Hi i got some marriage ceremony vcds from my nephew in Uk. I am unable to play the cds it shows blank in windows explorer. I tried ISOBuster to extract iso but it gives error and hangs up.. then i checked the cd format. Its UDF 2.01. I have windows xp. Can someone pls help how to play it on my pc![]()
A CD can, but normally shouldn't, be in UDF formatted filesystem.. VCDs should ALWAYS include an ISO9660 filesystem as well - a VCD created without one isn't legit and will likely not play correctly on a number of devices.
For ISOBuster, what is the error? It is your best bet in getting this resolved, so maybe you should troubleshoot WHY it it having problems - that may lead to an overall solution as well.
Scott -
UDFreader, as suggested by Baldrick, will fix the issue with XP not understanding UDF 2,01 so that needs to be your very first step. Worry about everything else after that.
As Cornucopia points out, UDF is wildly wrong for VCD so be open to the possibility that these discs are completely and utterly botched and you'll never be able to watch them. If you're lucky, your nephew simply made a horrible mistake in copying them. If you're unlucky, the originals are completely botched and you'll have to get whoever has access to the original video to re-do them.
Why the file is the UDF after burning?
By coody in forum Video ConversionReplies: 9Last Post: 15th Feb 2013, 14:13 -
Record files over 4 Gb in UDF?
By Artas1984 in forum MediaReplies: 2Last Post: 8th Dec 2011, 13:53 -
UDF Video
By Axissally in forum Video ConversionReplies: 11Last Post: 22nd Feb 2011, 13:47 -
UDF 2.5 driver for XP 64bit
By INFRATOM in forum Blu-ray RippingReplies: 2Last Post: 20th Mar 2010, 11:27 -
Burning with UDF
By gooberguy in forum Authoring (Blu-ray)Replies: 9Last Post: 18th Jul 2009, 17:01
