I've been putting videos together and makin DVDs for every race I do for a few years. Vegas Pro 9 used to work fine, although I never liked how it lowered the definition of the videos. Well, nowadays I have more mp4 files, and some are from Go Pros, and the stills are larger files now with better definition that in years past. I get some stills coming out blacked out. Then I have to go in and edit the stills to smaller files, and that seems to pull the definition of the videos down. I even convert some of the videos to .avi files before I put them in, and I still get blacked out stills. Would Vegas Pro 12 solve all my problems do you think? If not what would be better? I am very familiar with how Vegas Pro 9 works, so getting an updated Vegas Pro would be nice, but I only want to buy it if all my issues mentioned go away. You guys know a lot more about this than I do. Appreciate the help!
Short answer yes, 12 will work better. But it depends a lot on your system specs as well.
It's hard to work with giant stills in any software. You should resize to 2K max pixel dimensions, or lower the ppi to 96.
NewBlue Titler Pro and Vegas Pro 11 (425) questions
By videobread in forum EditingReplies: 9Last Post: 17th Dec 2011, 10:29 -
Hello..been a long time-Can I upgrade from vegas 5.0 and DVD arch 2.0 to Vegas Pro 9
By arcorob in forum Newbie / General discussionsReplies: 6Last Post: 1st Feb 2010, 20:31 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 22:52 -
What is the difference between Vegas Pro and Vegas movie studio platinum
By jbitakis in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2009, 00:41 -
Can't install outdated component
By ripper389561 in forum ffmpegX general discussionReplies: 3Last Post: 26th Jan 2009, 18:28
