Hello, new user here
Simple question but apparently the answer wasn't simple, to me at least..
How do I capture front L/R, C, and LFE from the DTS-HD track, downmix them and turn them into FLAC 2.0?
I just want the best possible 2ch audio and I figured it would be best to derive it off the DTS-HD track, no?
I don't care if I somehow have to take multiple steps in order to achieve it.
I mainly use OSX Lion but also have acces to a Win7 machine...
Results 1 to 11 of 11
eac3to
But wait, maybe you'll find the post below is somewhat truthfulCode:[C:\] =>eac3to eac3to v3.27, freeware by madshi.net - can show information about audio, video, VOB/EVO/(M2)TS and MKV files - can decode and encode various audio formats - can remove dialog normalization from AC3, E-AC3, DTS and TrueHD tracks - can extract AC3 stream from Blu-Ray TrueHD/AC3 tracks - can extract TrueHD stream from Blu-Ray TrueHD/AC3 tracks - can extract DTS core from DTS-HD tracks - can remove DTS zero padding and repair outdated DTS-ES headers - can apply positive or negative audio delays - can reduce bitdepth of decoded audio data by using TPDF dithering - can resample decoded audio data (using SSRC or r8brain) - can apply/reverse PAL speedup on decoded audio data (SSRC/r8brain) - can demux video / audio tracks of EVO/VOB/(M2)TS and MKV sources - can list available titles of Blu-Ray and HD DVD discs - can extract Blu-Ray and HD DVD chapter information and subtitles - can mux MPEG2, VC-1 and h264 video tracks to Matroska - can remove pulldown flags from MPEG2, VC-1 and h264 video tracks eac3to sourcefile[+sourcefile2] [trackno:] [destfile|stdout] [-options] Examples: eac3to source.pcm destination.flac eac3to source.thd destination.flac destination.ac3 eac3to source.evo 1: chapters.txt 2: video.mkv 3: audio.flac 5: subtitle.sup eac3to feature_1.evo+feature_2.evo movie.mkv eac3to blurayMovieFolder movie.mkv Options: -448 use e.g. "192", "448" or "640" kbps for AC3 encoding -768 use "768" or "1536" kbps for DTS encoding -core extract the DTS core of a DTS-HD track +/-100ms apply a positive or negative audio delay +/-3dB apply a positive or negative audio gain (volume change) -0,1,2,3,4,5 remap the channels to the specified order -edit=0:00:00,0ms loops or removes audio data at the specified runtime -silence/-loop forces usage of silence (or looping) for audio edits -down6 downmix 7 or 8 channels to 6 channels -downDpl downmix multi channel audio to Dolby Pro Logic II -downStereo downmix multi channel audio to simple Stereo -phaseShift shift phase (when doing stereo downmixing, see "downDpl") -mixlfe mix LFE in (when doing stereo downmixing, see "downDpl") -down16 downconvert decoded audio data to 14..23 bit -slowdown convert 25.000 and 24.000 content to 23.976 fps -speedup convert 23.976 and 24.000 content to 25.000 fps -23.976/... define source fps to be "23.976", "24.000", "25.000", ... -changeTo24.000 change source fps to "23.976", "24.000", "25.000", ... -resampleTo48000 resample audio to "44100", "48000" or "96000" Hz -quality=0.50 Nero AAC encoding quality (0.00 = lowest; 1.00 = highest) -8 define PCM file to be "1".."8" channels -16 define PCM file to be "16" or "24" bit -little define PCM file to be "little" or "big" endian -96000 define PCM file to be 44100, 48000, 96000 or 192000 Hz -override forcefully overrides PCM auto detection with manual values -sonic/nero/... force the use of a specific decoder (not recommended) -keepDialnorm disables dialog normalization removal (not recommended) -decodeHdcd decodes HDCD source track (usually 16 -> 20 bit) -demux demuxes 1st video track and all audio and subtitle tracks -stripPulldown strips the pulldown from MPEG2 video tracks -keepPulldown disable removal of pulldown for MPEG2, h264 and VC-1 tracks -seekToIFrames make all h264/AVC "I" frames seekable -check checks if the source EVO/(M2)TS file is clean. -test checks if the external filters are installed & working -lowPriority moves processing to background/idle priority -shutdown automatically shutdown the PC after processing is done Supported source formats: (1) RAW, (L)PCM (2) WAV (PCM, DTS and AC3), W64, RF64 (3) AC3, E-AC3 (4) DTS, DTS-ES, DTS-96/24, DTS-HD Hi-Res, DTS-HD Master Audio (5) MP1, MP2, MP3 audio (6) AAC audio (7) MLP, TrueHD, TrueHD/AC3 (8) FLAC (9) EVO/VOB/(M2)TS and MKV Decoded audio data can be stored as / encoded to: (1) RAW, (L)PCM (2) WAV (PCM only), W64, RF64, AGM (3) WAVs (multiple mono WAV files, PCM only) (4) AC3 (5) DTS (6) AAC (7) FLAC For best AAC decoding you need: (1) Nero 7 (Nero 8 won't work!) (2) Nero HD DVD / Blu-Ray plugin For best DTS decoding you need: (1) ArcSoft DTS Decoder - version 1.1.0.0 For DTS encoding you need: (1) SurCode DVD DTS - version 1.0.21 or newer For AAC encoding you need: (1) Nero AAC Encoder For video muxing you need: (1) Haali Matroska Muxer [C:\] =>
http://forum.doom9.org/showthread.php?t=168267 -
personally I would decoder with ffmpeg, pipe the output to sox, downmix with sox the way I want the downmix to happen, pipe to flaccl and rencode to flac. (can be done without using Windows either via command line or Hybrid )How do I capture front L/R, C, and LFE from the DTS-HD track, downmix them and turn them into FLAC 2.0?
If your source already has a professional downmixed stereo stream I would probably prefer that as source.I just want the best possible 2ch audio and I figured it would be best to derive it off the DTS-HD track, no? -
Unfortunately, theres no 2ch track in my source.
I'm probably going to try a few different methods to see what works best for me.
I've haven't really used eac3to, how do I run these commands?
How do I pipeline between different software?
Sorry for asking such noobie questions, I appreciate the answers so far
with a pipe symbol '|' here's an example, which:
1. decodes with ffmpeg
2. does a downmix to stereo (there are a few other threads throughout the forum which show different stereo downmixes with sox)
3. rencode the audio to flac using flaccl (configured for an NVIDIA card)
Cu SelurCode:ffmpeg -y -analyzeduration 100M -probesize 100M -threads 2 -v -10 -i "Input file" -f sox - | sox --multi-threaded --buffer 524288 -S -t sox - -b 16 -t wavpcm - remix -m 1v0.2646,3v0.1870,4v0.1870,5v0.2291,6v0.1323 2v0.2646,3v0.1870,4v0.1870,5v-0.1323,6v-0.2291 gain -n | CUETools.FLACCL.cmd.exe -5 --cpu-threads 4 --opencl-type GPU --opencl-platform "NVIDIA CUDA" --slow-gpu -o "Output.flac" -
Ps.: no clue about eac3to, since I never use it since there's no native version for Linux and it only offers some interesting stuff on Windows with some non-free dlls. -
I assume this code goes in ffmpeg?
Do you follow this example yourself? With it, would I be able to do what I asked in my first post? On OS X aswell? I assume I need ffmpeg, sox and flaccl first of all..
Is there any way to raise the center channel ~3dB? Perhaps even mix the front-wide channels into the downmix?
God I feel lost at this..Last edited by Laciie; 19th Jul 2013 at 17:53. Reason: Misread post
this example calls ffmpeg, sox and CUETools.FLACCL.cmd.exeI assume this code goes in ffmpeg?
If one would modify the downmix, which is done through the "remix -m ....."-part in the sox call: yes.With it, would I be able to do what I asked in my first post?
In you first post you wanted to use 'front L/R, C, and LFE' which is something like a 3.1 track, no clue how to downmix such a stream properly.
The example I posted uses the 5.1 base of the sound, mainly because all free open source decoders only decode the dts-core of a dts-hd stream. (I posted some downmix examples here, but the 4toStereo downmix there assumes a quad audio stream FL,FR,RL,RR.)
on OS X you would need to replace flaccl with the normal flac (and loose gpu encoding support, but other than that the encoding works fine)On OS X aswell?
yesI assume I need ffmpeg, sox and flaccl first of all..
sure, you would need to read up on sox (http://sox.sourceforge.net/sox.html), but it can be done and sox offers multiple ways to boost the volume of channels.Is there any way to raise the center channel ~3dB?
If your decoder supports this: yes; eac3to is capable to decode the whole dts-hd stream using some external (commercial) dll as far as I know.Perhaps even mix the front-wide channels into the downmix?
Since I don't know of any free dts-hd decoder (and not a decoder that only decodes the dts-core of the dts-hd) for either windows/linux/mac, I never bothered much with dts-hd explicitly (I ).
Normally one would leave this to a gui unless one has time and motivation to read up a lot.God I feel lost at this..
Cu Selur -
Thank you, you have been very helpful. I do have some basic coding skills but if I want this done within reasonable time it appears I should get a GUI - any recommendations? There seem to be so many, haven't got a clue as of what to choose.
Convert DTS-HD to Flac
By SeeManRun in forum AudioReplies: 10Last Post: 25th May 2013, 20:46 -
Converting 5.1 FLAC and DTS
By sarofski in forum AudioReplies: 19Last Post: 28th Feb 2013, 05:41 -
questions/help needed inre HD DTS and Flac
By spiritgumm in forum AudioReplies: 9Last Post: 4th Sep 2012, 11:51 -
FLAC to DTS Help
By The_WRATH in forum AudioReplies: 3Last Post: 22nd Nov 2011, 19:00 -
DTS-hd or TrueHd to flac?
By xenotox in forum Blu-ray RippingReplies: 0Last Post: 22nd Feb 2010, 17:17
