Chapters.txt"
-chapfr "C:\Users\Administrator\Videos\DVD_0_Title_01_Dura rara 04_Chapters.txt"
-SEG2v "C:\Users\Administrator\Videos\DVD_0_Title_02_Dura rara 05.m2v"
-SEG2vidmode LB
-SEG2a1 "C:\Users\Administrator\Videos\DVD_0_Title_02_Dura rara 05_1.ac3"
-SEG2a1lang ja
-SEG2s1 "C:\Users\Administrator\Videos\DVD_0_Title_02_Dura rara 05_1.sup"
-SEG2s1lang en
-SEG2s1ext 1
-SEG2cellfr "C:\Users\Administrator\Videos\DVD_0_Title_02_Dura rara 05_Chapters.txt"
-SEG2progfr "C:\Users\Administrator\Videos\DVD_0_Title_02_Dura rara 05_Chapters.txt"
-SEG2chapfr "C:\Users\Administrator\Videos\DVD_0_Title_02_Dura rara 05_Chapters.txt"
-SEG3v "C:\Users\Administrator\Videos\DVD_0_Title_03_Dura rara 06.m2v"
-SEG3vidmode LB
-SEG3a1 "C:\Users\Administrator\Videos\DVD_0_Title_03_Dura rara 06_1.ac3"
-SEG3a1lang ja
-SEG3s1 "C:\Users\Administrator\Videos\DVD_0_Title_03_Dura rara 06_1.sup"
-SEG3s1lang en
-SEG3s1ext 1
-SEG3cellfr "C:\Users\Administrator\Videos\DVD_0_Title_03_Dura rara 06_Chapters.txt"
-SEG3progfr "C:\Users\Administrator\Videos\DVD_0_Title_03_Dura rara 06_Chapters.txt"
-SEG3chapfr "C:\Users\Administrator\Videos\DVD_0_Title_03_Dura rara 06_Chapters.txt"
<20/7/2556 19:01:11>
Process aborted during DVD AUTHORING operations!
DVD Authoring operation failed, probably caused by excessive bitrate.
Decrease video and/or audio bitrates and then retry the project.
Check following files for more details:
AVStoDVD log file <D:\Videos\DVD_0.log>
BatchMux log file <D:\Videos\DVD_0_BatchMux.log>
For more troubleshooting on Authoring issues, see Help/FAQ/Authoring.
<20/7/2556 19:01:13>
Log file created by AVStoDVD Release 2.7.0
DVD_0_BatchMux
BatchMux version --> 1.3
Destination Folder --> D:\Videos\DVD_0\VIDEO_TS
MuxMan Script File --> C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_MuxMan. mxp
MuxMan Log String --> -l "C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_MuxMan .log"
Folder of the MuxMan executable --> D:\AVStoDVD\MuxMan
Check presence of MuxMan.exe --> PASSED
Palette File --> C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_Palette .txt
Default Palette --> SUCCESSFULLY REDEFINED
Segment #1 - Video File #1 --> C:\Users\Administrator\Videos\DVD_0_Title_01_Durar ara 04.m2v
Checking asset for importing as --> M2V, M1V, MPV
Video Coding Mode --> MPEG-2
Video Resolution (Nominal) --> (720x480)
MPEG-2 Aspect Ratio (DAR) --> 16:9
Video Frame Rate --> 29,97 fps
Video Bitrate (Nominal, Kbps) --> 8789
VBV Buffer Size (Kbyte) --> 224
Segment #1 - Video Display Mode --> LB
Segment #1 - Audio #1 File #1 --> C:\Users\Administrator\Videos\DVD_0_Title_01_Durar ara 04_1.ac3
Segment #1 - Audio Lang Code #1 --> ja
Segment #1 - Subpicture File #1 --> C:\Users\Administrator\Videos\DVD_0_Title_01_Durar ara 04_1.sup
Segment #1 - Subpic Lang Code #1 --> en
Segment #1 - Subpic Lang Ext #1 --> 1
Segment #1 - Timeframe file --> C:\Users\Administrator\Videos\DVD_0_Title_01_Durar ara 04_Chapters.txt
Segment #1 - Total Nr of Cells --> 5
Segment #1 - Total Nr of Programs --> 5
Segment #1 - Total Nr of Chapters --> 5
Segment #2 - Video File #1 --> C:\Users\Administrator\Videos\DVD_0_Title_02_Durar ara 05.m2v
Segment #2 - Video Display Mode --> LB
Segment #2 - Audio #1 File #1 --> C:\Users\Administrator\Videos\DVD_0_Title_02_Durar ara 05_1.ac3
Segment #2 - Audio Lang Code #1 --> ja
Segment #2 - Subpicture File #1 --> C:\Users\Administrator\Videos\DVD_0_Title_02_Durar ara 05_1.sup
Segment #2 - Subpic Lang Code #1 --> en
Segment #2 - Subpic Lang Ext #1 --> 1
Segment #2 - Timeframe file --> C:\Users\Administrator\Videos\DVD_0_Title_02_Durar ara 05_Chapters.txt
Segment #2 - Total Nr of Cells --> 5
Segment #2 - Total Nr of Programs --> 5
Segment #2 - Total Nr of Chapters --> 5
Segment #3 - Video File #1 --> C:\Users\Administrator\Videos\DVD_0_Title_03_Durar ara 06.m2v
Segment #3 - Video Display Mode --> LB
Segment #3 - Audio #1 File #1 --> C:\Users\Administrator\Videos\DVD_0_Title_03_Durar ara 06_1.ac3
Segment #3 - Audio Lang Code #1 --> ja
Segment #3 - Subpicture File #1 --> C:\Users\Administrator\Videos\DVD_0_Title_03_Durar ara 06_1.sup
Segment #3 - Subpic Lang Code #1 --> en
Segment #3 - Subpic Lang Ext #1 --> 1
Segment #3 - Timeframe file --> C:\Users\Administrator\Videos\DVD_0_Title_03_Durar ara 06_Chapters.txt
Segment #3 - Total Nr of Cells --> 5
Segment #3 - Total Nr of Programs --> 5
Segment #3 - Total Nr of Chapters --> 5
Started preparation of --> MUXMAN SCRIPT
Completed preparation of --> MUXMAN SCRIPT
MuxMan RunString --> -run
Strings (local stack - bytes) --> 2532
Time Codes (local heap - bytes) --> 553
Static memory usage % --> 2.35
Starting MuxMan Authoring with --> LOW task priority
MuxMan Authoring --> COMPLETE
Printing out --> MUXMAN LOG
-- MuxMan version 0.16.8
-- Opened script file C:\Users\ADMINI~1\AppData\Local\Temp\DVD_0_MuxMan. mxp
-- Accepted audio C:\Users\Administrator\Videos\DVD_0_Title_01_Durar ara 04_1.ac3
-- Opened sub 1 file C:\Users\Administrator\Videos\DVD_0_Title_01_Durar ara 04_1.sup.
-- Accepted audio C:\Users\Administrator\Videos\DVD_0_Title_02_Durar ara 05_1.ac3
-- Opened sub 1 file C:\Users\Administrator\Videos\DVD_0_Title_02_Durar ara 05_1.sup.
-- Accepted audio C:\Users\Administrator\Videos\DVD_0_Title_03_Durar ara 06_1.ac3
-- Opened sub 1 file C:\Users\Administrator\Videos\DVD_0_Title_03_Durar ara 06_1.sup.
-- 19:00:06 Begin multiplex VTS01.
-- Title Segment List
-- Seg1
-- Encoded stream 20 is script stream 1.
-- Maximum audio duration 88140 fields.
-- Starting scene Seg1_Scn1 at 00:00:00:00
-- Starting scene Seg1_Scn2 at 00:05:00:10, requested for 00:05:00:00
-- Starting scene Seg1_Scn3 at 00:10:00:14, requested for 00:10:00:00
-- Starting scene Seg1_Scn4 at 00:15:00:10, requested for 00:15:00:00
-- Starting scene Seg1_Scn5 at 00:20:00:05, requested for 00:20:00:00
-- P-STD buffer underflow by 29985 bytes at 122585229, sector 510332.
-- P-STD buffer underflow by 32379 bytes at 122589734, sector 510363.
-- P-STD buffer underflow by 11112 bytes at 122592737, sector 510384.
-- P-STD buffer underflow by 31013 bytes at 122597241, sector 510414.
-- P-STD buffer underflow by 11188 bytes at 122612256, sector 510767.
-- P-STD buffer underflow by 24925 bytes at 122615259, sector 510768.
-- P-STD buffer underflow by 25309 bytes at 122619764, sector 510769.
-- P-STD buffer underflow by 11978 bytes at 122630274, sector 510853.
-- P-STD buffer underflow by 25407 bytes at 122634779, sector 510853.
-- P-STD buffer underflow by 10910 bytes at 122637782, sector 510853.
-- P-STD buffer underflow by 28622 bytes at 122687331, sector 511083.
-- P-STD buffer underflow by 35446 bytes at 122690334, sector 511084.
-- P-STD buffer underflow by 28180 bytes at 122694839, sector 511085.
-- Multiplex operation failed, probably caused by excessive bitrate.
Segment memory resources --> RELEASED
Local Stack memory --> RELEASED
File i/o structures --> DEALLOCATED
I'm a bit new to this stuff, so I have no clue how to solve this.
  cleaning excessive noise with VirtualDub and Neat VideoBy defiantclass1 in forum RestorationReplies: 11Last Post: 16th Aug 2011, 10:24
  AVStoDVDBy Dooker in forum Authoring (DVD)Replies: 10Last Post: 24th Aug 2009, 08:29
  HD footage has excessive motion blur.By mattlolwtf in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 6th Apr 2009, 00:05
  AVStoDVD!By Milardo in forum Authoring (DVD)Replies: 12Last Post: 15th Feb 2009, 06:01
  Question about excessive file swappingBy jimdagys in forum ComputerReplies: 10Last Post: 19th Sep 2008, 10:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
