I need software to convert .webm files to .mp4. I don't want it to re-encode. I just want them to convert over. Will freemake video converter do the trick, or is there a quicker, better way? Thank you!
Results 1 to 10 of 10
WebM uses VP8 video or VP9 video and Vorbis audio.
mp4 uses h.264 video or mpeg4 video and aac audio or mp3 audio.
Therefore you'll have to re-encode for the other container. -
I don't think you can put the vp8/vp9 video(.webm contains vp8 video) in a mp4 container so you must reconvert to mp4 with for example h264 video. You can use freemake video converter for that.
Freemake (I'm using 4.0.2.17) does handle .webm format.
(I got a sample file from here to test it: http://www.webmfiles.org/demo-files/). -
webm does not necessary imply VP9.Freemake (I'm using 4.0.2.17) does handle .webm format.
The only decoders I know of which atm. can handle vp9 are:
a. vpxdec
b. Google Chrome
If Freemake can handle VP9 it would be interesting to know which decoder it is using.
Have you tried a vp9 file? -
first hit using google:Where can I get a VP9...?
http://base-n.de/webm/VP9%20Sample.html (http://base-n.de/webm/out9.webm) -
It appears VP9 wont work with FreemakeVC.
It did detect it as 512x288 16:9 93kbps 25fps (as did media info).
Shame. No doubt support will be added in the future.
(Mp4, AACv2, MKV, Webm, Theora) Drag Drop Convert GUI Update v 1.2.0.0
By richter03 in forum Video ConversionReplies: 11Last Post: 21st Apr 2013, 06:35 -
What is WebM?
By Genevive32 in forum Newbie / General discussionsReplies: 6Last Post: 13th Apr 2013, 10:35 -
tools to convert WebM to dvd or mpeg2 mp4
By theewizard in forum Video ConversionReplies: 13Last Post: 19th Mar 2013, 18:48 -
WebM
By jlopez626 in forum ffmpegX general discussionReplies: 1Last Post: 27th Oct 2012, 03:53 -
mp4 to OGV and WebM Conversion
By kerb in forum Video ConversionReplies: 11Last Post: 25th Mar 2012, 04:00
