Hi guys,
I'm new here and not sure where this post goes, so i'll just type out my problem here.
I have a Video_TS file that I burnt to a DVD using Toast, but upon putting it into my DVD player, it notified me that the file was actually PAL. Now I know it's apparently really hard to convert PAL to NTSC on a computer, so then my question is this: If I use, for example, an MOV file of the same movie, can I extract the menu from the Video_TS and make it work with that MOV file somehow?
Basically I'd like to export the menu and import it in with the MOV file and somehow make it work together. I know this may involve pointing certain parts of the menu to certain parts the movie, but is something like this possible?
Additional Information:
Computer: 15" Macbook Pro
Thanks for taking the time to read this!
In a word. No.
People spend ages converting their PAL dvds to NTSC but you simply can not convert a menu from a PAL dvd to NTSC - the buttons will not appear correctly.
You are not even attempting this. Best to create a new menu and link that to your MOVie
VIDEO_TS 7GB to VIDEO_TS 4GB
By klemyz in forum ffmpegX general discussionReplies: 2Last Post: 9th Dec 2009, 13:43 -
Master Menu For Multiple Video_TS Folders
By MourningStar in forum Newbie / General discussionsReplies: 6Last Post: 17th Jun 2009, 14:38 -
Video_TS folder has no menu(s) in Toast 10
By JonnyPhoenyx in forum MacReplies: 1Last Post: 8th Mar 2009, 16:02 -
How do I make a menu for a video_ts folder that has no menu?
By ericg42 in forum Authoring (DVD)Replies: 5Last Post: 9th Jan 2009, 07:02 -
Help: Freeware for basic DVD menu from VIDEO_TS/VOB
By pannayar in forum Authoring (DVD)Replies: 11Last Post: 12th Aug 2008, 04:17
